Home » Archived » BIRT » BIRT Output horizontally(BIRT Output horizontally)
BIRT Output horizontally [message #555189] Wed, 25 August 2010 14:27 Go to next message
Question : I want the data to be in a horizontal format in Eclipse BIRT Report.
Ex: Names
Rai
Jones
Barnes
But I want this data to be in a horizontal manner like below.
Desired output : Rai Jones Barnes
Please Help me out.
Re: BIRT Output horizontally [message #555246 is a reply to message #555189] Thu, 26 August 2010 00:19 Go to previous messageGo to next message
Usually we use a crosstab item for this. Just create a simple cube with
only one group and no measures and drag the group on to the xtab column
header. See attached.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.21"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.5.2.v20100208 Build &lt;2.5.2.v20100210-0630></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<property name="imageDPI">96</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="7">
<text-property name="displayName"></text-property>
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
<property name="OdaConnProfileName"></property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set" id="8">
<list-property name="columnHints">
<structure>
<property name="columnName">ORDERNUMBER</property>
<text-property
name="displayName">ORDERNUMBER</text-property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ORDERNUMBER</property>
<property name="dataType">integer</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">ORDERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select ordernumber
from orders
where ordernumber < 10104]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>ORDERNUMBER</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
</design:resultSetColumns>
<design:criteria/>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
</data-sets>
<cubes>
<tabular-cube name="Data Cube" id="20">
<property name="dimensions">
<tabular-dimension name="Group" id="30">
<property
name="defaultHierarchy">NewTabularHierarchy</property>
<property name="hierarchies">
<tabular-hierarchy name="NewTabularHierarchy"
id="31">
<property name="levels">
<tabular-level name="ORDERNUMBER" id="32">
<property
<property
</tabular-level>
</property>
</tabular-hierarchy>
</property>
</tabular-dimension>
</property>
<property name="measureGroups">
<tabular-measure-group name="Summary Field" id="21"/>
</property>
<property name="dataSet">Data Set</property>
</tabular-cube>
</cubes>
<styles>
<style name="report" id="4">
<property name="fontFamily">sans-serif</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab-cell" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="6">
</style>
<style name="NewStyle" id="19">
<property name="display">inline</property>
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="45">
<list-property name="boundDataColumns">
<structure>
<text-property
<expression name="expression"
type="javascript">dataSetRow["ORDERNUMBER"]</expression >
</structure>
</list-property>
<column id="54"/>
<header>
<row id="46">
<cell id="47">
<label id="48">
<text-property
name="text">ORDERNUMBER</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="49">
<cell id="50">
<data id="51">
<property
name="resultSetColumn">ORDERNUMBER</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="52">
<cell id="53"/>
</row>
</footer>
</table>
<extended-item extensionName="Crosstab"
extensionVersion="2.5.0" id="33">
<property name="rows">
<extended-item extensionName="CrosstabView" id="35"/>
</property>
<property name="columns">
<extended-item extensionName="CrosstabView" id="40">
<property name="views">
<extended-item extensionName="DimensionView"
id="41">
<property name="dimension">Group</property>
<extended-item
extensionName="LevelView" name="NewLevel View" id="42">
<property
name="level">Group/ORDERNUMBER</property>
<property name="member">
<extended-item
extensionName="CrosstabCell" id="43">
<property name="content">
<data
name="ORDERNUMBER" id="44">
<property
</data>
</property>
<property
name="width">1.6770833333333333in</property>
</extended-item>
</property>
</extended-item>
</property>
</extended-item>
</property>
</extended-item>
</property>
<property name="header">
<extended-item extensionName="CrosstabCell" id="34">
<property name="width">0.11458333333333333in</property>
</extended-item>
</property>
<property name="cube">Data Cube</property>
<structure>
<expression
name="expression">dimension["Group"]["ORDERNUMBER"]</expression >
</structure>
</list-property>
</extended-item>
</body>
</report>
On 8/25/2010 2:27 PM, Veena wrote:
> Report.
> Ex: Names
> Rai
> Jones
> Barnes
> Please Help me out.
Re: BIRT Output horizontally [message #658819 is a reply to message #555246] Wed, 09 March 2011 17:14 Go to previous messageGo to next message
How can this work for large amounts of data? Can it be made to wrap by
every x columns?
Here is the scenario, we have a header detail report. For an example,
take like a grade report. Is that possible?
Header
Detail
CLASS CLASS CLASS CLASS
SEMESTER SEMESTER SEMESTER SEMESTER
GRADE GRADE GRADE GRADE
> Jason
> id="1">
> <property name="createdBy">Eclipse BIRT Designer Version 2.5.2.v20100208
> <data-sources>
> <oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc"
> name="Data Source" id="7">
> <property
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> <text-property name="displayName">ORDERNUMBER</text-property>
> </structure>
> </list-property>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> </list-property>
> from orders
> <xml-property name="designerValues"><![CDATA[<?xml version="1.0"
> encoding="UTF-8"?>
> <model:DesignValues
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:criteria/>
> </oda-data-set>
> </data-sets>
> <cubes>
> <property name="defaultHierarchy">NewTabularHierarchy</property>
> <tabular-hierarchy name="NewTabularHierarchy" id="31">
> </tabular-level>
> </property>
> </property>
> </property>
> </property>
> </tabular-cube>
> </cubes>
> <styles>
> </style>
> </style>
> </style>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> <text-property name="content"><![CDATA[<value-of>new
> </text>
> </page-footer>
> </page-setup>
> <body>
> <table id="45">
> <structure>
> </structure>
> </list-property>
> <column id="54"/>
> <header>
> <row id="46">
> <cell id="47">
> <label id="48">
> <text-property name="text">ORDERNUMBER</text-property>
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="49">
> <cell id="50">
> <data id="51">
> <property name="resultSetColumn">ORDERNUMBER</property>
> </data>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="52">
> <cell id="53"/>
> </row>
> </footer>
> </table>
> <extended-item extensionName="Crosstab" extensionVersion="2.5.0" id="33">
> </property>
> <extended-item extensionName="DimensionView" id="41">
> <extended-item extensionName="LevelView" name="NewLevel View" id="42">
> <property name="level">Group/ORDERNUMBER</property>
> <extended-item extensionName="CrosstabCell" id="43">
> <data name="ORDERNUMBER" id="44">
> </data>
> </property>
> <property name="width">1.6770833333333333in</property>
> </extended-item>
> </property>
> </extended-item>
> </property>
> </extended-item>
> </property>
> </extended-item>
> </property>
> </extended-item>
> </property>
> <structure>
> <expression
> </structure>
> </list-property>
> </extended-item>
> </body>
> </report>
>> Hi,
>> Report.
>> Ex: Names
>> Rai
>> Jones
>> Barnes
>> Please Help me out.
Re: BIRT Output horizontally [message #658998 is a reply to message #658819] Thu, 10 March 2011 11:09 Go to previous message
A crosstab can be made to page break every x number of columns, but that
does not sound like what you want. In your case I would add multiple
tables tied to the same dataset and filter on row number. Add a
computed column to the dataset that does a running count to get a row
number you can filter on. To see an example of this look at the
attached report that has a grid with two columns. In each column is a
table. One table is filtered to show odd rownum and the other is
filtered to show even.
In your case I would also add two more details rows for a total of 3 one
for class, one for semester and the last for grade.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.22"
id="1">
<property name="comments">Copyright (c) 2007 &lt;&lt;Your Company
Name here>></property>
2.6.1.v20100902 Build &lt;2.6.1.v20100915-1750></property>
<html-property name="description">Creates a blank report with no
predefined content.</html-property>
<text-property name="displayName">Blank Report</text-property>
<property name="layoutPreference">auto layout</property>
<data-sources>
<oda-data-source
id="6">
<property
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
name="Data Set" id="7">
<list-property name="computedColumns">
<structure>
<property name="name">rwc</property>
<expression
name="expression">row["ORDERNUMBER"]</expression>
<property
name="aggregateFunction">RUNNINGCOUNT</property>
</structure>
</list-property>
<structure>
<text-property
</structure>
<structure>
<property name="columnName">PRODUCTCODE</property>
<text-property
name="displayName">PRODUCTCODE</text-property>
</structure>
<structure>
<property name="columnName">QUANTITYORDERED</property>
<text-property
name="displayName">QUANTITYORDERED</text-property>
</structure>
<structure>
<property name="columnName">PRICEEACH</property>
<text-property
name="displayName">PRICEEACH</text-property>
</structure>
<structure>
<property name="columnName">ORDERLINENUMBER</property>
<text-property
name="displayName">ORDERLINENUMBER</text-property>
</structure>
</list-property>
<structure>
</structure>
<structure>
<property name="position">2</property>
<property name="name">PRODUCTCODE</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">PRICEEACH</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">ORDERLINENUMBER</property>
</structure>
<structure>
<property name="position">6</property>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">ORDERLINENUMBER</property>
<property name="nativeDataType">5</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select *
from orderdetails]]></xml-property>
<model:DesignValues
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:name>PRODUCTCODE</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>PRODUCTCODE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRODUCTCODE</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>QUANTITYORDERED</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>QUANTITYORDERED</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>QUANTITYORDERED</design:label>
<design:attributes>
<design:name>PRICEEACH</design:name>
<design:position>4</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>PRICEEACH</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRICEEACH</design:label>
<design:displaySize>22</design:displaySize>
<design:attributes>
<design:name>ORDERLINENUMBER</design:name>
<design:position>5</design:position>
<design:nativeDataTypeCode>5</design:nativeDataTypeCode>
<design:precision>5</design:precision>
<design:uiHints>
<design:displayName>ORDERLINENUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERLINENUMBER</design:label>
<design:displaySize>6</design:displaySize>
</oda-data-set>
</data-sets>
<styles>
<style name="crosstab" id="4">
</style>
</style>
</styles>
<page-setup>
<property name="topMargin">1in</property>
<property name="leftMargin">1.25in</property>
<property name="bottomMargin">1in</property>
<property name="rightMargin">1.25in</property>
<page-footer>
<text id="3">
<text-property
</text>
</page-footer>
</page-setup>
<body>
<grid id="42">
<property name="width">100%</property>
<column id="43"/>
<column id="44"/>
<row id="45">
<cell id="46">
<table id="8">
<structure>
<property
<expression
name="expression">dataSetRow["ORDERNUMBER"]</expression >
<property
</structure>
<structure>
<property
<expression
name="expression">dataSetRow["PRODUCTCODE"]</expression >
</structure>
<structure>
<property
<expression
name="expression">dataSetRow["QUANTITYORDERED"]</expression >
<property
</structure>
<structure>
<expression
name="expression">dataSetRow["PRICEEACH"]</expression>
</structure>
<structure>
<property
<expression
name="expression">dataSetRow["ORDERLINENUMBER"]</expression >
<property
</structure>
<structure>
<property name="name">Column
Binding</property>
<expression
name="expression">row.__rownum</expression>
<property name="dataType">any</property>
</structure>
<structure>
<expression
name="expression">dataSetRow["rwc"]</expression>
<property
</structure>
</list-property>
<property name="pageBreakInterval">50</property>
<list-property name="filter">
<structure>
<property name="operator">ne</property>
<expression
name="expr">row["rwc"]%2</expression>
<simple-property-list name="value1">
<value>0</value>
</simple-property-list>
</structure>
</list-property>
<column id="51"/>
<column id="37"/>
<column id="39"/>
<header>
<row id="9">
<cell id="48">
<label id="53">
<text-property
name="text">Computed row count</text-property>
</label>
</cell>
<cell id="10">
<label id="11">
<text-property
</label>
</cell>
<cell id="14">
<label id="15">
<text-property
name="text">QUANTITYORDERED</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="20">
<cell id="49">
<data id="54">
<property
name="resultSetColumn">rwc</property>
</data>
</cell>
<cell id="21">
<data id="22">
<property
</data>
</cell>
<cell id="25">
<data id="26">
<property
name="resultSetColumn">QUANTITYORDERED</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="31">
<cell id="50"/>
<cell id="32"/>
<cell id="34"/>
</row>
</footer>
</table>
</cell>
<cell id="47">
<table id="55">
<structure>
<property
<expression
<property
</structure>
<structure>
<property
<expression
</structure>
<structure>
<property
<expression
<property
</structure>
<structure>
<expression
</structure>
<structure>
<property
<expression
<property
</structure>
<structure>
Binding</property>
<expression
</structure>
<structure>
<expression
<property
</structure>
</list-property>
<structure>
<property name="operator">eq</property>
<expression
<value>0</value>
</structure>
</list-property>
<column id="74"/>
<column id="75"/>
<column id="76"/>
<header>
<row id="56">
<cell id="57">
<label id="77">
<text-property
</label>
</cell>
<cell id="59">
<label id="60">
<text-property
</label>
</cell>
<cell id="61">
<label id="62">
<text-property
</label>
</cell>
</row>
</header>
<detail>
<row id="63">
<cell id="64">
<data id="65">
<property
</data>
</cell>
<cell id="66">
<data id="67">
<property
</data>
</cell>
<cell id="68">
<data id="69">
<property
</data>
</cell>
</row>
</detail>
<footer>
<row id="70">
<cell id="71"/>
<cell id="72"/>
<cell id="73"/>
</row>
</footer>
</table>
</cell>
</row>
</grid>
</body>
</report>
> every x columns?
> Header
> Detail
>> Jason
>> <?xml version="1.0" encoding="UTF-8"?>
>> id="1">
>> <data-sources>
>> <property
>> </oda-data-source>
>> </data-sources>
>> <data-sets>
>> <oda-data-set
>> <structure>
>> </structure>
>> </list-property>
>> <structure>
>> </structure>
>> </list-property>
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> from orders
>> encoding="UTF-8"?>
>> <model:DesignValues
>> <design:attributes>
>> <design:uiHints>
>> </design:uiHints>
>> <design:usageHints>
>> <design:criteria/>
>> </oda-data-set>
>> </data-sets>
>> <cubes>
>> </tabular-level>
>> </property>
>> </property>
>> </property>
>> </property>
>> </tabular-cube>
>> </cubes>
>> <styles>
>> </style>
>> </style>
>> </style>
>> </style>
>> </styles>
>> <page-setup>
>> <page-footer>
>> <text id="3">
>> </text>
>> </page-footer>
>> </page-setup>
>> <body>
>> <table id="45">
>> <structure>
>> </structure>
>> </list-property>
>> <column id="54"/>
>> <header>
>> <row id="46">
>> <cell id="47">
>> <label id="48">
>> </label>
>> </cell>
>> </row>
>> </header>
>> <detail>
>> <row id="49">
>> <cell id="50">
>> <data id="51">
>> </data>
>> </cell>
>> </row>
>> </detail>
>> <footer>
>> <row id="52">
>> <cell id="53"/>
>> </row>
>> </footer>
>> </table>
>> </property>
>> </data>
>> </property>
>> </extended-item>
>> </property>
>> </extended-item>
>> </property>
>> </extended-item>
>> </property>
>> </extended-item>
>> </property>
>> </extended-item>
>> </property>
>> <structure>
>> <expression
>> </structure>
>> </list-property>
>> </extended-item>
>> </body>
>> </report>
>>> Hi,
>>> Report.
>>> Ex: Names
>>> Rai
>>> Jones
>>> Barnes
>>> Please Help me out.
Previous Topic:PDF and image
Next Topic:Removing margin (whitespace) between table cells
Current Time: Thu Jul 24 22:35:13 EDT 2025
Powered by FUDForum. Page generated in 0.04184 seconds
