Home » Modeling » GMF (Graphical Modeling Framework) » OutlineView: 2 TreeEditParts -> 1 Model
OutlineView: 2 TreeEditParts -> 1 Model [message #658821] Wed, 09 March 2011 17:28 Go to next message
I have implemented an OutlineView, that has 2 TreeEditParts(TEP) for one EditPart in Editor(2 TEP for one Model) and i have a problem with this, because if I select one of these TEP it jumps to another.
I understand the reason of that, but i can't fix it. Can somebody help me?
My opinion for the reason is a selection process in GMF:
if I select first TEP than it's selects corresponding object in editor, and than this object sends back select notification event to outlineview to second editpart, therefore it jumps.
Re: OutlineView: 2 TreeEditParts -> 1 Model [message #658873 is a reply to message #658821] Thu, 10 March 2011 03:26 Go to previous messageGo to next message
The DiagramEditor has a selection synchronizer. by default, it would
have the treeeditpart and the Diagramedit part added to the
synchronizer. It also allows, some customization. Have a look at it.
you can get it with getSelectionSynchronizer() in the editor.
Cheers Christophe
Re: OutlineView: 2 TreeEditParts -> 1 Model [message #658910 is a reply to message #658821] Thu, 10 March 2011 07:25 Go to previous messageGo to next message
Thanks for the reply,
I have already tried to customize SelectionSynchronizer(method convert), but unsuccessful.
Which ideas do you have to prevent this problem?
Re: OutlineView: 2 TreeEditParts -> 1 Model [message #658926 is a reply to message #658910] Thu, 10 March 2011 07:57 Go to previous messageGo to next message
> but unsuccessful.
One idea, would be to disable the synchronizer first (Extend it, and
make sure it doesn't call super.selectionChanged(...). Than you would
whatever you deem necessary for your app.
Another idea, is to add your 2nd TEP to the synchronizer .addView() method.
Re: OutlineView: 2 TreeEditParts -> 1 Model [message #660588 is a reply to message #658926] Sat, 19 March 2011 13:10 Go to previous messageGo to next message
Thanks, i have found a solution Smile
Re: OutlineView: 2 TreeEditParts -> 1 Model [message #660651 is a reply to message #660588] Sun, 20 March 2011 12:41 Go to previous messageGo to next message
On 19-03-11 10:10, Artjom wrote:
> Thanks, i have found a solution :)
Could you please share it with the forum? Thx
Re: OutlineView: 2 TreeEditParts -> 1 Model [message #660716 is a reply to message #660651] Mon, 21 March 2011 07:27 Go to previous message
I faced the same problem with outline view.
Solution I followed is ..
extend the SelectionSynchronizer and override the selectionChanged(SelectionChangedEvent event) method to do synchronization for all other editparts except my implementations.
Previous Topic:ToolBarManager: remove subItem
Next Topic:Manipulate Notational Model on Element Creation
Current Time: Wed Jul 30 21:31:33 EDT 2025
Powered by FUDForum. Page generated in 0.04813 seconds
