Problem with multiple projects sharing a repository. [message #658855] |
Thu, 10 March 2011 00:06  |
I have multiple projects (A, B, C) that share the same git repository. Each project has a build path link to the same java source directory, and declare different inclusion patterns (e.g., **/client/**, **/server/**, "**/shared/**").
The projects also have (acyclic) dependencies: e.g., A -> B and B -> C.
The problem is when I modify a file and commit, the file shows up multiple times in the commit dialog. E.g.,
A/java/Foo.java
B/java/Foo.java
C/java/Foo.java
java/Foo.java
E.g., each project seems to think it has a subdirectory "java" due to the shared source folder on the build path.
is there a better way to structure projects with a shared source tree and dependencies?
RB
FUDForum. Page generated in 0.99594 seconds
