Home » Modeling » EMF » [CDO] H2 support
[CDO] H2 support [message #659553] Mon, 14 March 2011 10:58 Go to next message
I'm using CDO 4.0 with HSQLDB (1.8.0) as backend.
I want to move on H2 db as it seems to be the suggested reference from
CDO Team for Java Relational DB.
Hence, I've downloaded H2 latest version : 1.3.152. Nevertheless, I
can't connect to such a H2 server. It seems net4j H2 adapter only
supports 1.1.117 H2 product.
Is it right so far ?
I've updated the net4j H2 adapter to make it compatible with 1.3.152 H2
bundle, it is running so far...
How to make sure adaptation is really up-to-date ?
I can see some adaptations in H2Adapter class : getTypeName(...), it may
have changed between 1.1.x and 1.3.x.
Is it plan to move on H2 1.3.x versions officially ?
Stephane.
Re: [CDO] H2 support [message #659568 is a reply to message #659553] Mon, 14 March 2011 11:26 Go to previous messageGo to next message
Am 14.03.2011 15:58, schrieb Stephane Fournier:
> I want to move on H2 db as it seems to be the suggested reference from CDO Team for Java Relational DB.
> Hence, I've downloaded H2 latest version : 1.3.152. Nevertheless, I can't connect to such a H2 server. It seems net4j H2 adapter only supports 1.1.117 H2 product.
I didn't think so. What makes you think that?
> I've updated the net4j H2 adapter to make it compatible with 1.3.152 H2 bundle, it is running so far...
Can you attach a patch to a bugzilla? Maybe we can look at it after the EclipseCon.
Are your changes backward compatible or would they imply we had to maintain multiple versions of the adapter?
I don't understand this question ;-(
> I can see some adaptations in H2Adapter class : getTypeName(...), it may have changed between 1.1.x and 1.3.x.
What is an adaptation and where exactly are you seeing them?
Not yet, but we seem to get more and more complaints about the old driver. Stefan, what do you think?
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] H2 support [message #659573 is a reply to message #659568] Mon, 14 March 2011 11:46 Go to previous messageGo to next message
the main reason we support 1.1.117 is that this is the version in Orbit.
If Orbit moves to a new revision, we can and should, too. Otherwise we
would need to either decouple from Orbit or manage multiple revisions.
Stefan
Am 14.03.11 16:26, schrieb Eike Stepper:
>> Hi,
> EclipseCon.
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
Re: [CDO] H2 support [message #659575 is a reply to message #659568] Mon, 14 March 2011 11:56 Go to previous messageGo to next message
Hi Eike,
>> Hi,
In org.eclipse.net4j.db.h2 plug-in, the dependencies to org.h2 refer to
[1.1.0,1.2.0)
Hence, when I tried to connect a cdo server to a Generic H2 Server
1.3.152, I got exceptions :
org.h2.jdbc.JdbcSQLException: Version mismatch, driver version
is "0" but server version is "6" [90047-152]
at org.h2.message.DbException.getJdbcSQLException(DbException.j ava:327)
at org.h2.message.DbException.get(DbException.java:167)
at org.h2.server.TcpServerThread.run(TcpServerThread.java:73)
org.eclipse.net4j.db.DBException: org.h2.jdbc.JdbcSQLException: Version
mismatch, driver version is "0" but server version is "6" [90047-152]
H2Adapter class has a constant String VERSION = "1.1.114". Does it mean
it only works with that version ?
I only changed bundles dependencies from [1.1.0,1.2.0) to [1.1.0,1.4.0)
and I converted h2-1.3.152.jar into a bundle, deployed in my Target
platform.
I did not modify Java code.
> EclipseCon.
Sure If the changes I made suit the CDO team, I can make a patch.
The changes about org.eclipse.net4j.db.h2 are backward compatible so far.
As getTypeName() method seems to convert types, it may have some new
switch cases to handle with the 1.3.x ?
What is the purpose of the constant VERSION referencing 1.1.114 ? Should
we change it to another version ?
> Cheers
> /Eike
Re: [CDO] H2 support [message #659582 is a reply to message #659575] Mon, 14 March 2011 12:26 Go to previous messageGo to next message
Am 14.03.2011 16:56, schrieb Stephane Fournier:
> Hi Eike,
>>> Hi,
> In org.eclipse.net4j.db.h2 plug-in, the dependencies to org.h2 refer to org.h2.jdbc.JdbcSQLException: Version mismatch, driver version is "0" but server version is "6" [90047-152]
> org.eclipse.net4j.db.DBException: org.h2.jdbc.JdbcSQLException: Version mismatch, driver version is "0" but server version is "6" [90047-152]
> H2Adapter class has a constant String VERSION = "1.1.114". Does it mean it only works with that version ?
It's actually meaningless at the moment. We've added the version attribute to the extension point structure for the future when we might have to maintain multiple versions. Today I think, if it comes to that situation, we should better rely on OSGi's versioned dependency management ;-)
> I only changed bundles dependencies from [1.1.0,1.2.0) to [1.1.0,1.4.0) and I converted h2-1.3.152.jar into a bundle, deployed in my Target platform.
Ok, that should no longer be necessary as soon as you switch to newer builds.
>> EclipseCon.
Thanks, but not needed anymore, if it isn't more than the increase of the upper import version :P
> As getTypeName() method seems to convert types, it may have some new switch cases to handle with the 1.3.x ?
That's something you could try to find out exactly, if you want to help us.
Cheers
/Eike
> What is the purpose of the constant VERSION referencing 1.1.114 ? Should we change it to another version ?
>> Cheers
>> /Eike
Re: [CDO] H2 support [message #659583 is a reply to message #659573] Mon, 14 March 2011 12:27 Go to previous message
Am 14.03.2011 16:46, schrieb Stefan Winkler:
> If Orbit moves to a new revision, we can and should, too. Otherwise we would need to either decouple from Orbit or manage multiple revisions.
Or we request Eclipse legal approval and maintain a newer version of H2 in Orbit ourselves. The deadline for Indigo CQs has past, though ;-(
Cheers
/Eike
> Cheers,
> Stefan
>>> Hi,
>> EclipseCon.
>> Cheers
>> /Eike
Previous Topic:Save key value pairs
Next Topic:[CDO/Teneo] Data type error with H2 support
Current Time: Sat Jul 26 20:57:27 EDT 2025
Powered by FUDForum. Page generated in 0.04467 seconds
