Home » Eclipse Projects » Plugin Development Environment (PDE) » Including Root Files in a Product Build
| Including Root Files in a Product Build [message #604934] |
Tue, 09 March 2010 08:31   |
Eclipse User  |
I have a PDE headless build for my product (plugins-based), which works well.
Now I need to add a couple of files to my product, and I (try to) follow guidelines from this article :  http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .pde.doc.user/tasks/pde_rootfiles.htm, ie.create a feature that contributes rootfiles, but does not specify a bin.includes property, and use the featureList property to select this feature.
So:
- I created a feature for root files only (its build.properties only contains root=rootfiles, with the rootfiles folder containing the two extra-files I need)
- the headless build works fine, without error
- at the end, I see that ${buildDirectory}/repository/binary contains a binary file that corresponds to the feature I created for root files. If I open this binary files in an hex editor I can see, among other things, the names of the root files I want to add.
But finally, the produced zip doesn't contain the root files. At its root I only see (just like before trying to add root files) the exe launcher, the ini file, and artifact.xml
Any hint?
Thanks in advance for your help,
Yves
Yves Monier
| Re: Including Root Files in a Product Build [message #658298 is a reply to message #604934] |
Mon, 07 March 2011 13:03    |
Eclipse User  |
I did come across with the same issue.
It worked well with previous Eclipse versions (Ganymede, Galileo), but now
I use the new productBuild.xml ant template (which is pretty different
 from its predecessors), and the root files are not copied in outcome
product archive.
The configuration is:
[1] productBuild.xml
	<target name="main" description="the main build target">
		<antcall target="preBuild" />
		<antcall target="processRepos" />
		<antcall target="generateFeature">
			<!-- Generate the feature to drive the fetch -->
			<param name="verify" value="false" />
		</antcall>
		<antcall target="fetch" />
			<!-- We are calling generate feature a second time so that we can get
the pack / unpack clause fixed -->
			<param name="verify" value="true" />
		</antcall>
		<antcall target="generate" />
		<antcall target="process" />
		<antcall target="assemble" />
		<antcall target="package" />
		<antcall target="postBuild" />
	</target>
	<!-- Generate a container feature based on the product
file                -->
	<!-- The plugin or feature containing the .product file will need to
exist -->
	<!-- already, use preSetup or postSetup to fetch it if
necessary           -->
	<target name="generateFeature">
		<eclipse.generateFeature
featureId="org.eclipse.pde.build.container.feature"
buildDirectory="${buildDirectory}" baseLocation="${baseLocation}"
productFile="${product}" verify="${verify}"
pluginPath="${transformedRepoLocation}${path.separator}${pluginPath} "
configInfo="${configs}" pluginList="${pluginList}"
featureList="${featureList}" includeLaunchers="${includeLaunchers}"
buildPropertiesFile="${generatedBuildProperties}"
nestedInclusions="${nestedInclusions}" filterP2Base="${filterP2Base}" />
	</target>
[2] Feature's build.properties:
bin.includes = feature.xml,\
                root=rootfiles
[3] Feature layout
build.properties
feature.xml
rootfiles
   - license.html
Is there an additional setting which enable the root files support in
build.properties, or did I miss smth?
Jtonic
On Tue, 09 Mar 2010 15:31:03 +0200, Yves Monier <yves.monier@gmail.com>
wrote:
> Hello,
> well.
> feature.
> So:
> extra-files I need)
> the names of the root files I want to add. But finally, the produced zip
> artifact.xml
> Any hint?
> Yves
Respect
jtonic
| Re: Including Root Files in a Product Build [message #658317 is a reply to message #658298] |
Mon, 07 March 2011 14:55   |
Eclipse User  |
------------Mem8aJIu0y1LG2MEOfRjAu
Content-Type: text/plain; charset=iso-8859-15; format=flowed; delsp=yes
I did manage to configure the product generation related files [1] so as
the root files went in outcome archives.
Reading carefully here [1], I've noticed there are 2 ways to include Root
Files in a product build.
The last worked for me.
Quote
  ${buildDirectory}/build.properties: generatedBuildProperties =
${buildDirectory}/root.properties
  ${buildDirectory/root.properties: root =
absolute:${buildDirectory}/rootfiles
  ${buildDirectory}/rootfiles/*
Also, I did a mistake in my previous post when I've said the
productBuild.xml ANT template was changed significantly in Helios
 (${eclipse_home}\plugins\org.eclipse.pde.build**\scripts\pro ductBuild\productBuild.xml)
In fact my older productBuild.xml build script was a custom one.
The changes in Helios include:
[1] productBuild.xml, build.properties & root.properties
[2]
Jtonic
On Mon, 07 Mar 2011 20:03:38 +0200, Jtonic <antonel.pazargic@gmail.com>
> now I use the new productBuild.xml ant template (which is pretty
> different from its predecessors), and the root files are not copied in
> outcome product archive.
> </antcall>
> <!-- We are calling generate feature a second time so that we can getthe
> </antcall>
> </target>
> <!-- Generate a container feature based on the productfile -->
> exist -->
> <!-- already, use preSetup or postSetup to fetch it ifnecessary -->
> </target>
> root=rootfiles
> [3] Feature layout
> build.properties
> feature.xml
> rootfiles
> - license.html
> Regards
> Jtonic
> wrote:
>> Hello,
>> well.
>> Now I need to add a couple of files to my product, and I (try to)follow
>> feature.
>> So:
>> extra-files I need)
>> binary file that corresponds to the feature I created for root files.If
>> I open this binary files in an hex editor I can see, among otherthings,
>> the names of the root files I want to add. But finally, theproduced zip
>> doesn't contain the root files. At its root I only see(just like before
>> trying to add root files) the exe launcher, the inifile, and
>> artifact.xml
>> Any hint?
>> Yves
Respect
jtonic
Content-Type: multipart/related; boundary=----------Mem8aJIu0y1LG25T4zbuOr
------------Mem8aJIu0y1LG25T4zbuOr
Content-Type: text/html; charset=iso-8859-15
Content-ID: <op.1299527743875.65cf6d546d5dd36a@192.168.0.103>
Content-Transfer-Encoding: Quoted-Printable
<!DOCTYPE html><html><head><style type=3D"text/css">body { font-family:'=
Times New Roman'; font-size:17px}</style></head><body><div>I did manage =
to configure the product generation related files [1] so as the root fil=
es went in outcome archives.</div><div><br>Reading carefully here [1], I=
've noticed there are 2 ways to include Root Files in a product build.<b=
r>The last worked for me. <br><br>Quote<br>>>>> <br> ${b=
uildDirectory}/build.properties:  generatedBuildProperties =3D ${buildDi=
rectory}/root.properties<br> ${buildDirectory/root.properties:    root =3D=
 absolute:${buildDirectory}/rootfiles<br> ${buildDirectory}/rootfiles/*<=
br><<<<br><br>Also, I did a mistake in my previous post when I'=
ve said the productBuild.xml ANT template was changed significantly in H=
elios  (${eclipse_home}\plugins\org.eclipse.pde.build**\scripts\pro ductBu=
ild\productBuild.xml) . </div><div>In fact my older productBuild.xm=
l build script was a custom one.</div><div><br></div><div>The changes in=
 Helios include:</div><div><br>		nestedInclusions=3D"${nestedInclusions}=
"<br>		filterP2Base=3D"${filterP2Base}"<br><br>[1] productBuild.xml, bui=
ld.properties & root.properties<br>[2] http://help.eclipse.org/galil=
 eo/index.jsp?topic=3D/org.eclipse.pde.doc.user/tasks/pde_roo tfiles.htm <=
br><br>Regards<br><br>Jtonic<br><br>On Mon, 07 Mar 2011 20:03:38 +0200, =
Jtonic <antonel.pazargic@gmail.com> wrote:<br><br>> I did come =
across with the same issue.<br>> It worked well with previous Eclipse=
 versions (Ganymede, Galileo), but  <br>> now I use the new productBu=
ild.xml ant template (which is pretty  <br>> different  from its pred=
ecessors), and the root files are not copied in  <br>> outcome produc=
t archive.<br>><br>> The configuration is:<br>><br>> [1] pro=
ductBuild.xml<br>><br>> 	<target name=3D"main" description=3D"t=
he main build target"><br>> 		<antcall target=3D"preBuild" />=
;<br>> 		<antcall target=3D"processRepos" /><br>> 		<antc=
all target=3D"generateFeature"><br>> 			<!-- Generate the featu=
re to drive the fetch --><br>> 			<param name=3D"verify" value=3D=
"false" /><br>> 		</antcall><br>> 		<antcall target=3D=
"fetch" /><br>> 		<antcall target=3D"generateFeature"><br>&g=
t; 			<!-- We are calling generate feature a second time so that we c=
an get  <br>> the pack / unpack clause fixed --><br>> 			<pa=
ram name=3D"verify" value=3D"true" /><br>> 		</antcall><br>&=
gt; 		<antcall target=3D"generate" /><br>> 		<antcall target=
=3D"process" /><br>> 		<antcall target=3D"assemble" /><br>&g=
t; 		<antcall target=3D"package" /><br>> 		<antcall target=3D=
"postBuild" /><br>> 	</target><br>><br>> 	<!--  <br=
>>  =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=
 =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=
 =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D --=
><br>> 	<!-- Generate a container feature based on the product =
 <br>> file                --><br>> 	<!-- The plugin or feat=
ure containing the .product file will need to  <br>> exist --><br>=
> 	<!-- already, use preSetup or postSetup to fetch it if  <br>>=
; necessary           --><br>> 	<!--  <br>> =3D=3D=3D=3D=3D=3D=
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D --><br>> 	<target=
 name=3D"generateFeature"><br>> 		<eclipse.generateFeature  <br=
>> featureId=3D"org.eclipse.pde.build.container.feature"  <br>> bu=
ildDirectory=3D"${buildDirectory}" baseLocation=3D"${baseLocation}"  <br=
>> productFile=3D"${product}" verify=3D"${verify}"  <br>> pluginPa=
th=3D"${transformedRepoLocation}${path.separator}${pluginPath} "  <br>>=
; configInfo=3D"${configs}" pluginList=3D"${pluginList}"  <br>> featu=
reList=3D"${featureList}" includeLaunchers=3D"${includeLaunchers}"  <br>=
> buildPropertiesFile=3D"${generatedBuildProperties}"  <br>> neste=
dInclusions=3D"${nestedInclusions}" filterP2Base=3D"${filterP2Base}" /&g=
t;<br>> 	</target><br>><br>><br>> [2] Feature's build.=
properties:<br>> bin.includes =3D feature.xml,\<br>>              =
   root=3Drootfiles<br>><br>> [3] Feature layout<br>> build.pro=
perties<br>> feature.xml<br>> rootfiles<br>>    - license.html<=
br>><br>> Is there an additional setting which enable the root fil=
es support in  <br>> build.properties, or did I miss smth?<br>><br=
>> Regards<br>><br>> Jtonic<br>><br>><br>><br>> <br>=
> On Tue, 09 Mar 2010 15:31:03 +0200, Yves Monier <yves.monier@gma=
il.com>  <br>> wrote:<br>><br>>> Hello,<br>>><br>&g=
t;> I have a PDE headless build for my product (plugins-based), which=
 works  <br>>> well.<br>>> Now I need to add a couple of fil=
es to my product, and I (try to)  <br>>> follow guidelines from th=
is article :  <br>>> <a href=3D"http://help.eclipse.org/galileo/in=
 dex.jsp?topic=3D/org.eclipse.pde.doc.user/tasks/pde_rootfile s.htm ">http:=
 //help.eclipse.org/galileo/index.jsp?topic=3D/org.eclipse.pd e.doc.user/t=
asks/pde_rootfiles.htm</a>,  <br>>> ie.create a feature that contr=
ibutes rootfiles, but does not specify a  <br>>> bin.includes prop=
erty, and use the featureList property to select this  <br>>> feat=
ure.<br>>><br>>> So:<br>>> - I created a feature for r=
oot files only (its build.properties only  <br>>> contains root=3D=
rootfiles, with the rootfiles folder containing the two  <br>>> ex=
tra-files I need)<br>>> - the headless build works fine, without e=
rror<br>>> - at the end, I see that ${buildDirectory}/repository/b=
inary contains a  <br>>> binary file that corresponds to the featu=
re I created for root files.  <br>>> If I open this binary files i=
n an hex editor I can see, among other  <br>>> things, the names o=
f the root files I want to add. But finally, the  <br>>> produced =
zip doesn't contain the root files. At its root I only see  <br>>>=
 (just like before trying to add root files) the exe launcher, the ini  =
<br>>> file, and artifact.xml<br>>><br>>> Any hint?<br=
>>> Thanks in advance for your help,<br>>><br>>> Yves<=
br>>><br>><br>><br><br><br ></div><div id=3D"M2Signature"><di=
v>-- </div><div><div><em>Respect</em><br><br><strong><big ><big>jtonic</b=
ig></big></strong><br></div></div></div></body></html >
------------Mem8aJIu0y1LG25T4zbuOr--
------------Mem8aJIu0y1LG2MEOfRjAu--
 Current Time: Tue Nov 04 01:32:22 EST 2025
 Powered by  FUDForum. Page generated in 0.04081 seconds
