Home » Modeling » EMF » [CDO] H2 support
[CDO] H2 support [message #659553] |
Mon, 14 March 2011 10:58  |
I'm using CDO 4.0 with HSQLDB (1.8.0) as backend.
I want to move on H2 db as it seems to be the suggested reference from
CDO Team for Java Relational DB.
Hence, I've downloaded H2 latest version : 1.3.152. Nevertheless, I
can't connect to such a H2 server. It seems net4j H2 adapter only
supports 1.1.117 H2 product.
Is it right so far ?
I've updated the net4j H2 adapter to make it compatible with 1.3.152 H2
bundle, it is running so far...
How to make sure adaptation is really up-to-date ?
I can see some adaptations in H2Adapter class : getTypeName(...), it may
have changed between 1.1.x and 1.3.x.
Is it plan to move on H2 1.3.x versions officially ?
Stephane.
Re: [CDO] H2 support [message #659573 is a reply to message #659568] |
Mon, 14 March 2011 11:46   |
the main reason we support 1.1.117 is that this is the version in Orbit.
If Orbit moves to a new revision, we can and should, too. Otherwise we
would need to either decouple from Orbit or manage multiple revisions.
Stefan
Am 14.03.11 16:26, schrieb Eike Stepper:
> Am 14.03.2011 15:58, schrieb Stephane Fournier:
>> Hi,
> I didn't think so. What makes you think that?
>> H2 bundle, it is running so far...
> Can you attach a patch to a bugzilla? Maybe we can look at it after the
> EclipseCon.
> Are your changes backward compatible or would they imply we had to
> maintain multiple versions of the adapter?
> I don't understand this question ;-(
>> may have changed between 1.1.x and 1.3.x.
> What is an adaptation and where exactly are you seeing them?
> Not yet, but we seem to get more and more complaints about the old
> driver. Stefan, what do you think?
> Cheers
> /Eike
> http://www.esc-net.de
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
Re: [CDO] H2 support [message #659575 is a reply to message #659568] |
Mon, 14 March 2011 11:56   |
Hi Eike,
>> Hi,
In org.eclipse.net4j.db.h2 plug-in, the dependencies to org.h2 refer to
[1.1.0,1.2.0)
Hence, when I tried to connect a cdo server to a Generic H2 Server
1.3.152, I got exceptions :
org.h2.jdbc.JdbcSQLException: Version mismatch, driver version
is "0" but server version is "6" [90047-152]
at org.h2.message.DbException.getJdbcSQLException(DbException.j ava:327)
at org.h2.message.DbException.get(DbException.java:167)
at org.h2.server.TcpServerThread.run(TcpServerThread.java:73)
org.eclipse.net4j.db.DBException: org.h2.jdbc.JdbcSQLException: Version
mismatch, driver version is "0" but server version is "6" [90047-152]
H2Adapter class has a constant String VERSION = "1.1.114". Does it mean
it only works with that version ?
I only changed bundles dependencies from [1.1.0,1.2.0) to [1.1.0,1.4.0)
and I converted h2-1.3.152.jar into a bundle, deployed in my Target
platform.
I did not modify Java code.
> EclipseCon.
Sure If the changes I made suit the CDO team, I can make a patch.
The changes about org.eclipse.net4j.db.h2 are backward compatible so far.
As getTypeName() method seems to convert types, it may have some new
switch cases to handle with the 1.3.x ?
What is the purpose of the constant VERSION referencing 1.1.114 ? Should
we change it to another version ?
> Cheers
> /Eike
Re: [CDO] H2 support [message #659582 is a reply to message #659575] |
Mon, 14 March 2011 12:26   |
Am 14.03.2011 16:56, schrieb Stephane Fournier:
> Hi Eike,
>>> Hi,
> In org.eclipse.net4j.db.h2 plug-in, the dependencies to org.h2 refer to org.h2.jdbc.JdbcSQLException: Version mismatch, driver version is "0" but server version is "6" [90047-152]
> org.eclipse.net4j.db.DBException: org.h2.jdbc.JdbcSQLException: Version mismatch, driver version is "0" but server version is "6" [90047-152]
> H2Adapter class has a constant String VERSION = "1.1.114". Does it mean it only works with that version ?
It's actually meaningless at the moment. We've added the version attribute to the extension point structure for the future when we might have to maintain multiple versions. Today I think, if it comes to that situation, we should better rely on OSGi's versioned dependency management ;-)
> I only changed bundles dependencies from [1.1.0,1.2.0) to [1.1.0,1.4.0) and I converted h2-1.3.152.jar into a bundle, deployed in my Target platform.
Ok, that should no longer be necessary as soon as you switch to newer builds.
>> EclipseCon.
Thanks, but not needed anymore, if it isn't more than the increase of the upper import version :P
> As getTypeName() method seems to convert types, it may have some new switch cases to handle with the 1.3.x ?
That's something you could try to find out exactly, if you want to help us.
Cheers
/Eike
> What is the purpose of the constant VERSION referencing 1.1.114 ? Should we change it to another version ?
>> Cheers
>> /Eike
Re: [CDO] H2 support [message #659583 is a reply to message #659573] |
Mon, 14 March 2011 12:27  |
Am 14.03.2011 16:46, schrieb Stefan Winkler:
> If Orbit moves to a new revision, we can and should, too. Otherwise we would need to either decouple from Orbit or manage multiple revisions.
Or we request Eclipse legal approval and maintain a newer version of H2 in Orbit ourselves. The deadline for Indigo CQs has past, though ;-(
Cheers
/Eike
> Cheers,
> Stefan
>>> Hi,
>> EclipseCon.
>> Cheers
>> /Eike
Current Time: Sat Jul 26 10:59:21 EDT 2025
Powered by FUDForum. Page generated in 0.04174 seconds
