Home » Archived » M2M (model-to-model transformation) » [Xtend] Creation of associations (ClassCastException)([Xtend] Creation of associations (ClassCastException))
[Xtend] Creation of associations (ClassCastException) [message #658499] |
Tue, 08 March 2011 13:21  |
I have problems with creating associations (below association between OneToOneArc and BatchJob). "BatchJob" is contained by an EClass named "BatchStream".
create mmBatch::OneToOneArc createJobOne2OneCond(mmBatch::BatchJob jobTarget, mmBatch::BatchJob jobSource) :
this.setPredecessor(jobSource) ->
this.setSuccessor(jobTarget) ->
this.setName(jobSource.name + "->" + jobTarget.name)
I am getting following error in my workflow during writing the xmi file by org.eclipse.mwe.emf.Writer:
1032 ERROR WorkflowRunner - java.lang.String incompatible with org.eclipse.emf.ecore.util.FeatureMap
java.lang.ClassCastException: java.lang.String incompatible with org.eclipse.emf.ecore.util.FeatureMap
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eURIFragmentSegm ent(BasicEObjectImpl.java:302)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.getURIFragm ent(ResourceImpl.java:678)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.getURIFragmen t(XMLResourceImpl.java:423)
at org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.getURIFragment( XMLHelperImpl.java:718)
Do I have to implement associations in a different way (like cloning BatchJob parameters)? I really appreciate any kind of help.
Thank you,
Peter
Re: [Xtend] Creation of associations (ClassCastException) [message #659576 is a reply to message #659462] |
Mon, 14 March 2011 11:54   |
--------------090300060501080309070109
Peter,
At this line:
The code is walking the referenced objects
public String eURIFragmentSegment(EStructuralFeature
eStructuralFeature, EObject eObject)
if (eStructuralFeature == null)
for (@SuppressWarnings("unchecked")
EContentsEList.FeatureIterator<EObject> crossReferences =
(EContentsEList.FeatureIterator<EObject>)((InternalEList<? >)eCrossReferences()).basicIterator();
crossReferences.hasNext(); )
EObject crossReference = crossReferences.next();
if (crossReference == eObject)
eStructuralFeature = crossReferences.feature();
StringBuilder result = new StringBuilder();
result.append('@');
result.append(eStructuralFeature.getName());
if (eStructuralFeature instanceof EAttribute)
All the objects in the eCrossReferences() must be EObjects and they can
only be there by virtue of a EReference or an EAttribute that's a
feature map. So, what's an an EAttribute of type string doing there? If
you use the debugger the walk through the logic, you should be able to
discover that somehow this code is returning a bad list.
public static <T> ECrossReferenceEList<T>
createECrossReferenceEList(EObject eObject)
EStructuralFeature [] eStructuralFeatures =
((EClassImpl.FeatureSubsetSupplier)eObject.eClass().getEAllS tructuralFeatures()).crossReferences();
You'll see that in EClassImpl
private void init()
BasicEList<EStructuralFeature> containmentsList = new
EStructuralFeatureUniqueEList();
BasicEList<EStructuralFeature> crossReferencesList = new
boolean isMixed =
"mixed".equals(EcoreUtil.getAnnotation(EClassImpl.this,
ExtendedMetaData.ANNOTATION_URI, "kind"));
for (int i = 0; i < size; ++i)
// Skip derived features.
EStructuralFeature eStructuralFeature =
(EStructuralFeature)data[i];
if (eStructuralFeature instanceof EReference)
EReference eReference = (EReference)eStructuralFeature;
if (eReference.isContainment())
if (!eReference.isDerived())
containmentsList.add(eReference);
else if (!eReference.isContainer())
// Include derived relations only if they won't also
come from mixed or a group.
if (!eReference.isDerived() ||
!isMixed &&
EcoreUtil.getAnnotation(eReference, ExtendedMetaData.ANNOTATION_URI,
"group") == null)
*crossReferencesList*.add(eReference);
else if (FeatureMapUtil.isFeatureMap(eStructuralFeature))
if (!eStructuralFeature.isDerived())
containmentsList.add(eStructuralFeature);
*crossReferencesList*.add(eStructuralFeature);
It should only be possible that EReferences and EAttributes that are
features maps are in the list of cross references...
In the end, you need to do the analysis...
Peter Sasse wrote:
> Hi Ed,
> thank you for your reply. In the last days I tried to figure out, what
> the problem is. May I ask you, when I cannot get a solution (what do
> you need for analysis)?
> Thank you & regards,
> Peter
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Peter,<br>
<br>
At this line:<br>
<blockquote>BasicEObjectImpl.java:302<br>
</blockquote>
<small><big>The code is walking the referenced objects </big></small><br>
<blockquote><small><br>
eStructuralFeature, EObject eObject)<br>
{<br>
if (eStructuralFeature == null)<br>
{<br>
EContentsEList.FeatureIterator<EObject> crossReferences = <br>
(EContentsEList.FeatureIterator<EObject>)((Int ernalEList<?>)eCrossReferences()).basicIterato r();
<br>
crossReferences.hasNext(); )<br>
{<br>
EObject crossReference = crossReferences.next();<br>
if (crossReference == eObject)<br>
{<br>
eStructuralFeature = crossReferences.feature();<br>
}<br>
}<br>
}<br>
<br>
StringBuilder result = new StringBuilder();<br>
result.append('@');<br>
result.append(eStructuralFeature.getName());<br>
<br>
if (eStructuralFeature instanceof EAttribute)<br>
{<br>
</small></blockquote>
If you use the debugger the walk through the logic, you should be able
to discover that somehow this code is returning a bad list.<br>
<br>
<small> public static <T> ECrossReferenceEList<T>
createECrossReferenceEList(EObject eObject)<br>
{<br>
EStructuralFeature [] eStructuralFeatures = <br>
((EClassImpl.FeatureSubsetSupplier)eObject.eClass().getEAllS tructuralFeatures()).crossReferences(); </small><br>
<br>
You'll see that in EClassImpl<br>
<br>
<blockquote><small> private void init()</small><br>
<small> {</small><br>
<small> BasicEList<EStructuralFeature>
containmentsList = new EStructuralFeatureUniqueEList();</small><br>
crossReferencesList = new EStructuralFeatureUniqueEList();</small><br>
<small> boolean isMixed =
ExtendedMetaData.ANNOTATION_URI, "kind"));</small><br>
<small> for (int i = 0; i < size; ++i)</small><br>
<small> // Skip derived features.</small><br>
<small> //</small><br>
<small> EStructuralFeature eStructuralFeature =
(EStructuralFeature)data[i];</small><br>
<small> if (eStructuralFeature instanceof EReference)</small><br>
<small> EReference eReference =
(EReference)eStructuralFeature;</small><br>
<small> if (eReference.isContainment())</small><br>
<small> if (!eReference.isDerived())</small><br>
<small> containmentsList.add(eReference);</small><br>
<small> }</small><br>
<small> else if (!eReference.isContainer())</small><br>
<small> // Include derived relations only if they
won't also come from mixed or a group.</small><br>
<small> if (!eReference.isDerived() || </small><br>
<small> !isMixed &&
"group") == null)</small><br>
<small> <b>crossReferencesList</b>.add(eReference);</small><br>
<small> else if
(FeatureMapUtil.isFeatureMap(eStructuralFeature))</small><br >
<small> if (!eStructuralFeature.isDerived())</small><br>
<small> containmentsList.add(eStructuralFeature);</small><br>
<small> <b>crossReferencesList</b>.add(eStructuralFeature);</small ><br>
</blockquote>
features maps are in the list of cross references...<br>
<br>
In the end, you need to do the analysis...<br>
<br>
<br>
Peter Sasse wrote:
<blockquote cite="mid:ilkflh$p23$1@news.eclipse.org" type="cite">Hi Ed,
<br>
<br>
<br>
<br>
<br>
Peter
<br>
</blockquote>
</body>
</html>
--------------090300060501080309070109--
Re: [Xtend] Creation of associations (ClassCastException) [message #660235 is a reply to message #659863] |
Thu, 17 March 2011 10:08   |
Hi Ed,
first regarding your questions:
> Have these models been changing to add features?
> Have a look at what happens in eBasicSetContainer when you add it to the
> containment reference. The feature ID there should be -1 - <the feature
> of the containment reference in the parent class>.
> Are all these classes in the same package or is it possible some are in
> a base package and derived classes in another package need to be
> regenerated?
All mentioned classes are in the same package. But I am using two ecores. One model is from that type used to be read from, one model is from that type used to be read and merged the content of the first model into it. The feature ID of the model (first ecore) is other than -1, the feature IDs of the merged model (second ecore) is equal to -1.
Thus I found the bug, that creating the BatchStream aggregations into BatchNets won't set the object at the opposite role for BatchStream. I saw, that traversing to BatchStream and back to BatchNet returns null. Now explicite setting of the object at the opposite role (BatchNet) inside object of type BatchStream leads to following exception:
EvaluationException : The value of type 'org.eclipse.emf.ecore.impl.EClassImpl@4c594c59 (name: BatchNet)...' must be of type 'org.eclipse.emf.ecore.impl.EClassImpl@25d625d6 (name: BatchNet) ...'
Is above issue related to http://www.openarchitectureware.org/forum/viewtopic.php?foru m=2&showtopic=11530, or is following opposite setting wrong?
create mmBatch::BatchStream createCtmStream(mmCtm::SCHED_GROUP ctmSchedTable, mmBatch::BatchNet net) : ... -> this.setBatchnet(net);
Thank you & kind regards,
Peter
[Updated on: Thu, 17 March 2011 10:09] by Moderator
Re: [Xtend] Creation of associations (ClassCastException) [message #660286 is a reply to message #660235] |
Thu, 17 March 2011 11:35   |
--------------000706030202030905090506
Peter,
Comments below.
Peter Sasse wrote:
> Hi Ed,
>> Have these models been changing to add features? Have a look at what
>> happens in eBasicSetContainer when you add it to the containment
>> reference. The feature ID there should be -1 - <the feature of the
>> in a base package and derived classes in another package need to be
>> regenerated?
Hmmm. This sounds fishy.
> into it.
Not sure what that means and I'm not sure what you mean by there being
two Ecore in the same package.
Feature IDs are never negative.
The encoding for tracking the container/containment feature is like this:
* The feature ID of this object's container holding feature, if
there is one,
* or {@link #EOPPOSITE_FEATURE_BASE EOPPOSITE_FEATURE_BASE} minus
the feature ID of the container's feature that contains this object.
protected int eContainerFeatureID;
So it sounds to me like there is some inconsistency between the
containment feature IDs you use in the two different cases.
It's hard for me to imagine how that's possible, but then I have no idea
what you mean by "two Ecore" when you've only described one model...
> exception:
> mailto:'org.eclipse.emf.ecore.impl.EClassImpl@4c594c59 (name:
> mailto:'org.eclipse.emf.ecore.impl.EClassImpl@25d625d6 (name: BatchNet)
So clearly you have two different versions of the model and you're
mixing up instances of these two as if they should be instances of just
a single model. That's not going to work.
It doesn't sound related.
> Peter
<html>
<head>
</head>
Peter,<br>
<br>
Comments below.<br>
<br>
Peter Sasse wrote:
<blockquote cite="mid:ilt48g$5p1$1@news.eclipse.org" type="cite">Hi Ed,
<br>
<br>
<br>
<blockquote type="cite">Have these models been changing to add
features? Have a look at what happens in eBasicSetContainer when you
add it to the containment reference. The feature ID there should be -1
- <the feature of the containment reference in the parent class>.
<br>
regenerated?
<br>
</blockquote>
ecores.</blockquote>
Hmmm. This sounds fishy.<br>
<blockquote cite="mid:ilt48g$5p1$1@news.eclipse.org" type="cite"> One
type used to be read and merged the content of the first model into it.</blockquote>
two Ecore in the same package. <br>
<blockquote cite="mid:ilt48g$5p1$1@news.eclipse.org" type="cite"> The
<br>
</blockquote>
Feature IDs are never negative. <br>
<br>
this:<br>
<blockquote> /**<br>
there is one,<br>
the feature ID of the container's feature that contains this object.<br>
*/<br>
protected int eContainerFeatureID;<br>
</blockquote>
containment feature IDs you use in the two different cases.<br>
<blockquote cite="mid:ilt48g$5p1$1@news.eclipse.org" type="cite"><br>
BatchNets won't set the object at the opposite role for BatchStream. </blockquote>
idea what you mean by "two Ecore" when you've only described one
model...<br>
<blockquote cite="mid:ilt48g$5p1$1@news.eclipse.org" type="cite">I saw,
<br>
<br>
<a class="moz-txt-link-freetext" href="mailto:'org.eclipse.emf.ecore.impl.EClassImpl@4c594c59">mailto:'org.eclipse.emf.ecore.impl.EClassImpl@4c594c59</a> (name:
<a class="moz-txt-link-freetext" href="mailto:'org.eclipse.emf.ecore.impl.EClassImpl@25d625d6">mailto:'org.eclipse.emf.ecore.impl.EClassImpl@25d625d6</a> (name: BatchNet)</blockquote>
a single model. That's not going to work.<br>
<blockquote cite="mid:ilt48g$5p1$1@news.eclipse.org" type="cite"> ...'
<br>
<br>
<br>
<a class="moz-txt-link-freetext" href=" http://www.openarchitectureware.org/forum/viewtopic.php?foru m=2&showtopic=11530"> http://www.openarchitectureware.org/forum/viewtopic.php?foru m=2&showtopic=11530</a>,
<br>
</blockquote>
It doesn't sound related.<br>
<blockquote cite="mid:ilt48g$5p1$1@news.eclipse.org" type="cite"> create
<br>
<br>
<br>
<br>
Peter
<br>
</blockquote>
</body>
</html>
--------------000706030202030905090506--
Current Time: Mon Jul 28 17:07:28 EDT 2025
Powered by FUDForum. Page generated in 0.17612 seconds
