| [Xtext] implement toString() with the ParseTreeConstructor [message #659244] | Fri, 11 March 2011 10:54  |  |
| Eclipse User  |  |  |  |  | Hi,
 I'm wondering if there is a way ((static) utility method or something
 like this) for creating a String from a model object according to the
 grammar. That is, I want to print out my model elements according to the
 grammer, mainly for debugging purposes. In some cases, I do not have an
 Xtext text file but only the model elements.
 I figure it should be possible to use the generated parse tree
 constructor to achieve that, isn't it? (I do not need the formatter).
 Before I start digging into the constructor, I was wondering if some
 kind of utility class doing exactly this already exists?
 Actually, what I want to do is to replace the generated toString()
 methods in my model implementation with this grammar like output. Maybe
 there is a hidden switch to even enable that? Or do I have to do this
 myself, e.g. by implementing a post processor transformation adding the
 toString body to the model elements?
 Jens
| Re: [Xtext] implement toString() with the ParseTreeConstructor [message #659266 is a reply to message #659244] | Fri, 11 March 2011 12:48   |  |
| Eclipse User  |  |  |  |  | Did you look at Serialization? - it produces text/string from the model.
 - henrik
 On 3/11/11 4:54 PM, Jens v.P. wrote:
 > Cheers,
 > Jens
FUDForum. Page generated in 0.03880 seconds
