Add BIRT runtime library jar files into RCP app? [message #659818] |
Tue, 15 March 2011 13:36  |
I have a RCP application from where I am calling methods to create BIRT reports based on a .rptDesign file.
I am able to do this successfully from a standalone Java app by adding the BIRT runtime *.jar files to the -cp option.
For the RCP app, however, when I launched the RCP app, the code to invoke the runtime library fails with an error message:
java.lang.NoClassDefFoundError: org/eclipse/birt/report/engine/api/IRenderOption
To try to get this to work from I copied the C:\birt-runtime-2_6_2\ReportEngine\lib\ folder into my <workspaceDir>\<myRcpProjectDir>\birtRuntimeLib\ folder.
Then, within the plugin.xml file, within the 'Build' tab, I made sure I added all the jar files from the <workspaceDir>\<myRcpProjectDir>\birtRuntimeLib\ directory into the "Extra Classpath Entries" section.
The error message still shows when I run the RCP app.
Did I miss something?
Thanks so much in advance,
--Anna
FUDForum. Page generated in 0.06883 seconds
