Home » Eclipse Projects » JFace » DataBinding for a combobox which holds a Elist from a model
DataBinding for a combobox which holds a Elist from a model [message #658009] |
Fri, 04 March 2011 18:23  |
Hi to all,
I want to implement a master-detail (list and detaileditor) which contains a combobox.
There is shown a list of recipients in the list.
in the combobox there is shown a reference in the Recipient-class with the name master, which references another recipient from the list. This should be selected with the combobox.
Now I want to implement a databinding, but don't know how to do this. My code leads to an
java.lang.NoSuchMethodException: org.eclipse.aid.model.Aid.impl.RecipientImpl.addPropertyChan geListener(java.beans.PropertyChangeListener)
at java.lang.Class.getMethod(Class.java:1622)
at org.eclipse.core.internal.databinding.beans.BeanPropertyList enerSupport.processListener(BeanPropertyListenerSupport.java :96)
at org.eclipse.core.internal.databinding.beans.BeanPropertyList enerSupport.hookListener(BeanPropertyListenerSupport.java:44 )
at org.eclipse.core.internal.databinding.beans.BeanPropertyList ener.doAddTo(BeanPropertyListener.java:56)
at org.eclipse.core.databinding.property.NativePropertyListener .addTo(NativePropertyListener.java:41)
at org.eclipse.core.internal.databinding.property.value.SimpleP ropertyObservableValue$3.run(SimplePropertyObservableValue.j ava:83)
at org.eclipse.core.databinding.observable.Realm$1.run(Realm.ja va:148)
at org.eclipse.core.databinding.observable.Realm.safeRun(Realm. java:152)
at org.eclipse.core.databinding.observable.Realm.exec(Realm.jav a:170)
This is my code: (tabViewerRec = Table of items, cmbMaster is combobox that should contain the selection
widgetValue = WidgetProperties.selection().observe(cmbMaster);
selection = ViewersObservables.observeSingleSelection(tabViewerRec);
modelValue = BeansObservables.observeDetailValue(selection, "master", Recipient.class);
bindingContext.bindValue(widgetValue, modelValue);
Would be nice, if you could help me
Best regards
Markus
[Updated on: Fri, 04 March 2011 18:23] by Moderator
Re: DataBinding for a combobox which holds a Elist from a model [message #658099 is a reply to message #658058] |
Sun, 06 March 2011 07:26   |
Hi again Ed,
experimenting a little bit, I found the solution (snippet below). The only problem is, that this is an attribute, which can be null. How can I fill an empty entry, which maps to null?
Best regards
Markus
Snippet:
IViewerObservableValue widgetValue2 = ViewersObservables.observeSingleSelection(comboviewer);
EStructuralFeature eStructuralFeature = recClass.getEStructuralFeature(AidPackage.RECIPIENT__MASTER) ;
IObservableValue modelValue = EMFObservables.observeDetailValue(Realm.getDefault(), selection, eStructuralFeature);
EMFEditObservables.observeDetailValue(Realm.getDefault(),
AdapterFactoryEditingDomain.getEditingDomainFor(currentRec),
modelValue, eStructuralFeature);
bindingContext.bindValue(widgetValue2, modelValue);
Re: DataBinding for a combobox which holds a Elist from a model [message #658110 is a reply to message #658099] |
Sun, 06 March 2011 11:15   |
Markus,
Comments below.
Markus Oley wrote:
> Hi again Ed,
I'm not a data binding expert, so I don't really know what you're asking
specifically, but I do know that in general, making a distinction
between null and the empty string is problematic in text widgets. It
seems a general problem but there is no general solution. It's just an
additional state that's not well represented by just a text widget.
> Best regards Markus
> Snippet:
There's AidPackage.Literals.RECIPIENT__MASTER already available.
Re: DataBinding for a combobox which holds a Elist from a model [message #658219 is a reply to message #658213] |
Mon, 07 March 2011 08:00  |
The null conversion is something your IConverter has to handle. So you
need to use the bindValue() method which accepts 4 params.
It's also not clear from your code if you are using an
EMFDatabindingContext or DatabindingContext. Make sure you use the
EMFDatabindingContext!
Tom
Am 07.03.11 13:36, schrieb Markus Oley:
> Hi Ed,
> OK, thank you
Current Time: Sat Jul 26 17:05:16 EDT 2025
Powered by FUDForum. Page generated in 0.04596 seconds
