Home » Modeling » EMF » Tracking Notification in the Model
Tracking Notification in the Model [message #658484] |
Tue, 08 March 2011 12:20  |
I need to receive any notification in the model to track changes in the infromation and report them. The Edit framework is not good for me because the model is not going to use any GUI but send data updates over the network. After searching a lot i found and old post (2002) on this talking about a SelfInstallingAdapter. I modify that and updated to the code below.
However i would appreciate if somebody could indicate me whether there is another more efficient way of doing this.
Javi
public abstract class AbstractEObjectNotificationTracker {
protected EObject trackedObject = null;
protected SelfInstallingAdapter adapter = new SelfInstallingAdapter();
abstract protected void process(Notification notification);
abstract protected void doAdapterRemovedFromObject(EObject eObject);
abstract protected void doAdapterAddedToObject(EObject eObject);
public void track(EObject eObject){
if ( trackedObject != null ){
trackedObject.eAdapters().remove(adapter);
doAdapterRemovedFromObject(trackedObject);
removeTrackingOfContents(trackedObject);
trackedObject = eObject;
if ( trackedObject != null){
eObject.eAdapters().add(adapter);
doAdapterAddedToObject(eObject);
addTrackingOfContents(eObject);
protected void addTrackingOfContents(EObject eObject){
EObject containedObject;
for (TreeIterator<EObject> i = EcoreUtil.getAllProperContents(eObject,false); i.hasNext(); )
containedObject = i.next();
containedObject.eAdapters().add(adapter);
doAdapterAddedToObject(containedObject);
protected void removeTrackingOfContents(EObject eObject){
containedObject.eAdapters().remove(adapter);
doAdapterRemovedFromObject(containedObject);
private class SelfInstallingAdapter extends AdapterImpl{
public void notifyChanged(Notification notification)
super.notifyChanged(notification);
selfAdapt(notification);
process(notification);
protected void selfAdapt(Notification notification)
Object notifier = notification.getNotifier();
if (notifier instanceof EObject)
Object feature = notification.getFeature();
if (feature instanceof EReference && ((EReference)feature).isContainment())
handleContainment(notification);
protected void handleContainment(Notification notification)
switch (notification.getEventType())
case Notification.SET:
case Notification.UNSET:
EObject oldValue = JavaUtil.<EObject>cast(notification.getOldValue());
if (oldValue != null)
System.err.println("Remove Adapter: " + oldValue);
oldValue.eAdapters().remove(this);
doAdapterRemovedFromObject(oldValue);
removeTrackingOfContents(oldValue);
EObject newValue = JavaUtil.<EObject>cast(notification.getNewValue());
if (newValue != null)
System.err.println("Add Adapter: " + newValue);
newValue.eAdapters().add(this);
doAdapterAddedToObject(newValue);
addTrackingOfContents(newValue);
break;
case Notification.ADD:
break;
case Notification.ADD_MANY:
EObject newValue;
Collection newValues = (Collection)notification.getNewValue();
for (Iterator i = newValues.iterator(); i.hasNext(); )
newValue = JavaUtil.<EObject>cast(i.next());
break;
case Notification.REMOVE:
break;
case Notification.REMOVE_MANY:
EObject oldValue;
Collection oldValues = (Collection)notification.getOldValue();
for (Iterator i = oldValues.iterator(); i.hasNext(); )
oldValue = JavaUtil.<EObject>cast(i.next());
System.err.println("Add Adapter: " + oldValue);
break;
public void setTarget(Notifier target)
System.err.println("Set Target: " + target);
Re: Tracking Notification in the Model [message #658530 is a reply to message #658494] |
Tue, 08 March 2011 15:43   |
Javi,
Comments below.
Xavipen wrote:
> Hi Ed,
> Quote:
>> Javi,
>> Comments below.
>> Xavipen wrote:
>> > Hi,
>> A ChangeRecorder might be perfect for that.
>> EContentAdapter and ChangeRecorders are good examples of this.
> I have just checked the code for EContentAdapter and I have one
> concern. Having the adding of contents in the setTarget causes
> repeated calls and the apdapter being added several times under
> certain circunstances (Because when adding the adapter setTarget is
> called again).
This is a theory you have? Indeed the adapter is added recursively, but
to the children, not more than once to the same object.
> That was the reason why i move it to a track method and left the
> setTarget method empty in my implementation. How is EContentAdapter
> dealing with it?
> (ChangeRecorders seems to be more for undo capabilities and i do not
> need it for now)
No, it's one of the uses. It's primarily for tracking what's changed
and for producing a description of what's changed. That description can
be applied to produce the changes being described (thereby supporting
undo/redo). I'm not sure what form you intend to "report" changes...
> Quote:
>> I'm working right now on updates to the change model so that it will be
>> possible to easily create a ChangeDescription that's a forward delta
>> which could be sent to a server to update a server-side instance of the
>> model to match exactly the client side updates. Is that ultimately what
>> you're after?
> This sounds very interesting, specilly when thinking about remoteGUI
> and is missing for the SOA i know.
> In my case, I do not know if i could apply it though. The class in the
> model are "processing" blocks rather than just data. And i do not want
> to mirror the processing but only to be able to monitor the
> configuration and stadistics of these "processing" blocks. Is it
> possible to define a sort of "ValueObject" like in SOA for and EMF
> model selecting a subset of the Attributes and operations they implement?
I'm not sure I understand. You might mark some features as transient
because you're not interest in them being persistent...
Re: Tracking Notification in the Model [message #658632 is a reply to message #658530] |
Wed, 09 March 2011 05:52   |
Quote: | Javi,
Comments below.
Xavipen wrote:
> Hi Ed,
> Quote:
>> Javi,
>> Comments below.
>> Xavipen wrote:
>> > Hi,
> called again).
That was a question. On the adapter in the forum the setTarget was iterating through all the contents (direct and indirect) of the Notifier, thus things where called twice. That was the reasoning for my question.
I went back to EContent Adapter code and run a couple of test. EContentAdapter only iteracts trough the "direct" contents of the notifier. So it works like a charm.
Quote: | > That was the reason why i move it to a track method and left the
> dealing with it?
> need it for now)
We will have a Data repository where different clients will be able to subcribe for different data acoording to there needs.
The EContentAdapter will be use to link the Model and the repo so the repo get's updated when the model changes. (publish, unpublish new data/objects, attributes updates...)
Quote: | >
> Quote:
>> you're after?
It is a bit dificult to explain in words. It is not related about the persistance. There is a beheiviour associated to the class (to simplify different classes will have a different internal thread transient,) Therefore when persisting the objects the beheiviour is also persisted and by modifying the objects in the model you can modify how the data needs to be process in realtime and also define differnet model for different beheiviours, etc...
The missing piece is how to get a remote GUI, (although is not the priority now) and the new feature you are working on could help in the monitoring part. The thing is that i would not like to have the beheiviour of the objects on the client (and having then running any thread there).
I hope this has clarify a bit what´s in my mind. I do not know enough about EMF yet and this was a bit of topic . In any case, one thing i know: The more i learn about the EMF the more i like it Thanks a lot!
Javi
[Updated on: Wed, 09 March 2011 05:54] by Moderator
Re: Tracking Notification in the Model [message #658737 is a reply to message #658632] |
Wed, 09 March 2011 11:06  |
Javi,
Comments below.
Xavipen wrote:
> Quote:
>> Ed Merks wrote on Tue, 08 March 2011 21:43
>> > Javi,
>> > > Comments below.
>> > > Xavipen wrote:
>> > > Hi Ed,
>> > > Quote:
>> > >> Javi,
>> > >> Comments below.
>> > >> Xavipen wrote:
>> > >> > Hi,
>> changes in
>> going
>> about a
>> below.
>> > > I have just checked the code for EContentAdapter and I have one >
>> > concern. Having the adding of contents in the setTarget causes > >
>> repeated calls and the apdapter being added several times under > >
>> certain circunstances (Because when adding the adapter setTarget is >
>> > called again). > This is a theory you have? Indeed the adapter is
>> added recursively, but > to the children, not more than once to the
>> same object.
>> That was a question. ;) On the adapter in the forum the setTarget was
>> my question.
>> notifier. So it works like a charm. :)
>> Quote:
>> EContentAdapter > > dealing with it?
>> not > > need it for now)
>> changed > and for producing a description of what's changed. That
>> description can > be applied to produce the changes being described
>> (thereby supporting > undo/redo). I'm not sure what form you intend
>> Quote:
>> > > Quote:
>> whether there
>> will be
>> delta
>> of the
>> ultimately what
>> > >> you're after?
>> remoteGUI > > and is missing for the SOA i know.
>> in the > > model are "processing" blocks rather than just data. And i
>> do not want > > to mirror the processing but only to be able to
>> monitor the > > configuration and stadistics of these "processing"
>> blocks. Is it > > possible to define a sort of "ValueObject" like in
>> SOA for and EMF > > model selecting a subset of the Attributes and
>> transient > because you're not interest in them being persistent...
I guess the use of the word behavior doesn't help me because I think of
behavior as invoking EOperations.
> monitoring part.
CDO is awfully helpful with remote GUIs as well, though your scenario
sounds a little "special".
> about EMF yet and this was a bit of topic :) . In any case, one thing
> i know: The more i learn about the EMF the more i like it :)
> Thanks a lot!
> Javi
Current Time: Wed Jul 23 23:04:06 EDT 2025
Powered by FUDForum. Page generated in 0.05508 seconds
