Home » Eclipse Projects » EclipseLink » Dynamic EclipseLink JPA Clarification(How to get DynamicClassLoader? [EclipseLink+Jersey and Glassfish 3.1])
Dynamic EclipseLink JPA Clarification [message #659629] Mon, 14 March 2011 16:52 Go to next message
Hi all and excuse my english,
I try to explain my problem: I should manage entities not mapped in persistence.xml. These entities are created runtime so I haven't jpa entities in my web application.
So I was reading about the dynamic entities on http://wiki.eclipse.org/EclipseLink/Examples/JPA/Dynamic
and the example http://dev.eclipse.org/svnroot/rt/org.eclipse.persistence/br anches/2.1/trunk/examples/jpa.employee/eclipselink.example.j pa.employee.dynamic/src/example/EmployeeDynamicMappings.java
But I don't know how to get
DynamicClassLoader dcl
because in the above example it's passed on function. So I paste my example code:
@ManagedBean
@Path("/entity")
public class MyDynamicEntity {
	@PersistenceContext(unitName = "data5PU")
	EntityManager em;
	@SuppressWarnings("unchecked")
	@GET
	@Produces(MediaType.TEXT_PLAIN)
	public String get() {
		DatabaseSession session = new DatabaseSessionImpl();
		session.setProperty(PersistenceUnitProperties.WEAVING, "true");
		// session.setProperty(PersistenceUnitProperties.WEAVING_FETCHGROUPS,
		// "true");
		session.login();
		DynamicClassLoader dcl = DynamicClassLoader.lookup(session);
		Class<?> aziendaClass = dcl.createDynamicClass("entity.Azienda");
		JPADynamicTypeBuilder builder = new JPADynamicTypeBuilder(aziendaClass,
				null, "D_AZIENDA");
		builder.addDirectMapping("id", int.class, "A_ID");
		builder.addDirectMapping("nome", String.class, "A_NAME");
		builder.setPrimaryKeyFields("A_ID");
		DynamicType type = builder.getType();
		DynamicHelper dynamicHelper = new JPADynamicHelper(em);
		DynamicEntity l = null;
		l = (DynamicEntity) em.find(type.getJavaClass(), 0);
		return l.get("A_NAME");
But in this way I got this error:
JACC Policy Provider: Failed Permission Check.. - permission((org.osgi.framework.AdminPermission (id=220) resolve,resource))
Any suggestions to resolve? What's wrong?
[Updated on: Tue, 15 March 2011 04:53] by Moderator
Re: Dynamic EclipseLink JPA Clarification [message #659640 is a reply to message #659629] Mon, 14 March 2011 17:44 Go to previous messageGo to next message
Ok my first error is that:
Note: Container managed persistence not supported
Anyway I don't know what's currentLoader in this row in the tutorial
DynamicClassLoader dcl = new DynamicClassLoader(currentLoader);
[Updated on: Mon, 14 March 2011 17:45] by Moderator
Re: Dynamic EclipseLink JPA Clarification [message #659728 is a reply to message #659640] Tue, 15 March 2011 07:23 Go to previous messageGo to next message
These are my progress:
I added the following line into server.policy
permission java.lang.RuntimePermission    "createClassLoader";
and in this way i don't have the permission exception CreateClassLoader
I paste mine test code, supposing I have a table called "Azienda(id integer,nome varchar)" and wanting to create a dynamic entity class called "entity.Azienda"
@Path("/entity")
	EntityManager em;
	@GET
		Map<String, Object> properties = new HashMap<String, Object>();
		EntityManagerFactory emf = Persistence.createEntityManagerFactory("data5PU", properties);
		em = emf.createEntityManager();
		Session session = JpaHelper.getEntityManager(em).getSession();
				null, "Azienda");
		builder.addDirectMapping("id", Integer.class, "id");
		builder.addDirectMapping("nome", String.class, "nome");
		builder.setPrimaryKeyFields("id");
		l =  (DynamicEntity) em.find(aziendaClass, 0);
		return l.<String>get("nome");
Now the problem is:
java.lang.IllegalArgumentException: Unknown entity bean class: class entity.Azienda, please verify that this class has been marked with the @Entity annotation.
The advice and assistance would be greatly appreciated. I do not know what to do yet!!!
Re: Dynamic EclipseLink JPA Clarification [message #666843 is a reply to message #659728] Sat, 23 April 2011 03:11 Go to previous messageGo to next message
Originally posted by: gregor.karl.frey.t-online.de
You must add the DynamicType to the session using the JPAHelper.
Something like:
JPADynamicHelper(getEntityManagerFactory());
dynamicHelper.addTypes(true, true, builder.getType())
The two boolean parameters control the creation of missing tables and
foreign key constraints.
Gregor
> @Path("/entity")
> EntityManager em;
> @GET
> null, "Azienda");
> Now the problem is:
> Quote:
>> @Entity annotation.
> what to do yet!!!
Re: Dynamic EclipseLink JPA Clarification [message #903395 is a reply to message #666843] Thu, 23 August 2012 09:26 Go to previous messageGo to next message
Hi Gregor
I understand that JPA entity extensions can be used in Java EE environment. Can I also use "Dynamic EclipseLink JPA" in Java EE (glassfish) environment?
Basically, I want to add mapping to an existing JPA entity class at runtime using "Dynamic EclipseLink JPA" in glassfish environment.
Thanks in advance
Chirag
Re: Dynamic EclipseLink JPA Clarification [message #905007 is a reply to message #903395] Wed, 29 August 2012 10:50 Go to previous message
Yes, Dynamic EclipseLink JPA should work in JEE and Glassfish.
Previous Topic:Named Query not found
Next Topic:Converter is not called on load operation
Current Time: Sat Jul 26 11:36:35 EDT 2025
Powered by FUDForum. Page generated in 0.25798 seconds
