Home » Modeling » EMF » EMF Editor and CrossReference(Build an editor that allow creation of cross reference element)
EMF Editor and CrossReference [message #659211] Fri, 11 March 2011 09:57 Go to next message
Hi, my question is the following: Is there a way to manage two models in the same generated editor. For example :
(I have two model where i generate Model / Edit / Editor).
Model 1:
Class A , contains many 'AbstractA'
'AConcrete' extends 'AbstractA'
Model 2 (in a different plugin):
Class B extends 'AbstractA' by cross-reference to model 1.
When i generate editor for model1 and execute it, when i use the custom editor generated for model1 and i try to create new element from Class A, using the right-click .. createChild, the only element that appears is 'AConcrete'. Is there a way to show 'Class B' also?
This should not be a problem because Class B extends the same element as 'AConcrete'.
Is there something i'm doing wrong? or is there any options in the genModel that allow me to achieve this?
Thanks for your help
David C.
Re: EMF Editor and CrossReference [message #659246 is a reply to message #659211] Fri, 11 March 2011 10:26 Go to previous messageGo to next message
--------------040407020401090506050802
David,
If you generated them from a single GenModel it would work. Or you
could use the approach described here:
http://ed-merks.blogspot.com/2008/01/creating-children-you-d idnt-know.html
> Model 1:
> as 'AConcrete'.
> David C.
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
David,<br>
<br>
could use the approach described here:<br>
<blockquote><a
href=" http://ed-merks.blogspot.com/2008/01/creating-children-you-d idnt-know.html"> http://ed-merks.blogspot.com/2008/01/creating-children-you-d idnt-know.html</a><br>
</blockquote>
<br>
David wrote:
<blockquote cite="mid:ildcrm$que$1@news.eclipse.org" type="cite">Hi, my
<br>
<br>
<br>
<br>
Model 1:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
as 'AConcrete'.
<br>
<br>
<br>
<br>
<br>
<br>
David C.
<br>
</blockquote>
</body>
</html>
--------------040407020401090506050802--
Re: EMF Editor and CrossReference [message #659249 is a reply to message #659246] Fri, 11 March 2011 11:42 Go to previous message
Thx for your reply Ed, i'll take a look at the article.
David
Previous Topic:Editing EObject properties
Next Topic:Best practices: versioning .ecore files
Current Time: Fri Jul 25 21:33:50 EDT 2025
Powered by FUDForum. Page generated in 0.03616 seconds
