Home » Archived » BIRT » BIRT Viewer leaving files open?
BIRT Viewer leaving files open? [message #658471] |
Tue, 08 March 2011 11:15  |
We have a BIRT Viewer setup on tomcat 5.5, rhel 5, java 1.6.23.
When we generate a report, you can do this:
lsof | egrep java
java 2845 root 617u REG 253,0 314214 131125 /opt/birt/temp/DataEngine_5033323_2675/BasicDiskList19613244 (deleted)
java 2845 root 618u REG 253,0 313797 131126 /opt/birt/temp/DataEngine_5033323_2675/BasicDiskList30222539 (deleted)
java 2845 root 620u REG 253,0 252000 131127 /opt/birt/temp/DataEngine_5033323_2675/BasicDiskList23658015 (deleted)
java 2845 root 621u REG 253,0 313797 131128 /opt/birt/temp/DataEngine_5033323_2675/BasicDiskList251432 (deleted)
java 2845 root 622u REG 253,0 252000 131129 /opt/birt/temp/DataEngine_5033323_2675/BasicDiskList31527019 (deleted)
java 2845 root 623u REG 253,0 239071 131130 /opt/birt/temp/DataEngine_5033323_2675/BasicDiskList16573392 (deleted)
java 2845 root 624u REG 253,0 240416 131131 /opt/birt/temp/DataEngine_5033323_2675/BasicDiskList13675460 (deleted)
java 2845 root 625u REG 253,0 252000 131143 /opt/birt/temp/DataEngine_5033323_2675/BasicDiskList33448450 (deleted)
java 2845 root 626u REG 253,0 252000 131136 /opt/birt/temp/DataEngine_5033323_2675/BasicDiskList24793977 (deleted)
java 2845 root 627u REG 253,0 404214 131199 /opt/birt/temp/DataEngine_5033323_2675/BasicDiskList28869360 (deleted)
java 2845 root 628u REG 253,0 223766 131151 /opt/birt/temp/DataEngine_5033323_2675/BasicDiskList7686347 (deleted)
java 2845 root 629u REG 253,0 223631 131154 /opt/birt/temp/DataEngine_5033323_2675/BasicDiskList33433724 (deleted)
java 2845 root 630u REG 253,0 265377 131158 /opt/birt/temp/DataEngine_5033323_2675/BasicDiskList30043153 (deleted)
java 2845 root 631u REG 253,0 239071 131159 /opt/birt/temp/DataEngine_5033323_2675/BasicDiskList8181808 (deleted)
java 2845 root 632u REG 253,0 263750 131162 /opt/birt/temp/DataEngine_5033323_2675/BasicDiskList5591349 (deleted)
java 2845 root 633u REG 253,0 240416 131163 /opt/birt/temp/DataEngine_5033323_2675/BasicDiskList21397551 (deleted)
java 2845 root 634u REG 253,0 223766 131164 /opt/birt/temp/DataEngine_5033323_2675/BasicDiskList28685099 (deleted)
java 2845 root 635u REG 253,0 223631 131165 /opt/birt/temp/DataEngine_5033323_2675/BasicDiskList395110 (deleted)
java 2845 root 636u REG 253,0 404214 131166 /opt/birt/temp/DataEngine_5033323_2675/BasicDiskList30394608 (deleted)
java 2845 root 637u REG 253,0 403797 131168 /opt/birt/temp/DataEngine_5033323_2675/BasicDiskList9507802 (deleted)
java 2845 root 638u REG 253,0 265377 131169 /opt/birt/temp/DataEngine_5033323_2675/BasicDiskList11429932 (deleted)
java 2845 root 639u REG 253,0 263750 131171 /opt/birt/temp/DataEngine_5033323_2675/BasicDiskList3748215 (deleted)
java 2845 root 641u REG 253,0 536841 131197 /opt/birt/temp/DataEngine_5033323_2675/BasicDiskList13765283 (deleted)
etc.
For a "heavy" report, there are about 20 files generated, and less for "lighter" reports.
Eventually these will get GC'd. However, our servers get hit quite a lot, and typically we blow past the open file limits quickly. I upped the open file limit for now, but my question is this:
Should BIRT be leaving files open like this? As in, is this supposed to be happening or are we not cleaning up the reports correctly, making some sort of "end" call, etc.?
Re: BIRT Viewer leaving files open? [message #658477 is a reply to message #658471] |
Tue, 08 March 2011 11:20   |
Logan,
Those files are supposed to be created. I would have expected them to
close though. Can you post your code?
Jason
> lsof | egrep java
> etc.
> "lighter" reports.
Current Time: Tue Jul 22 23:59:26 EDT 2025
Powered by FUDForum. Page generated in 0.06040 seconds
