Home » Modeling » MoDisco » Integrating support for Javascript
Integrating support for Javascript [message #657834] Fri, 04 March 2011 04:06 Go to next message
I'm the main developer of Javascript for EMF (JS4EMF) and think it would
be interesting to add support for Javascript queries to Modisco, based
on JS4EMF.
What should I read and do to implement this?
Hallvard
Re: Integrating support for Javascript [message #657927 is a reply to message #657834] Fri, 04 March 2011 11:26 Go to previous messageGo to next message
Hi Hallvard,
First, thanks a lot for your interest!
I agree it would be a really nice contribution to MoDisco.
To have more information on the MoDisco Query Manager, you can take a look to the available general documentation from http://wiki.eclipse.org/MoDisco/Components/QueryManager/Docu mentation/0.9 to get an overall idea.
For the implementation part, there is already an example of such an integration of a query language: JXPath.
You can take a look to the source code of the corresponding org.eclipse.gmt.modisco.infra.query.jxpath plug-in which is available from the MoDisco SVN.
There, you will have a concrete example of the extension points to use and interfaces to implement.
More information can also be found from the Javadoc of the org.eclipse.gmt.modisco.infra.query and org.eclipse.gmt.modisco.infra.query.core plug-ins.
I hope this help.
And don't hesitate if you need more information.
Hugo
Re: Integrating support for Javascript [message #658133 is a reply to message #657927] Sun, 06 March 2011 17:22 Go to previous messageGo to next message
Good!
> I hope this help.
Thanks, that was what I needed. Based on this example I've implemented a
Javascript-based model query factory and adapter. It seems to work well.
Two questions:
- Do you have a test setup, so I can write an automated test instead of
just claiming it works?
- How to contribute the implementation?
Hallvard
Re: Integrating support for Javascript [message #658168 is a reply to message #658133] Mon, 07 March 2011 04:30 Go to previous messageGo to next message
Hi Hallvard,
Great!
Concerning the tests, you can find from the MoDisco SVN "tests" folder some projects providing tests on queries: org.eclipse.gmt.modisco.infra.query.tests for general tests on queries and org.eclipse.gmt.modisco.java.queries.tests for testing queries on a Java model.
Similarly, you could use a Java model to build your test plug-in...
Concerning the contribution of your implementation, here is some general information: http://wiki.eclipse.org/MoDisco/How_to_contribute
Basically, you will need to create a MDT-MoDisco "Contribution" bug and attach your plug-ins to it for initiating the process.
Hugo
Re: Integrating support for Javascript [message #658378 is a reply to message #658168] Tue, 08 March 2011 04:37 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=339183
Hallvard
Previous Topic:Infix Operation Code Elements Missing from JavaCode Model to KDM Model
Next Topic:Operating/editing the results of a query
Current Time: Wed Jul 23 07:44:34 EDT 2025
Powered by FUDForum. Page generated in 0.26178 seconds
