OCLInvalid Error [message #658697] |
Wed, 09 March 2011 08:56  |
Hello every body here,
I have just a question , you can note it from the two Ocl expressions:
First One:
Association.allInstances()-> select(asso:Association|(asso.name.substring(1,9)='DR!{Hamad ') )
Results:
<<evlvAddDomainAssociation, evlvRenamedAssociation>> <Association> DR!{Hamada, Ramada}HO!{Hima, barhoom}
the second one:
Association.allInstances()-> select(asso:Association|(asso.name.substring(1,(10))='DR!{Ha mada') )
Results:
OclInvalid
The question is what is the problem with there in the second OCL constraint?
best regards to all of you.
Re: OCLInvalid Error [message #658764 is a reply to message #658762] |
Wed, 09 March 2011 12:35   |
Hello All,
Thanks for the reply ,
but I still have the same problem, whenever I use number >9 it gives me the same invalid .
Results:
the second one:
Association.allInstances()-> select(asso:Association|(asso.name.substring(1,10)='DR!{Hama da, Ramada}HO!{Hima') )
Results:
OclInvalid
So what is the problem now,? do not care about the blank , it occurs just here in this text ,
Thanx for your help,
Re: OCLInvalid Error [message #658768 is a reply to message #658764] |
Wed, 09 March 2011 12:50   |
Note that the substring selection is within a select, so if ANY
Association has less than 9/10 charcters you will get invalid.
Ed Willink
On 09/03/2011 17:35, Hussam wrote:
> Hello All,
> Results:
> the second one:
> Ramada}HO!{Hima') )
> Results:
> OclInvalid
> Regards
Re: OCLInvalid Error [message #658782 is a reply to message #658771] |
Wed, 09 March 2011 13:32  |
Hi Hussam
In the same way as Java.
Guard an access to an invalid index with a bounds check.
Ed Willink
On 09/03/2011 18:16, Hussam wrote:
> Thanx ED Willink,
> I think you got what I want to do,
> I need to query some association according to substring, how to do
> that out of the select statement?
> Regards
FUDForum. Page generated in 0.04804 seconds
