Home » Modeling » MoDisco » Modisco standalone
Modisco standalone [message #658261] Mon, 07 March 2011 10:28 Go to next message
Originally posted by: jan-christopher.bals.uni-paderborn.de
Hi!
I´m looking for maven plugin which generates uml class diagrams from
source code during the maven build lifecycle.
Is it possible to use modisco for that?
I read something about running eclipse plugins headless (invoked via
command line).
Now i wonder if it is possible to write a maven plugin which invokes a
headless eclipse plugin which uses the modisco plugin.
best regards
Jan
Re: Modisco standalone [message #658630 is a reply to message #658261] Wed, 09 March 2011 05:16 Go to previous messageGo to next message
yes it is possible to implement and launch some
org.eclipse.equinox.app.IApplication which will reference and invoke
MoDisco plugins. Some internet search will describe you this
IApplication framework.
You may browse MoDisco components Help (Help content or wiki
http://wiki.eclipse.org/MoDisco/Components) to know more about Java API.
About discoverers, each MoDisco discoverer responds to a normalized
interface and can be called programmatically (see
org.eclipse.gmt.modisco.infra.discoverymanager.Discoverer).
As an example, you may checkout the code from
org.eclipse.gmt.modisco.java.discoverer.tests project.
About Java source analysis, the MoDisco Java discoverer (and derived
discoverers such as transformations to KDM and UML) requires that the
source code is managed into one eclipse workspace project.
I hope it well help you to start.
Fabien.
Re: Modisco standalone [message #1106233 is a reply to message #658630] Tue, 10 September 2013 17:34 Go to previous message
Does it mean basically that I can not get a model of a Java file in a standalone application? Do I need a running Eclipse (perphaps headless)?
Previous Topic:Creating a Java Class Programmatically by means of Java Model
Next Topic:Modisco excluded elements regex
Current Time: Fri Jul 25 22:48:29 EDT 2025
Powered by FUDForum. Page generated in 0.07841 seconds
