Home » Modeling » EMF » [CDO] Win7 DbStore starts OK but CDO Explorer cannot connect
[CDO] Win7 DbStore starts OK but CDO Explorer cannot connect [message #659814] |
Tue, 15 March 2011 13:08  |
I have successfully setup a CDO DbStore repo on Win7_x64. I can see from
the logs (I turned tracing on for all packages) that the "CDO Server
started" with no errors.
I am using the standards org.eclipse.emf.cdo.server.product-feature with
a modified cdo-server.xml to have the databaseName for Derby to point at
a local directory.
When I use CDO Explorer perspective to connect to this repo on
localhost:2036 it gives me a
"org.eclipse.net4j.util.concurrent.TimeoutRuntimeException: Registration
timeout after 10000 milliseconds"
Is there any other log file or somewhere that might tell me why this is
happening? When I use osgi>clode, it closes down without any exceptions.
There are no exceptions I can find anywhere.
Thx.
David
Re: [CDO] Win7 DbStore starts OK but CDO Explorer cannot connect [message #659825 is a reply to message #659814] |
Tue, 15 March 2011 13:56   |
> a local directory.
> Thx.
> David
I checked netstat -A and there is nothing on port 2036 on 0.0.0.0 or
127.0.0.1 ( I tried both in the config )
Here is the last part of the startup console output:
app thread - org.eclipse.emf.cdo.server.app.0 [debug.lifecycle.dump]
DUMP SmartPreparedStatementCache@25
AbstractPreparedStatementCache.connection =
org.apache.derby.impl.jdbc.EmbedConnection40@515768123 (XID = 715),
(SESSIONID = 15), (DATABASE =
C:/Users/David/workspace/com.example.mdwmui/cdo/derbyedmmode l), (DRDAID
= null)
cache =
org.eclipse.emf.cdo.server.internal.db.SmartPreparedStatemen tCache$Cache@4bbf8a41
checkedOut =
DUMP DBStoreAccessor@24
StoreAccessor.commitContexts =
StoreAccessor.store = DBStore@5
StoreAccessor.context = null
StoreAccessor.reader = true
connection = org.apache.derby.impl.jdbc.EmbedConnection40@515768123
(XID = 715), (SESSIONID = 15), (DATABASE =
= null)
connectionKeepAliveTask =
org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor$ConnectionKeepAliveTask@c0dd841
statementCache = SmartPreparedStatementCache@25
newObjects =
app thread - org.eclipse.emf.cdo.server.app.0 [debug] Created Resource
Query: a228c043-012e-ba8c-7a96-00000400ed18
Query: ea5bc046-012e-ba8c-7a96-00000400ed18
app thread - org.eclipse.emf.cdo.server.app.0 [debug] Resource query
returned ID 1
app thread - org.eclipse.emf.cdo.server.app.0 [debug.lifecycle]
Deactivating DBStoreAccessor@24
Deactivating SmartPreparedStatementCache@25
DUMP Default@26
Repository.name = edmodelrepo
Repository.uuid = null
Repository.store = DBStore@5
Repository.type = MASTER
Repository.state = ONLINE
Repository.properties =
supportingAudits=true
supportingEcore=true
supportingBranches=true
overrideUUID=
Repository.supportingAudits = true
Repository.supportingBranches = true
Repository.ensuringReferentialIntegrity = false
Repository.packageRegistry =
http://www.eclipse.org/emf/2002/Ecore=CDOPackageInfo[packageURI=http://www.eclipse.org/emf/2002/Ecore,
parentURI=null, metaIDRange=[MID1:MID420]]
http://www.eclipse.org/emf/CDO/Eresource/2.0.0=CDOPackageInf o[packageURI=http://www.eclipse.org/emf/CDO/Eresource/2.0.0,
parentURI=null, metaIDRange=[MID421:MID455]]
Repository.branchManager = CDOBranchManagerImpl@21
Repository.revisionManager = CDORevisionManagerImpl@15
Repository.commitInfoManager = CDOCommitInfoManagerImpl@18
Repository.sessionManager = SessionManager@14
Repository.queryManager = QueryManager@17
Repository.commitManager = CommitManager@19
Repository.lockManager = LockManager@20
Repository.queryHandlerProvider = null
Repository.readAccessHandlers =
Repository.writeAccessHandlers =
Repository.rootResourceID = OID1
[INFO] CDO server started
!ENTRY org.eclipse.emf.cdo.server 1 0 2011-03-15 17:24:55.054
!MESSAGE CDO server started
Application Started: 5792
Plugins enabled ( clicked "Add required plugins") include
org.apache.derby (10.5.1.1)
org.apache.derby.core
org.eclipse.emf.cdo (3.0.1)
org.eclipse.emf.cdo.common
org.eclipse.emf.cdo.server.db
org.eclipse.net4j (3.0.1)
org.eclipse.net4j.db
org.eclipse.net4j.db.derby
org.eclipse.net4j.tcp
org.eclipse.net4j.derby
Helios SR2
Without exceptions being thrown kinda hard to know where to look next.
David
Re: [CDO] Win7 DbStore starts OK but CDO Explorer cannot connect [message #659827 is a reply to message #659826] |
Tue, 15 March 2011 14:06   |
Ha,
I missed the org.eclipse.emf.cdo.server.tcp. I was following this
http://wiki.eclipse.org/Setting_up_a_CDO_Server
And it lists these
* org.apache.derby
* org.eclipse.emf.cdo.server.db
* org.eclipse.net4j.db.derby
* org.eclipse.net4j.tcp
And the "Add required plugins" does not pick it up, opps.
Thx.
David
On 15/03/11 18:01, David Wynter wrote:
> On 15/03/11 17:54, Eike Stepper wrote:
>> Am 15.03.2011 18:53, schrieb Eike Stepper:
>>> Am 15.03.2011 18:08, schrieb David Wynter:
>>>> from the logs (I turned tracing on for all packages) that the "CDO
>>>> Server started" with no errors.
>>>> with a modified cdo-server.xml to have the databaseName for Derby to
>>>> point at a local directory.
>>>> Registration timeout after 10000 milliseconds"
>>>> is happening? When I use osgi>clode, it closes down without any
>>>> exceptions. There are no exceptions I can find anywhere.
>>> Most commonly this is because the org.eclipse.emf.cdo.server.net4j is
>>> not deployed properly to the server.
>> And org.eclipse.net4j.tcp is also needed on the server. Please also
>> check your firewall settings.
>> I doubt this is a Win7_64 related issue, as I'm using the same for
>> development ;-)
>> Cheers
>> /Eike
>> http://www.esc-net.de
>> http://thegordian.blogspot.com
>> http://twitter.com/eikestepper
> Firewall allows all ports in and out for Eclipse. But to be safe I added
> a new rule to allow port 2036 in and out for anything. It satill does
> not appear in netstat -A on 0.0.0.0
> As in my recent post, net4j is enabled in the plugins
> Thx.
> David
Re: [CDO] Win7 DbStore starts OK but CDO Explorer cannot connect [message #659834 is a reply to message #659827] |
Tue, 15 March 2011 14:10   |
Am 15.03.2011 19:06, schrieb David Wynter:
> Ha,
There's no such plugin. You mean org.eclipse.emf.cdo.server.net4j? That's important and Add Required Plugins wouldn't pick it up because it's optional from a repository's perspective. So, does it work now?
Cheers
/Eike
> And it lists these
> * org.apache.derby
> Thx.
> David
>>> development ;-)
>>> Cheers
>>> /Eike
>> Hi,
>> Thx.
>> David
Re: [CDO] Win7 DbStore starts OK but CDO Explorer cannot connect [message #659835 is a reply to message #659834] |
Tue, 15 March 2011 14:28   |
Yeah, sorry, what you said ;)
Yes it works fine, the tutorial just needs to have
added to the list, which I just did.
Thx.
David
>> Ha,
> Cheers
> /Eike
>> And it lists these
>> * org.apache.derby
>> Thx.
>> David
>>>> development ;-)
>>>> Cheers
>>>> /Eike
>>> Hi,
>>> Thx.
>>> David
Re: [CDO] Win7 DbStore starts OK but CDO Explorer cannot connect [message #659876 is a reply to message #659835] |
Tue, 15 March 2011 16:42  |
Am 15.03.2011 19:28, schrieb David Wynter:
> Yes it works fine,
Great ;-)
Thank you!
Cheers
/Eike
> Thx.
> David
>>> Ha,
>> Cheers
>> /Eike
>>> And it lists these
>>> * org.apache.derby
>>> Thx.
>>> David
>>>>> development ;-)
>>>>> Cheers
>>>>> /Eike
>>>> Hi,
>>>> Thx.
>>>> David
Current Time: Wed Jul 23 12:40:46 EDT 2025
Powered by FUDForum. Page generated in 3.52277 seconds
