Home » Modeling » EMF » Avoiding xsi:type in instance serializations with no target namespace in schema
Avoiding xsi:type in instance serializations with no target namespace in schema [message #659096] Thu, 10 March 2011 18:22 Go to next message
We have a requirement to not have any namespace pollution in the
instance serializations. I got the example from Ed's blog
http://ed-merks.blogspot.com/2007_12_01_archive.html to work with a
targetNamespace specified in the schema. However, when there is no
targetNamespace, the elements under the root are serialized fine without
the namespace, but all the other elements have the xsi:types.
e.g.
<fileSystem xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:noNamespaceSchemaLocation="http://www.example.com/resource">
<folder name="folder1">
<member xsi:type="File" name="file1"/>
<member xsi:type="Folder" name="nestedFolder"/>
</folder>
</fileSystem>
I am new to EMF, so was wondering if it is possible at all to avoid the
xsi:type for all the elements?
Nalini.
Re: Avoiding xsi:type in instance serializations with no target namespace in schema [message #659097 is a reply to message #659096] Thu, 10 March 2011 18:29 Go to previous messageGo to next message
Nalini,
Comments below.
Pollution. :-P
> without the namespace, but all the other elements have the xsi:types.
> e.g.
> </folder>
> </fileSystem>
> the xsi:type for all the elements?
Only by avoiding subclassing or with the use of substitution groups, but
I think you found that blog. You're saying it's not working for
non-namespace schemas? You're sure you're using this option for save?
result.getDefaultSaveOptions().put
(XMLResource.OPTION_ELEMENT_HANDLER,
new ElementHandlerImpl(false));
> Nalini.
Re: Avoiding xsi:type in instance serializations with no target namespace in schema [message #659100 is a reply to message #659097] Thu, 10 March 2011 19:44 Go to previous messageGo to next message
On 3/10/2011 3:29 PM, Ed Merks wrote:
> Nalini,
> Comments below.
> Pollution. :-P
>> e.g.
>> <?xml version="1.0" encoding="UTF-8"?>
>> </folder>
>> </fileSystem>
> (XMLResource.OPTION_ELEMENT_HANDLER, new ElementHandlerImpl(false));
Yes, I am using the options XMLResource.OPTION_ELEMENT_HANDLER for save.
I tried a couple of things, I just added ExtendedMetadata entry
qualified=true on the ecore generated while generating the model from
the schema. And then used this ecore to reload the model. This resulted
in the xsi:type for all the elements under the root.
The next time, I removed the targetNamespace from the resource example
xsd itself and all references to resource to generate the model. That
also had the xsi:type for the elements not under the root.
We may not be able to avoid the subclassing, so will be using
substitution groups. So, you think what was outlined in the blog should
work for non-namespace schemas too?
Nalini.
Re: Avoiding xsi:type in instance serializations with no target namespace in schema [message #659101 is a reply to message #659100] Thu, 10 March 2011 20:13 Go to previous messageGo to next message
Nalini,
I think it should work, but I haven't tried. It would be a bug if it
doesn't...
>> Nalini,
>> Comments below.
>> Pollution. :-P
>>> e.g.
>>> </folder>
>>> </fileSystem>
> resulted in the xsi:type for all the elements under the root.
> should work for non-namespace schemas too?
> Nalini.
Re: Avoiding xsi:type in instance serializations with no target namespace in schema [message #659599 is a reply to message #659101] Mon, 14 March 2011 14:35 Go to previous message
Ed, I have filed https://bugs.eclipse.org/bugs/show_bug.cgi?id=339935 as
this does not work for me.
It looks like the bug is in the BasicExtendedMetadata class where the
substitution group does not seem to get resolved when there is no
namespace. I have just started debugging this to see if I can workaround
this issue, but was wondering if you have any tips for workarounds here.
Nalini.
On 3/10/2011 5:13 PM, Ed Merks wrote:
> Nalini,
> doesn't...
>>> Nalini,
>>> Comments below.
>>> Pollution. :-P
>>>> e.g.
>>>> </folder>
>>>> </fileSystem>
>> Thanks,
>> Nalini.
Previous Topic:[CDO/Teneo] Data type error with H2 support
Next Topic:How to: Ecore Diagram for EMF
Current Time: Sun Jul 27 13:03:02 EDT 2025
Powered by FUDForum. Page generated in 0.05094 seconds
