Home » Eclipse Projects » Memory Analyzer » ClassLoader analysis and IBM .phd files(ClassLoader analysis seems broken in MAT 1.0.1 for .phd files)
ClassLoader analysis and IBM .phd files [message #658673] Wed, 09 March 2011 07:55 Go to next message
I am trying to analyse a .phd file created by a 32 bit Windows IBM Java 5 JVM.
The ClassLoader analysis doesn't seem to work - every class seems to be owned by a single system classloader.
I did see a bug report
https://bugs.eclipse.org/bugs/show_bug.cgi?format=multiple&a mp;id=267592
that fixes a NullPointerException for this case, and presumably 1.0.1 already has that fix, but the analysis itself doesn't work.
Are there any plans to fix it or am I just not using the feature correctly?
jon.
Re: ClassLoader analysis and IBM .phd files [message #658722 is a reply to message #658673] Wed, 09 March 2011 10:49 Go to previous messageGo to next message
Which JVM version generated the dump?
Window > Heap Dump Details > JVM Version
Some older JVM versions don't generate class loader information in the PHD file, so MAT can't display useful class loader information.
Try putting the javacore.txt file in the same directory as the heapdump.phd file, delete the index files and reparse the dump. The javacore file does contain some class loader information and this might be enough for the DTFJ/PHD reader to find out the class loaders.
Re: ClassLoader analysis and IBM .phd files [message #658840 is a reply to message #658722] Wed, 09 March 2011 19:54 Go to previous message
Andrew,
Thanks. This worked. I didn't have a javacore from exactly the same time as the heapdump, but I had one from a few minutes before. I renamed it to have the same name pattern as the .phd file, and this worked.
For the record the JVM I was using was:
J2RE 5.0 IBM J9 2.3 Windows XP x86-32 build j9vmwi3223ifx-20080811
VM build 20080809_21892_iHdsMr
JIT enabled - 20080620_1845_r8
jon.
Previous Topic:What's the best way to package and share OQL queries
Next Topic:Remainder sector is very big
Current Time: Tue Jul 22 02:18:15 EDT 2025
Powered by FUDForum. Page generated in 0.03865 seconds
