| Display#asynExec since 1.3.0-M7 [message #659262] |
Fri, 11 March 2011 11:35   |
Eclipse User  |
Hi RAP Team,
Since 1.3.0-M7 Display#asyncExec implementation uses synchronizer,
however this seems to break my unit test. Currently we have code
similliar below:
Button button = ....
SelectionAdapter adapter = new SelectionAdapter()
	public void widgetSelected(SelectionEvent event)
		doSomething();
button.addSelectionListener(adapter);
void doSomething()
	Display.getCurrent().asynExec
		new Runnable()
			public void run()
I can run my application as usual just fine, but in unit tests in which
I call method 'doSomething' directly the Runnable's run won't get
invoked at all.
Any help would be greatly appreciated.
Thanks & Regards,
Setya
| Re: Display#asynExec since 1.3.0-M7 [message #659617 is a reply to message #659342] |
Mon, 14 March 2011 15:00    |
Eclipse User  |
Setya,
your 'workaround' is actually the proper solution to the problem. You
need to spin the event loop to get messages processed. This includes
(a)sync runnables. This behavior now also aligns with how SWT processes
runnables.
Sorry for the late response and the inconvenience.
Rüdiger
On 12.03.2011 14:53, Setya wrote:
> Hi all,
> My workaround so far is:
> while (Display.getCurrent().readAndDispatch()){}
> Any better workarounds are welcome.
> Thanks & Regards,
> Setya
>> Hi all,
>> After debugging I found that the following code :
>> while(  UICallBackManager.getInstance().processNextRunnableInUIThrea d()) {
>> had been removed from RWTLifeCycle#afterPhaseExecution.
>> And there was a comment stating that by removing the code
>> asyncExec-runnables that are added in an after-PROCESS_ACTION-listener
>> would not be processed in the same request.
>> Any workaround on this ?
>> Thanks & Regards,
>> Setya
>>> Hi RAP Team,
>>> similliar below:
>>> doSomething();
>>> void doSomething()
>>> new Runnable()
>>> public void run()
>>> invoked at all.
>>> Thanks & Regards,
>>> Setya
| Re: Display#asynExec since 1.3.0-M7 [message #659894 is a reply to message #659617] |
Tue, 15 March 2011 18:39   |
Eclipse User  |
Rudiger,
Thank you for your clarification. Glad to know that I don't have to hack
anything.
Thanks & Regards,
Setya
> Setya,
> runnables.
> Regards,
> Rüdiger
>> Hi all,
>> Thanks & Regards,
>> Setya
>>> Hi all,
>>> while(
>>> Thanks & Regards,
>>> Setya
>>>> Hi RAP Team,
>>>> similliar below:
>>>> doSomething();
>>>> void doSomething()
>>>> new Runnable()
>>>> public void run()
>>>> invoked at all.
>>>> Thanks & Regards,
>>>> Setya
FUDForum. Page generated in 0.03811 seconds
