Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Undo/Redo with 3.4 Commands
Undo/Redo with 3.4 Commands [message #480056] |
Thu, 13 August 2009 11:32  |
Hi all,
I used to have an old 3.2 RCP app. I had created my own type of editor,
which used the workbench operation history like so:
operationHistory =
editor.getEditorSite().getWorkbenchWindow().getWorkbench().g etOperationSupport().getOperationHistory();
In the apps ApplicationActionBarAdvisor, I used the undo and redo actions
like so:
undoAction = ActionFactory.UNDO.create(window);
register(undoAction);
Now, when we upgraded to 3.4 and the new menu/command/handler mechanism,
i'm adding the commands to the menu bar as follows (note I dont have
handlers for them)
CommandContributionItemParameter param = new
CommandContributionItemParameter(window, "undo",
"org.eclipse.ui.edit.undo", SWT.NONE);
CommandContributionItem undo = new CommandContributionItem(param);
Unfortunatley, the undo/redo commands don't work anymore. They aren't
updated when my editor operation history changes. Is there anything more I
need to do, to link the commands to the workbench operation history? Do
they not have default handlers to track the operation history?
I've googled my ass off over this, but i'm still not getting anywhere. Any
help would be greatly appreciated!
Thanks.
Re: Undo/Redo with 3.4 Commands [message #480094 is a reply to message #480056] |
Thu, 13 August 2009 15:14   |
Originally posted by: phillipus.nowhere.net
Rob wrote:
> Hi all,
> operationHistory =
> actions like so:
> handlers for them)
> I need to do, to link the commands to the workbench operation history?
> Do they not have default handlers to track the operation history?
> Any help would be greatly appreciated!
> Thanks.
I use Undo/Redo in 3.5 but on a View. I also have the same global menus
as you in the ApplicationActionBarAdvisor.
Here's some code that might point you in the right direction as I use it
on my view:
public class MyView extends ViewPart {
private UndoActionHandler fUndoActionHandler;
private RedoActionHandler fRedoActionHandler;
private IUndoContext fUndoContext;
public void createPartControl(Composite parent) {
initializeOperationHistory();
createGlobalActions();
registerGlobalActionHandlers();
private void createGlobalActions() {
// Undo / Redo
fUndoActionHandler = new UndoActionHandler(getViewSite(),
fUndoContext);
fRedoActionHandler = new RedoActionHandler(getViewSite(),
fUndoContext);
private void registerGlobalActionHandlers() {
IActionBars actionBars = getViewSite().getActionBars();
// Register the global menu actions
actionBars.setGlobalActionHandler(ActionFactory.UNDO.getId() ,
fUndoActionHandler);
actionBars.setGlobalActionHandler(ActionFactory.REDO.getId() ,
fRedoActionHandler);
public void setFocus() {
* Initialize the workbench operation history for our undo context.
private void initializeOperationHistory() {
// Create a unique undo context to represent this editor's undo
history
fUndoContext = new ObjectUndoContext(this);
// Set the undo limit for this context (could put this in Prefs)
int limit = 500;
IOperationHistory history =
PlatformUI.getWorkbench().getOperationSupport().getOperation History();
history.setLimit(fUndoContext, limit);
Re: Undo/Redo with 3.4 Commands [message #480173 is a reply to message #480094] |
Fri, 14 August 2009 05:24   |
Phillipus wrote:
> Rob wrote:
>> Hi all,
>> operationHistory =
>> actions like so:
>> handlers for them)
>> Thanks.
> on my view:
> @Override
> // Undo / Redo
> fUndoContext);
> fUndoContext);
> @Override
> history
> int limit = 500;
Thank for the reply! You seem to be using the old actions mechanism for
your menu items. Are you adding Actions to your menu bar? I am using the
new commands mechanism that arrived in 3.4 - so i'm adding
CommandContributionItems to my menu bar.
I also have text editors in my app, and strangely, my undo/redo commands
are working for the text editors, but not for my custom editors. Anyone
any ideas?
Thanks!
Re: Undo/Redo with 3.4 Commands [message #480559 is a reply to message #480173] |
Mon, 17 August 2009 11:45   |
Rob wrote:
> Phillipus wrote:
>> Rob wrote:
>>> Hi all,
>>> operationHistory =
>>> actions like so:
>>> handlers for them)
>>> Thanks.
>> on my view:
>> @Override
>> // Undo / Redo
>> fUndoContext);
>> fUndoContext);
>> @Override
>> history
>> int limit = 500;
> any ideas?
> Thanks!
Still no progress made on this. Would anyone have any suggestions? I want
to keep undo/redo in my menu bar as command contributions and don't want
to revert back to Actions. It's still wierd that it works for a text
editor.
Rob
Re: Undo/Redo with 3.4 Commands [message #659241 is a reply to message #659225] |
Fri, 11 March 2011 10:56   |
Other results:
For demonstration, I'm working in a view.
I was about to do the stuff this way:
createPartControl(...) {
IAction undoAction = new Action() {
public void run() {
//do the undo operation
new UndoHandler().execute(null);
getViewSite().getActionBars().setGlobalActionHandler(ActionFactory.UNDO.getId(), undoAction);
This works but I'm not satistied as I need to write an IAction.
So, I tried the following:
final IHandlerService handlerService = (IHandlerService) getSite().getService(IHandlerService.class);
public void run() {
try {
handlerService.executeCommand("org.eclipse.ui.edit.undo", null);
} catch (Exception e) {
e.printStackTrace();
The result was a stackoverflow error as the retarget action recalls my action!
So, I tried:
public void run() {
try {
handlerService.activateHandler("org.eclipse.ui.edit.undo", new UndoHandler());
This works !
So, just for the fun, I tried something simpler:
I don't understand why but this works as well: the undo items in the menu contributions become available and work fine!
Re: Undo/Redo with 3.4 Commands [message #661418 is a reply to message #659241] |
Thu, 24 March 2011 11:23   |
You may get more response if you ask on the eclipse.platform newsgroup, as
all of the types that you mention live above the level of swt.
Grant
"Mathieu Garcia" <matg22@gmail.com> wrote in message
news:ildg9s$1f9$1@news.eclipse.org...
> Other results:
> @Override
> public void run() {
> getViewSite().getActionBars().setGlobalActionHandler(ActionF actory.UNDO.getId(),
> undoAction);
> @Override
> public void run() {
> try {
> undoAction);
> action!
> So, I tried:
> @Override
> public void run() {
> try {
> UndoHandler());
> undoAction);
> This works !
> UndoHandler());
Re: Undo/Redo with 3.4 Commands [message #700406 is a reply to message #661418] |
Sat, 23 July 2011 07:07  |
Hey Mathieu,
Thanks that you kept your answers and findings up to date. I am currently facing the same problem. I am not having issues with cut copy paste, but undo and redo is just not working. Same story with the save command. On which application is your RCP based. mine is based on the "org.eclipse.ui.ide.workbench".
http://www.eclipse.org/forums/index.php/t/222670/
Still i have no answers at all. Can you remeber where you found the part that your ahndlers were overwritten again with the actions?
Cheers
Phil
Current Time: Sat Jul 26 03:17:33 EDT 2025
Powered by FUDForum. Page generated in 0.05835 seconds
