Home » Eclipse Projects » EclipseLink » Help on caching needed(how to setup eclipselink when it is used to access the same database in separate web apps?)
Help on caching needed [message #658131] Sun, 06 March 2011 16:21 Go to next message
Dear all,
I have three webapps A, B and C. They all rely on EclipseLink 2.1.2 to persist some entities (C actually just need to read data from the database, it does not modify it).
Each webapp is deployed separately in the servlet container (Tomcat).
(We are not in the context of JEE here, there is no way to deploy an ear with those webapps.)
My problem is the following: if I change the content of the database with one app, then the other apps do not see immediately the changes.
I guess that this is due to the default caching behavior.
http://wiki.eclipse.org/Introduction_to_Cache_%28ELUG%29
What is the best solution to deal with that problem?
Re: Help on caching needed [message #658150 is a reply to message #658131] Mon, 07 March 2011 01:50 Go to previous messageGo to next message
I have the same problem with running separate fat clients; you need to disable the 2nd level cache. I will be at work in about an hour and can give you the code if you want.
Tom
On 6-3-2011 22:21, Daniel Le Berre wrote:
> Dear all,
Re: Help on caching needed [message #658173 is a reply to message #658131] Mon, 07 March 2011 04:37 Go to previous messageGo to next message
Here it is
lOptions.put(PersistenceUnitProperties.CACHE_SHARED_DEFAULT, "false"); // do not use the shared cache (otherwise refresh will not update from db)
> Dear all,
Re: Help on caching needed [message #658188 is a reply to message #658173] Mon, 07 March 2011 05:35 Go to previous message
Many thanks Tom!
Previous Topic:java.lang.SecurityException: signer information does not match signer information of other classes i
Next Topic:Eclipselink and Grails
Current Time: Fri Jul 25 23:09:33 EDT 2025
Powered by FUDForum. Page generated in 0.05198 seconds
