Home » Archived » BIRT » Using BIRT APIs
Using BIRT APIs [message #653220] Tue, 08 February 2011 16:56 Go to next message
I would like to utilize BIRT APIs. Is there a document which lists the APIs and what they do? I am looking for APIs to remove columns and rows, change text color, change font and preview mainly; however, might need more later.
please advise
Neil
Re: Using BIRT APIs [message #653437 is a reply to message #653220] Wed, 09 February 2011 13:31 Go to previous messageGo to next message
Neil,
You need the DE API (Design Engine API). There are a lot of examples on
birt-exchange.org that show how to use it. There is also a webinar on
the de api. You may also want to look at the eclipse page:
http://www.eclipse.org/birt/phoenix/deploy/designEngineAPI.p hp
Jason
On 2/8/2011 4:56 PM, Neil Wang wrote:
> more later.
> please advise
> Neil
Re: Using BIRT APIs [message #654293 is a reply to message #653437] Mon, 14 February 2011 18:17 Go to previous messageGo to next message
Hi Jason,
I would like to start with removing a row.
I looked through the APIs in org.eclipse.birt.report.model.api and am thinking shiftRow() in TableHandle is the method to use. Of course, I could be wrong and also am not sure how to initiate a TableHandle. Please advise.
Neil
Re: Using BIRT APIs [message #654431 is a reply to message #654293] Tue, 15 February 2011 13:01 Go to previous messageGo to next message
Neil,
If you just want to drop a detail row you can use the drop method. I am
attaching a test class that shows how to do various things with the de
api. In the example I insert a detail row using the
RowOperationParameters class. Right before I save the design I drop the
added row.
Jason
package DEAPI;
import java.io.IOException;
import java.util.ArrayList;
import java.util.List;
import java.io.BufferedInputStream;
import java.io.InputStream;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.model.api.CellHandle;
import org.eclipse.birt.report.model.api.ColumnHandle;
import org.eclipse.birt.report.model.api.DataItemHandle;
import org.eclipse.birt.report.model.api.DesignConfig;
import org.eclipse.birt.report.model.api.ElementFactory;
import org.eclipse.birt.report.model.api.IDesignEngine;
import org.eclipse.birt.report.model.api.IDesignEngineFactory;
import org.eclipse.birt.report.model.api.LabelHandle;
import org.eclipse.birt.report.model.api.ImageHandle;
import org.eclipse.birt.report.model.api.ActionHandle;
import org.eclipse.birt.report.model.api.ReportElementHandle;
import org.eclipse.birt.report.model.api.RowOperationParameters;
import org.eclipse.birt.report.model.api.ScalarParameterHandle;
import org.eclipse.birt.report.model.api.ScriptLibHandle;
import org.eclipse.birt.report.model.api.TextItemHandle;
import org.eclipse.birt.report.model.elements.JointDataSet;
import org.eclipse.birt.report.model.api.OdaDataSetHandle;
import org.eclipse.birt.report.model.api.JointDataSetHandle;
import org.eclipse.birt.report.model.api.JoinConditionHandle;
import org.eclipse.birt.report.model.api.OdaDataSourceHandle;
import org.eclipse.birt.report.model.api.PropertyHandle;
import org.eclipse.birt.report.model.api.ReportDesignHandle;
import org.eclipse.birt.report.model.api.RowHandle;
import org.eclipse.birt.report.model.api.SessionHandle;
import org.eclipse.birt.report.model.api.StructureFactory;
import org.eclipse.birt.report.model.api.TableHandle;
import org.eclipse.birt.report.model.api.activity.SemanticException ;
import org.eclipse.birt.report.model.api.elements.structures.Comput edColumn;
import org.eclipse.birt.report.model.elements.ReportItem;
import org.eclipse.birt.report.model.api.elements.structures.Embedd edImage;
import org.eclipse.birt.report.model.elements.Style;
import org.eclipse.birt.report.model.elements.ReportDesign;
import org.eclipse.birt.report.model.api.StyleHandle;
import
org.eclipse.birt.report.model.api.elements.structures.Aggreg ationArgument;
import
org.eclipse.birt.report.model.api.elements.structures.DateTi meFormatValue;
import org.eclipse.birt.report.model.api.elements.structures.Format Value;
import org.eclipse.birt.report.model.api.elements.structures.MapRul e;
import org.eclipse.birt.report.model.api.elements.structures.HideRu le;
import
org.eclipse.birt.report.model.api.elements.structures.Proper tyBinding;
import org.eclipse.birt.report.model.api.elements.structures.TOC;
import org.eclipse.birt.report.model.api.elements.structures.JoinCo ndition;
import org.eclipse.birt.report.model.api.elements.structures.ParamB inding;
import org.eclipse.birt.report.model.api.elements.DesignChoiceConst ants;
import org.eclipse.birt.report.model.api.elements.structures.Highli ghtRule;
import org.eclipse.birt.report.model.elements.interfaces.IJointData SetModel;
import org.eclipse.birt.report.model.api.elements.structures.SortKe y;
import org.eclipse.birt.report.model.api.SortKeyHandle;
import
org.eclipse.birt.report.model.api.elements.structures.Filter Condition;
import org.eclipse.birt.report.model.api.elements.structures.Action ;
import org.eclipse.birt.report.model.api.elements.structures.Includ eScript;
import java.util.Iterator;
import com.ibm.icu.util.ULocale;
* Simple BIRT Design Engine API (DEAPI) demo.
public class StructFactoryTest
ReportDesignHandle designHandle = null;
ElementFactory designFactory = null;
StructureFactory structFactory = null;
public static void main( String[] args )
try
StructFactoryTest de = new StructFactoryTest();
de.buildReport();
catch ( IOException e )
e.printStackTrace();
catch ( SemanticException e )
void buildDataSource( ) throws SemanticException
OdaDataSourceHandle dsHandle = designFactory.newOdaDataSource(
"Data Source", "org.eclipse.birt.report.data.oda.jdbc" );
dsHandle.setProperty( "odaDriverClass",
"org.eclipse.birt.report.data.oda.sampledb.Driver" );
dsHandle.setProperty( "odaURL", "jdbc:classicmodels:sampledb" );
dsHandle.setProperty( "odaUser", "ClassicModels" );
dsHandle.setProperty( "odaPassword", "" );
PropertyBinding pb = new PropertyBinding();
designHandle.getDataSources( ).add( dsHandle );
long currid = dsHandle.getID();
//pb.setName("odaUser");
//pb.setID(currid);
//pb.setValue("params[\"NewParameter\"].value");
//PropertyHandle ph = designHandle.getPropertyHandle("propertyBindings");
//ph.addItem(pb);
void buildDataSet( ) throws SemanticException
OdaDataSetHandle dsHandle = designFactory.newOdaDataSet( "ds",
"org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet" );
dsHandle.setDataSource( "Data Source" );
String qry = "Select * from customers";
dsHandle.setQueryText( qry );
addFilterCondition( dsHandle );
designHandle.getDataSets( ).add( dsHandle );
void buildDataSet2( ) throws SemanticException
OdaDataSetHandle dsHandle = designFactory.newOdaDataSet( "ds2",
String qry = "Select * from orderdetails where ordernumber = ?";
void buildJointDataSet( ) throws SemanticException
OdaDataSetHandle dsHandle1 = designFactory.newOdaDataSet( "ds1",
dsHandle1.setDataSource( "Data Source" );
String qry1 = "Select * from customers";
dsHandle1.setQueryText( qry1 );
OdaDataSetHandle dsHandle2 = designFactory.newOdaDataSet( "ds2",
dsHandle2.setDataSource( "Data Source" );
String qry2 = "Select * from orders";
dsHandle2.setQueryText( qry2 );
JointDataSetHandle jds = designFactory.newJointDataSet("test");
designHandle.getDataSets( ).add( dsHandle1 );
designHandle.getDataSets( ).add( dsHandle2 );
jds.addDataSet("ds1");
jds.addDataSet("ds2");
String leftExpression = "dataSetRow[\"CUSTOMERNUMBER\"]";
String rightExpression = "dataSetRow[\"CUSTOMERNUMBER\"]";
JoinCondition condition = StructureFactory.createJoinCondition( );
condition.setJoinType( DesignChoiceConstants.JOIN_TYPE_LEFT_OUT );
condition.setOperator( DesignChoiceConstants.JOIN_OPERATOR_EQALS );
condition.setLeftDataSet( "ds1" ); //$NON-NLS-1$
condition.setRightDataSet( "ds2" ); //$NON-NLS-1$
condition.setLeftExpression( leftExpression ); //$NON-NLS-1$
condition.setRightExpression( rightExpression ); //$NON-NLS-1$
PropertyHandle conditionHandle = jds
.getPropertyHandle( JointDataSet.JOIN_CONDITONS_PROP );
conditionHandle.addItem( condition );
designHandle.getDataSets( ).add( jds );
void addMapRule(TableHandle th){
try{
MapRule mr = structFactory.createMapRule();
mr.setTestExpression("row[\"CustomerCreditLimit\"]");
mr.setOperator(DesignChoiceConstants.MAP_OPERATOR_EQ);
mr.setValue1("0");
mr.setDisplay("N/A");
PropertyHandle ph = th.getPropertyHandle(StyleHandle.MAP_RULES_PROP);
ph.addItem(mr);
}catch (Exception e){
void addVisRule(ReportElementHandle rh){
try{
HideRule hr = structFactory.createHideRule();
hr.setFormat("pdf");
hr.setExpression("true");
PropertyHandle ph = rh.getPropertyHandle(ReportItem.VISIBILITY_PROP);
ph.addItem(hr);
void addBottomBorder(ReportElementHandle rh){
try{
rh.setProperty(StyleHandle.BORDER_BOTTOM_COLOR_PROP, "#000000");
rh.setProperty(StyleHandle.BORDER_BOTTOM_STYLE_PROP, "solid");
rh.setProperty(StyleHandle.BORDER_BOTTOM_WIDTH_PROP, "2px");
void addHighLightRule(RowHandle th){
try{
HighlightRule hr = structFactory.createHighlightRule();
hr.setOperator(DesignChoiceConstants.MAP_OPERATOR_GT);
hr.setTestExpression("row[\"CustomerCreditLimit\"]");
hr.setValue1("100000");
hr.setProperty(HighlightRule.BACKGROUND_COLOR_MEMBER, "blue");
PropertyHandle ph =
th.getPropertyHandle(StyleHandle.HIGHLIGHT_RULES_PROP);
ph.addItem(hr);
void addSortKey(TableHandle th){
try{
SortKey sk = structFactory.createSortKey();
//sk.setKey("row[\"CustomerName\"]");
sk.setDirection(DesignChoiceConstants.SORT_DIRECTION_ASC);
sk.setKey("if( params[\"srt\"].value){ if( params[\"srt\"].value ==
'a' ){ row[\"CustomerName\"]; }else{ row[\"CustomerCity\"];}}");
PropertyHandle ph = th.getPropertyHandle(TableHandle.SORT_PROP);
ph.addItem(sk);
void modSortKey(TableHandle th){
try{
SortKeyHandle sk;
//get number or iterate
sk = (SortKeyHandle)ph.get(0);
sk.setDirection(DesignChoiceConstants.SORT_DIRECTION_DESC);
void addFilterCondition(OdaDataSetHandle dh){
try{
FilterCondition fc = structFactory.createFilterCond();
fc.setExpr("row[\"COUNTRY\"]");
fc.setOperator(DesignChoiceConstants.MAP_OPERATOR_EQ);
fc.setValue1("'USA'");
dh.addFilter(fc);
void addFilterCondition(TableHandle th){
try{
fc.setExpr("row[\"CustomerCountry\"]");
PropertyHandle ph = th.getPropertyHandle(TableHandle.FILTER_PROP);
ph.addItem(fc);
void addHyperlink(LabelHandle lh){
try{
Action ac = structFactory.createAction();
ActionHandle actionHandle = lh.setAction( ac );
//actionHandle.setURI("'http://www.google.com'");
actionHandle.setLinkType(DesignChoiceConstants.ACTION_LINK_T YPE_DRILL_THROUGH);
actionHandle.setReportName("c:/test/xyz.rptdesign");
actionHandle.setTargetFileType("report-design");
actionHandle.setTargetWindow("_blank");
actionHandle.getMember("paramBindings");
ParamBinding pb = structFactory.createParamBinding();
pb.setParamName("order");
pb.setExpression("row[\"ORDERNUMBER\"]");
actionHandle.addParamBinding(pb);
<structure name="action">
<property name="linkType">drill-through</property>
<property name="reportName">detail.rptdesign</property>
<property name="targetWindow">_blank</property>
<property name="targetFileType">report-design</property>
<list-property name="paramBindings">
<structure>
<property name="paramName">order</property>
<expression
name="expression">row["ORDERNUMBER"]</expression>
</structure>
</list-property>
</structure>
void addToc(DataItemHandle dh){
try{
TOC myToc = structFactory.createTOC("row[\"CustomerName\"]");
dh.addTOC(myToc);
void addImage(){
try{
EmbeddedImage image = structFactory.createEmbeddedImage( );
image.setType( DesignChoiceConstants.IMAGE_TYPE_IMAGE_JPEG );
image.setData( load( "logo3.jpg" ) );
image.setName( "mylogo" );
designHandle.addImage( image );
public byte[] load( String fileName ) throws IOException
InputStream is = null;
is = new BufferedInputStream( this.getClass( ).getResourceAsStream(
fileName ) );
byte data[] = null;
if ( is != null )
try
data = new byte[is.available( )];
is.read( data );
catch ( IOException e1 )
throw e1;
return data;
void addScript(ReportDesignHandle rh){
try{
IncludeScript is = structFactory.createIncludeScript();
is.setFileName("test.js");
rh.getPropertyHandle(ReportDesign.INCLUDE_SCRIPTS_PROP);
//ph.addItem(is);
void buildReport() throws IOException, SemanticException
DesignConfig config = new DesignConfig( );
config.setBIRTHome("C:/birt/birt-runtime-2_5_1/birt-runtime-2_5_1/ReportEngine ");
IDesignEngine engine = null;
try{
Platform.startup( config );
IDesignEngineFactory factory = (IDesignEngineFactory) Platform
.createFactoryObject(
IDesignEngineFactory.EXTENSION_DESIGN_ENGINE_FACTORY );
engine = factory.createDesignEngine( config );
}catch( Exception ex){
ex.printStackTrace();
SessionHandle session = engine.newSessionHandle( ULocale.ENGLISH ) ;
ReportDesignHandle design = null;
try{
//open a design or a template
designHandle = session.createDesign();
addScript( designHandle);
designFactory = designHandle.getElementFactory( );
//designHandle.findScriptLib("name").setName("test2");
//Iterator iter = designHandle.scriptLibsIterator( );
//((ScriptLibHandle) iter.next()).drop() ;
//designHandle.dropScriptLib( lib );
buildDataSource();
buildDataSet();
buildJointDataSet();
TableHandle table = designFactory.newTableItem( "table", 3 );
table.setWidth( "100%" );
table.setDataSet( designHandle.findDataSet( "ds" ) );
// get first row in group header of group 0 .
//RowOperationParameters parameters1 = new RowOperationParameters( 0, 0,
// 0 );
// get second row in group header of group 0.
//RowOperationParameters parameters2 = new RowOperationParameters( 0, 0,
// 1 );
// get second row in table footer.
//RowOperationParameters parameters3 = new RowOperationParameters( 2, -1,
// 1 );
// get first row in table header.
//RowOperationParameters parameters4 = new RowOperationParameters( 0, -1,
// 0 );
// get second row in table detail which contain row span.
//RowOperationParameters parameters5 = new RowOperationParameters( 2, -1,
// 1 );
// get first row in group header of group 1.
//RowOperationParameters parameters6 = new RowOperationParameters( 0, 1,
// 0 );
//second parm has to be -1 unless you are modifying a group
//third parm specifies the row number
//first parm is the slotid
RowOperationParameters ro = new RowOperationParameters(2, -1, 0);
table.insertRow(ro);
PropertyHandle computedSet = table.getColumnBindings( );
ComputedColumn cs1, cs2, cs3, cs4, cs5;
cs1 = StructureFactory.createComputedColumn();
cs1.setName("CustomerName");
cs1.setExpression("dataSetRow[\"CUSTOMERNAME\"]");
computedSet.addItem(cs1);
cs2 = StructureFactory.createComputedColumn();
cs2.setName("CustomerCity");
cs2.setExpression("dataSetRow[\"CITY\"]");
//cs2.setDataType(dataType)
computedSet.addItem(cs2);
cs3 = StructureFactory.createComputedColumn();
cs3.setName("CustomerCountry");
cs3.setExpression("dataSetRow[\"COUNTRY\"]");
computedSet.addItem(cs3);
cs4 = StructureFactory.createComputedColumn();
cs4.setName("CustomerCreditLimit");
cs4.setExpression("dataSetRow[\"CREDITLIMIT\"]");
computedSet.addItem(cs4);
cs5 = StructureFactory.createComputedColumn();
cs5.setName("CustomerCreditLimitSum");
cs5.setExpression("dataSetRow[\"CREDITLIMIT\"]");
cs5.setAggregateFunction("sum");
//cs5.setFilterExpression(expression)
//All or group name
//cs5.setAggregateOn(aggregateOn)
computedSet.addItem(cs5);
// table header
RowHandle tableheader = (RowHandle) table.getHeader( ).get( 0 );
ColumnHandle ch = (ColumnHandle)table.getColumns().get(0);
ch.setProperty("width", "50%");
ColumnHandle ch2 = (ColumnHandle)table.getColumns().get(1);
ch2.setSuppressDuplicates(true);
LabelHandle label1 = designFactory.newLabel("Label1" );
label1.setOnRender("var x = 3;");
addBottomBorder(label1);
label1.setText("Customer");
CellHandle cell = (CellHandle) tableheader.getCells( ).get( 0 );
cell.getContent( ).add( label1 );
LabelHandle label2 = designFactory.newLabel("Label2" );
label2.setText("City");
cell = (CellHandle) tableheader.getCells( ).get( 1 );
cell.getContent( ).add( label2 );
LabelHandle label3 = designFactory.newLabel("Label3" );
label3.setText("Credit Limit");
cell = (CellHandle) tableheader.getCells( ).get( 2 );
cell.getContent( ).add( label3 );
// table detail (second Detail Row)
RowHandle tabledetail = (RowHandle) table.getDetail( ).get( 1 );
cell = (CellHandle) tabledetail.getCells( ).get( 0 );
DataItemHandle data = designFactory.newDataItem( "data1" );
data.setResultSetColumn("CustomerName");
addToc( data );
cell.getContent( ).add( data );
cell = (CellHandle) tabledetail.getCells( ).get( 1 );
data = designFactory.newDataItem( "data2" );
data.setResultSetColumn("CustomerCity");
cell = (CellHandle) tabledetail.getCells( ).get( 2 );
data = designFactory.newDataItem( "data3" );
TextItemHandle tih =designFactory.newTextItem("mytextitem");
//tih.setContentType(contentType);
//tih.setContent(value);
data.setResultSetColumn("CustomerCreditLimit");
FormatValue fv = structFactory.newFormatValue();
fv.setPattern("#,##0.00{RoundingMode=HALF_UP}");
fv.setCategory("custom");
data.setProperty("numberFormat", fv);
addHyperlink(label1);
addMapRule(table);
addHighLightRule(tabledetail);
addSortKey(table);
modSortKey(table);
addFilterCondition(table);
addImage();
RowHandle tablefooter = (RowHandle) table.getFooter().get( 0 );
cell = (CellHandle) tablefooter.getCells( ).get( 0 );
ImageHandle image1 = designFactory.newImage( "mylogo" );
image1.setImageName( "mylogo" );
//image1.sets
//addVisRule( image1 );
//cell.getContent( ).add( image1 );
cell = (CellHandle) tablefooter.getCells( ).get( 2 );
data = designFactory.newDataItem( "datasum" );
//FormatValue formatValueToSet = new DateTimeFormatValue( );
//formatValueToSet.setPattern( "dd/mm/yy" );
//formatValueToSet.setCategory("Custom");
//data.setProperty( StyleHandle.DATE_TIME_FORMAT_PROP,
// formatValueToSet );
//has to have a style data.getStyle().setDateTimeFormat("dd/mm/yy");
data.setResultSetColumn("CustomerCreditLimitSum");
ScalarParameterHandle sph = designFactory.newScalarParameter("srt");
sph.setIsRequired(false);
//sph.setAllowNull(true);
//sph.setAllowBlank(true);
sph.setValueType(DesignChoiceConstants.PARAM_VALUE_TYPE_STAT IC);
sph.setDataType(DesignChoiceConstants.PARAM_TYPE_STRING);
designHandle.getParameters().add(sph);
//delete the row added earlier:
table.getDetail().get(0).drop();
designHandle.getBody( ).add( table );
// Save the design and close it.
designHandle.saveAs("output/desample/structfactorytest.rptdesign " );
designHandle.close( );
Platform.shutdown();
System.out.println("Finished");
On 2/14/2011 6:17 PM, Neil Wang wrote:
> Hi Jason,
> Please advise.
> Neil
Re: Using BIRT APIs [message #658332 is a reply to message #654431] Mon, 07 March 2011 17:58 Go to previous messageGo to next message
Hi Jason,
Thank you for your comment.
I gave it a try. I am working on this incrementally and the first thing I wanted to achieve is to open an existing template and save it to somewhere else. This is what I did:
try{
try{
designHandle = session.openDesign("PhysicalModel.rptdesign");
designHandle.saveAs("structfactorytest.rptdesign");
I tried to open structfactorytest.rptdesign and this is what I got
"Could not open the editor: The editor class could not be instantiated. This usually indicates a missing no-arg cstructor or that the editor's class name was mistyped in plugin.xml"
There is a long stack trace after the message.
I opened both PhysicalModel.rptdesign and structfactorytest.rptdesign to compare them to see what the differences are.
There are two types of differences:
1.
in PhysicalModel.rptdesign
<property name="queryText"></property>
in the same line of structfactorytest.rptdesign
<xml-property name="queryText"><![CDATA[]]></xml-property>
2.
<property name="displayName">Name</property>
<text-property name="displayName">Name</text-property>
I replaced <xml-property name="queryText"><![CDATA[]]></xml-property> with <property name="queryText"></property> and <text-property name="displayName">Name</text-property> with <property name="displayName">Name</property> in structfactorytest.rptdesign. The template can be opened without error.
Also, do I have to do this?
I incorporated BIRT with the product I am working on and the product has BIRT features and plugins without the standard file structure that comes with BIRT runtime (like the BIRT home file structure)
please advise.
Neil
Re: Using BIRT APIs [message #658438 is a reply to message #658332] Tue, 08 March 2011 09:14 Go to previous messageGo to next message
Neil,
I am somewhat confused on how you have BIRT deployed. If the birt
plugins are already part of your app set the birt home to "" and do not
do a platform startup or shutdown. You should still be able to just call:
To get the design engine.
Jason
On 3/7/2011 5:58 PM, Neil Wang wrote:
> Hi Jason,
> try{
> try{
> 1.
> 2.
> please advise.
> Neil
Re: Using BIRT APIs [message #658493 is a reply to message #658438] Tue, 08 March 2011 12:59 Go to previous messageGo to next message
Hi Jason,
Setting the home to "" and removing the platform start and shut down fixes the problem. thanks~
Neil
Re: Using BIRT APIs [message #659087 is a reply to message #658438] Thu, 10 March 2011 17:41 Go to previous messageGo to next message
Hi Jason,
I have an existing template which has many nested tables.
There are two things I am trying to figure out how to do
1. how to open a specific table and remove its rows.
2. how to remove a specific table.
I have tried googling for the info but have no luck. please advise.
Neil
Re: Using BIRT APIs [message #659222 is a reply to message #659087] Fri, 11 March 2011 09:55 Go to previous messageGo to next message
Neil
I this thread a posted some code on how to drop a detail row, but it did
not show how to locate the table to begin with. There are a couple ways
to do this. One iterate over the contents of the entire report and
examine each table or two name your tables in the general properties for
the table item and then use:
designHandle.findElement("mytable");
where mytable is the name. Make sure to cast it to a TableHandle. To
drop the table just use
designHandle.findElement("mytable").drop();
Jason
On 3/10/2011 5:41 PM, Neil Wang wrote:
> Hi Jason,
> Neil
Re: Using BIRT APIs [message #660508 is a reply to message #659222] Fri, 18 March 2011 13:17 Go to previous messageGo to next message
Hi Jason,
Thanks you, it works fine.
I am now trying to remove a column from a table and this is what I did.
TableHandle table = (TableHandle)designHandle.findElement("Column");
table.getColumns().get(1).drop();
When I tried to open the report design, the ArrayIndexOutOfBoundsException occurred. Did I drop it the right way? If not, please advise on how I should do it.
thanks,
Neil
Re: Using BIRT APIs [message #660518 is a reply to message #660508] Fri, 18 March 2011 15:00 Go to previous messageGo to next message
drop the cells first like:
TableHandle th = (TableHandle)report.findElement("mytable");
RowHandle header = (RowHandle) th.getHeader( ).get( 0 );
header.getCells().get(0).drop();
RowHandle detail1 = (RowHandle) th.getDetail().get( 0 );
detail1.getCells().get(0).drop();
//RowHandle detail2 = (RowHandle) th.getDetail().get( 1 );
//detail2.getCells().get(0).drop();
//RowHandle detail3 = (RowHandle) th.getDetail().get( 2 );
//detail3.getCells().get(0).drop();
//RowHandle footer = (RowHandle) th.getFooter( ).get( 0 );
//footer.getCells().get(0).drop();
th.getColumns().get(0).drop();
0 is the first column btw.
Jason
On 3/18/2011 1:17 PM, Neil Wang wrote:
> Hi Jason,
> thanks,
> Neil
Re: Using BIRT APIs [message #660812 is a reply to message #660518] Mon, 21 March 2011 13:36 Go to previous messageGo to next message
Hi Jason,
Thank you. It works fine.
Neil
Re: Using BIRT APIs [message #662782 is a reply to message #660518] Thu, 31 March 2011 18:10 Go to previous messageGo to next message
Hi Jason,
I have some questions about how to modify the properties
1. Change the background color of a row
This is what I did to change the background of a row:
RowHandle tableheader = (RowHandle) table.getHeader().get(0);
tableheader.getStyle().getBackgroundColor();
I was looking for setBackgroundColor() but didn't find it. Please let me know how I can set the color? I would like to use RGB value to set the color.
2. Change the font of a row of text
This is what I did to change the font of a row of text:
tableheader.getStyle().setFontStyle(fontStyle)
The java doc shows this:
Sets the style of the font. The input value is one of constants defined in DesignChoiceConstants:
- FONT_STYLE_NORMAL
- FONT_STYLE_ITALIC
- FONT_STYLE_OBLIQUE
There is a lot of different fonts but I can't find them all. Please let me know how I can find them.
3. Change the size of a row of text
I tried to find the method but couldn't find it. Please advise.
4. Is it possible to invoke the preview method programmatically; so that, preview can be performed on an existing template?
regards,
Neil
Re: Using BIRT APIs [message #662812 is a reply to message #662782] Fri, 01 April 2011 00:09 Go to previous messageGo to next message
Neil,
1 - If you just want to set the color do
tableheader.setProperty(StyleHandle.BACKGROUND_COLOR_PROP, "Blue");
or
tableheader.setProperty(StyleHandle.BACKGROUND_COLOR_PROP, "#FF8080");
2 - Not sure what you want here. Are you needing the fontFamily changed
use:
tableheader.setProperty( StyleHandle.FONT_WEIGHT_PROP,
DesignChoiceConstants.FONT_WEIGHT_BOLD );
tableheader.setProperty( StyleHandle.FONT_FAMILY_PROP, "Century" );
tableheader.setProperty( StyleHandle.FONT_SIZE_PROP, "12pt" );
3 - Do you mean row height or font size?
tableheader.setProperty(ReportItemHandle.HEIGHT_PROP, "1.2in");
4 - What is the context? The Web Viewer is a plugin and you can call
the WebViewer.display method from a RCP/Eclipse based app.
Jason
On 3/31/2011 6:10 PM, Neil Wang wrote:
> Hi Jason,
> color.
> - FONT_STYLE_NORMAL
> - FONT_STYLE_ITALIC
> regards,
> Neil
Re: Using BIRT APIs [message #663006 is a reply to message #662812] Fri, 01 April 2011 19:24 Go to previous messageGo to next message
Hi Jason,
Thank you for the comment.
Do you know where I can find all the available values for "StyleHandle.FONT_FAMILY_PROP"?
You have it as "Century" in the example.
Also, what I am trying to do with preview is that I am adding a wizard to modify existing reports. In the wizard, I would like to have a preview button. When clicked, it will bring up a window which shows a subset of the report. If the Web Viewer is something I should use, can you please let me know which plugin has it?
regards,
Neil
Re: Using BIRT APIs [message #663278 is a reply to message #663006] Mon, 04 April 2011 09:51 Go to previous messageGo to next message
Neil,
I believe this will depend on what fonts are installed on your system.
The viewer plugin is org.eclipse.birt.report.viewer.
Jason
On 4/1/2011 7:24 PM, Neil Wang wrote:
> Hi Jason,
> regards,
> Neil
Re: Using BIRT APIs [message #663412 is a reply to message #663278] Mon, 04 April 2011 18:16 Go to previous messageGo to next message
Hi Jason,
Thank you for your comment. Is there a doc which explains how to use the display() method?
I used this one: public static void display(String report, String format, boolean allowPage)
This is how I invoked it: WebViewer.display("C:/report.rptdesign", WebViewer.HTML, true);
However, I ran into this exception
at org.eclipse.birt.report.viewer.utilities.AppServerWrapper.ge tPort(AppServerWrapper.java:207)
at org.eclipse.birt.report.viewer.utilities.WebappAccessor.getP ort(WebappAccessor.java:162)
at org.eclipse.birt.report.viewer.utilities.WebViewer.getBaseUR L(WebViewer.java:316)
at org.eclipse.birt.report.viewer.utilities.WebViewer.createURL (WebViewer.java:532)
at org.eclipse.birt.report.viewer.utilities.WebViewer.createURL (WebViewer.java:500)
at org.eclipse.birt.report.viewer.utilities.WebViewer.display(W ebViewer.java:907)
at org.eclipse.birt.report.viewer.utilities.WebViewer.display(W ebViewer.java:881)
please advise,
Neil
Re: Using BIRT APIs [message #663650 is a reply to message #663412] Tue, 05 April 2011 23:07 Go to previous messageGo to next message
Neil,
Can you try something like:
BrowserManager bmg = BrowserManager.getInstance();
bmg.setAlwaysUseExternal(false);
HashMap myparms = new HashMap();
HashMap emitmap = new HashMap();
myparms.put("SERVLET_NAME_KEY", "frameset");
myparms.put("FORMAT_KEY", "html");
//myparms.put("RESOURCE_FOLDER_KEY", "c:/myresources");
myparms.put("ALLOW_PAGE", "false");
myparms.put("SHOW_PARAMETER_PAGE", "false");
//emitmap.put("Top Count", "6");
//myparms.put("EMITTER_OPTIONS_KEY", emitmap);
//myparms.put("MAX_ROWS_KEY", "500");
//WebViewer.display(rpt, browser, myparms);
//WebViewer.display(reportName, browser, myparms);
WebViewer.display(reportName, myparms);
I have commented out some of the options.
Jason
On 4/4/2011 6:16 PM, Neil Wang wrote:
> Hi Jason,
> display() method?
> ebViewer.java:907)
> ebViewer.java:881)
> please advise,
> Neil
Re: Using BIRT APIs [message #664214 is a reply to message #663650] Thu, 07 April 2011 16:55 Go to previous messageGo to next message
Hi Jason,
Is there a property I can set to limit the number of rows in the report?
please advise,
Neil
Re: Using BIRT APIs [message #664286 is a reply to message #664214] Fri, 08 April 2011 04:46 Go to previous messageGo to next message
Neil,
Use MAX_ROWS_KEY:
myparms.put(WebViewer.MAX_ROWS_KEY, "5");
Jason
On 4/7/2011 4:55 PM, Neil Wang wrote:
> Hi Jason,
> please advise,
> Neil
Re: Using BIRT APIs [message #666696 is a reply to message #664286] Thu, 21 April 2011 12:49 Go to previous messageGo to next message
Hi Jason,
I noticed something:
If I have a table with a name "Customer" and the table looks like this
First Name [First Name] row 0
Last Name [Last Name] row 1
ID [ID] row 2
I noticed that if I remove row 1 by using
customerTable.getRows().get(1).drop();
before saving the template, the index of each entry becomes
ID [ID] row 1
If I would like to remove the ID row and use
customerTable.getRows().get(2).drop();
I will get an out of bound exception; therefore, I would like to know which row I am removing before doing it. I am thinking about grabbing the label first.
For example, I would like to
1. find the label "Last Name" with the table name "Customer" and grab the whole row and remove it.
2. find the label "ID" with the table name "Customer" and grab the whole row and remove it.
this way, I won't get the exception.
I would like to do the same for columns, too. Is there a way to achieve this or there is a better solution?
Please advise.
Neil
Re: Using BIRT APIs [message #699462 is a reply to message #666696] Thu, 21 July 2011 11:20 Go to previous messageGo to next message
Hi guys i have a big problem
i want to make api with birt but does not work, i tried with the exemple api from Birt and i got the following msg.
Exception in thread "main" java.lang.NoClassDefFoundError: org/eclipse/core/runtime/CoreException
at org.eclipse.birt.core.framework.Platform.createPlatformLauncher(Platform.java:115)
at org.eclipse.birt.core.framework.Platform.startup(Platform.java:74)
at DeDemo.buildReport(DeDemo.java:80)
at DeDemo.main(DeDemo.java:43)
Caused by: java.lang.ClassNotFoundException: org.eclipse.core.runtime.CoreException
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
... 4 more
can u please helpe
Re: Using BIRT APIs [message #699539 is a reply to message #699462] Thu, 21 July 2011 13:52 Go to previous messageGo to next message
What are you using to build the app? Eclipse? Is this a command line
app or a Web app? What version of BIRT are you using?
By the look of the error, it seems that you are missing the
reportengine/lib jars from the classpath.
Jason
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> ... 4 more
> can u please helpe
Re: Using BIRT APIs [message #699707 is a reply to message #699539] Fri, 22 July 2011 03:03 Go to previous messageGo to next message
HELLO
I am using Eclipse INDIGO (last version) and the last version from BIRT 3.7.
Re: Using BIRT APIs [message #699709 is a reply to message #699707] Fri, 22 July 2011 03:05 Go to previous messageGo to next message
i read thar the reportengine/lib jars are already on the new BIrt version
thanks
Re: Using BIRT APIs [message #699938 is a reply to message #699709] Fri, 22 July 2011 10:56 Go to previous messageGo to next message
Richard,
Did you get this to work?
Jason
> thanks
Re: Using BIRT APIs [message #703158 is a reply to message #699938] Wed, 27 July 2011 04:37 Go to previous message
WOW!!
great works!!!
thanks jason
regards
richard
Previous Topic:using UI libraries in custom parameter page
Next Topic:INPUT PARAMETERS
Current Time: Wed Jul 23 05:33:40 EDT 2025
Powered by FUDForum. Page generated in 0.23861 seconds
