Home » Modeling » Epsilon » ETL - How to Handle Metamodel Extensions
ETL - How to Handle Metamodel Extensions [message #659732] Tue, 15 March 2011 08:10 Go to next message
Hi Dimitris,
I have a metamodel with a containment called extensions of type = meta-class 'AbstractExtension'
AbstractExtension can be extended in new metamodels to extend the modelling notation.
I have recently changed to use Helios and this version of Epsilon: 0.9.0.201101251228
The problem is that my ETL rules no longer trigger when source is a metaclass of the new extension metamodel.
e.g. Neither of these rules are triggered...
rule test
transform s : Source!NewMetaClass
to t : Target!OldMetaClass{
"TEST".println();
rule test2
transform s : SourceExtension!NewMetaClass
"TEST".println();
Where NewMetaClass extends AbstractExtension.
Source is the source model with the old Metamodel
SourceExtension is the same source model with the new extension metamodel.
By the way, if you type NewMetaClass incorrectly it gives an exception so it is finding this metaclass.
Also, the following finds an instance of the new metaclass...
@greedy
rule test
transform s : Source!AbstractExtension
to t : Target!NewMetaClass{
"TEST".println();
s.name.println();
The same rules used to work ok in the old Galileo version of Epsilon 0.8.9.201004151115
Has something changed? Am I doing something wrong?
Asieh
Re: ETL - How to Handle Metamodel Extensions [message #660017 is a reply to message #659732] Wed, 16 March 2011 10:54 Go to previous message
Hi Asiah,
Could you please send me a minimal configuration I can use to reproduce this at epsilon.devs gmail com?
Dimitris
Previous Topic:[EVL] NoSuchMethodError in exported plugin
Next Topic:[Eugenia] link creation problem
Current Time: Wed Jul 23 07:46:35 EDT 2025
Powered by FUDForum. Page generated in 0.13187 seconds
