Home » Eclipse Projects » JFace » DataBinding for a combobox which holds a Elist from a model
DataBinding for a combobox which holds a Elist from a model [message #658009] Fri, 04 March 2011 18:23 Go to next message
Hi to all,
I want to implement a master-detail (list and detaileditor) which contains a combobox.
There is shown a list of recipients in the list.
in the combobox there is shown a reference in the Recipient-class with the name master, which references another recipient from the list. This should be selected with the combobox.
Now I want to implement a databinding, but don't know how to do this. My code leads to an
java.lang.NoSuchMethodException: org.eclipse.aid.model.Aid.impl.RecipientImpl.addPropertyChan geListener(java.beans.PropertyChangeListener)
at java.lang.Class.getMethod(Class.java:1622)
at org.eclipse.core.internal.databinding.beans.BeanPropertyList enerSupport.processListener(BeanPropertyListenerSupport.java :96)
at org.eclipse.core.internal.databinding.beans.BeanPropertyList enerSupport.hookListener(BeanPropertyListenerSupport.java:44 )
at org.eclipse.core.internal.databinding.beans.BeanPropertyList ener.doAddTo(BeanPropertyListener.java:56)
at org.eclipse.core.databinding.property.NativePropertyListener .addTo(NativePropertyListener.java:41)
at org.eclipse.core.internal.databinding.property.value.SimpleP ropertyObservableValue$3.run(SimplePropertyObservableValue.j ava:83)
at org.eclipse.core.databinding.observable.Realm$1.run(Realm.ja va:148)
at org.eclipse.core.databinding.observable.Realm.safeRun(Realm. java:152)
at org.eclipse.core.databinding.observable.Realm.exec(Realm.jav a:170)
This is my code: (tabViewerRec = Table of items, cmbMaster is combobox that should contain the selection
widgetValue = WidgetProperties.selection().observe(cmbMaster);
selection = ViewersObservables.observeSingleSelection(tabViewerRec);
modelValue = BeansObservables.observeDetailValue(selection, "master", Recipient.class);
bindingContext.bindValue(widgetValue, modelValue);
Would be nice, if you could help me
Best regards
Markus
[Updated on: Fri, 04 March 2011 18:23] by Moderator
Re: DataBinding for a combobox which holds a Elist from a model [message #658011 is a reply to message #658009] Fri, 04 March 2011 19:18 Go to previous messageGo to next message
Markus,
Shouldn't you be using the EMFObservables or EMFEditObservables rather
than the Bean one?
Markus Oley wrote:
> Hi to all,
> contains a combobox. There is shown a list of recipients in the list.
> My code leads to an
> va:148)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> java:152)
> a:170)
> selection =
Re: DataBinding for a combobox which holds a Elist from a model [message #658029 is a reply to message #658011] Sat, 05 March 2011 03:50 Go to previous messageGo to next message
Hi Ed,
thank you for your fast answer.
These are my first steps with the combination of JFace/EMF and I'm new to JFace-Databinding.
So it is in all propability that my approach is wrong.
Do you have a codesnippet somewhere, where this problem is solved? Or a tutorial how to use JFace-Databinding together with EMF? Would be very helpful.
Thanks by now,
Best regards
Markus
Re: DataBinding for a combobox which holds a Elist from a model [message #658058 is a reply to message #658029] Sat, 05 March 2011 12:01 Go to previous messageGo to next message
--------------010706010903090601020501
Markus,
Googling "EMF Databinding" turns up a bunch of good sources of
information including
http://tomsondev.bestsolution.at/2009/06/06/galileo-emf-data binding-part-1/
Markus Oley wrote:
> Hi Ed,
> thank you for your fast answer. These are my first steps with the
> So it is in all propability that my approach is wrong. Do you have a
> Thanks by now,
> Best regards
> Markus
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Markus,<br>
<br>
information including<br>
<blockquote><a
href=" http://tomsondev.bestsolution.at/2009/06/06/galileo-emf-data binding-part-1/"> http://tomsondev.bestsolution.at/2009/06/06/galileo-emf-data binding-part-1/</a><br>
</blockquote>
<br>
Markus Oley wrote:
<blockquote cite="mid:ikst4a$t4k$1@news.eclipse.org" type="cite">Hi Ed,
<br>
combination of JFace/EMF and I'm new to JFace-Databinding. <br>
<br>
<br>
Thanks by now, <br>
Best regards
<br>
Markus
<br>
</blockquote>
</body>
</html>
--------------010706010903090601020501--
Re: DataBinding for a combobox which holds a Elist from a model [message #658065 is a reply to message #658058] Sat, 05 March 2011 15:38 Go to previous messageGo to next message
OK, thank a lot... I will look
Re: DataBinding for a combobox which holds a Elist from a model [message #658069 is a reply to message #658058] Sat, 05 March 2011 17:37 Go to previous messageGo to next message
Hi Ed,
sorry, but these examples don't work for me, since the signatures of some methods changed. Could you please give me any further hints?
Thanks by now,
Markus
Re: DataBinding for a combobox which holds a Elist from a model [message #658099 is a reply to message #658058] Sun, 06 March 2011 07:26 Go to previous messageGo to next message
Hi again Ed,
experimenting a little bit, I found the solution (snippet below). The only problem is, that this is an attribute, which can be null. How can I fill an empty entry, which maps to null?
Best regards
Markus
Snippet:
IViewerObservableValue widgetValue2 = ViewersObservables.observeSingleSelection(comboviewer);
EStructuralFeature eStructuralFeature = recClass.getEStructuralFeature(AidPackage.RECIPIENT__MASTER) ;
IObservableValue modelValue = EMFObservables.observeDetailValue(Realm.getDefault(), selection, eStructuralFeature);
EMFEditObservables.observeDetailValue(Realm.getDefault(),
AdapterFactoryEditingDomain.getEditingDomainFor(currentRec),
modelValue, eStructuralFeature);
bindingContext.bindValue(widgetValue2, modelValue);
Re: DataBinding for a combobox which holds a Elist from a model [message #658110 is a reply to message #658099] Sun, 06 March 2011 11:15 Go to previous messageGo to next message
Markus,
Comments below.
Markus Oley wrote:
> Hi again Ed,
I'm not a data binding expert, so I don't really know what you're asking
specifically, but I do know that in general, making a distinction
between null and the empty string is problematic in text widgets. It
seems a general problem but there is no general solution. It's just an
additional state that's not well represented by just a text widget.
> Best regards Markus
> Snippet:
There's AidPackage.Literals.RECIPIENT__MASTER already available.
Re: DataBinding for a combobox which holds a Elist from a model [message #658213 is a reply to message #658110] Mon, 07 March 2011 07:36 Go to previous messageGo to next message
Hi Ed,
OK, thank you
Re: DataBinding for a combobox which holds a Elist from a model [message #658219 is a reply to message #658213] Mon, 07 March 2011 08:00 Go to previous message
The null conversion is something your IConverter has to handle. So you
need to use the bindValue() method which accepts 4 params.
It's also not clear from your code if you are using an
EMFDatabindingContext or DatabindingContext. Make sure you use the
EMFDatabindingContext!
Tom
Am 07.03.11 13:36, schrieb Markus Oley:
> Hi Ed,
> OK, thank you
Previous Topic:Data Binding for Android?
Next Topic:[databinding] JUnit tests, howto ?
Current Time: Fri Jul 25 07:31:22 EDT 2025
Powered by FUDForum. Page generated in 0.05123 seconds
