Re: EMF load resource with different namespaces (prefixes) [message #657675 is a reply to message #657571] |
Thu, 03 March 2011 10:52   |
Stephan,
Comments below.
Stephan Krusche wrote:
> I have two xsd files, both in the same folder:
> model.xsd
> <xs:schema xmlns:model2="http://www.ns.com/model2"
> xmlns:xs="http://www.w3.org/2001/XMLSchema"
> xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
> elementFormDefault="qualified" ecore:package="mytool.model.model"
> ecore:documentRoot="Model">
> <xs:import namespace="http://www.ns.com/model2"
> schemaLocation="model2.xsd"/>
> <xs:element name="attribute">
> <xs:complexType>
> <xs:sequence>
> <xs:element ref="model2:model2element"/>
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> </xs:schema>
> model2.xsd
> <xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
> targetNamespace="http://www.ns.com/model2"
> ecore:package="mytool.model.model2" ecore:documentRoot="Model2">
> <xs:element name="model2element">
> <xs:complexType>
> <xs:sequence>
> <xs:element ref="model2:name" minOccurs="1"
> maxOccurs="unbounded"/>
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> <xs:element name="name" type="xs:string"/>
> </xs:schema>
> I generated two corresponding ecore files and a genmodel with that and
> I also generated the Java model code. So far no problems.
Looks like a problem to me. There's both one logical schema (there's
only one targetNamespace) split across to resources.
> Now I want to load the following xml file:
> modelfile.xml
> <?xml version="1.0" encoding="UTF-8" standalone="no"?>
> <attribute>
> <model2:model2element>
> <model2:name>testString</model2:name>
> </model2:model2element>
> </attribute>
> with the following Java code:
> private void load(IFile selectedFile) {
> //File modelXmlFile = new File("modelfile.xml");
> ResourceSet resourceSet = new ResourceSetImpl();
> resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put( "xml",
> new ModelResourceFactoryImpl());
> java.net.URI uri = selectedFile.getLocationURI();
> URI fileUri = URI.createURI(uri.toString(), true);
> XMLResource resource = null;
> try {
> resource = (XMLResource) resourceSet.createResource(fileUri);
> resourceSet.getPackageRegistry().put(ModelPackage.eNS_URI,
> ModelPackage.eINSTANCE);
> resourceSet.getPackageRegistry().put(Model2Package.eNS_URI,
> Model2Package.eINSTANCE);
> resource.load(null);
> } catch (Exception ex) {
> ex.printStackTrace();
> resourceSet.getResources().add(resource);
> Model myModel = (Model) resource.getContents().get(0);
> System.out.println(myModel);
> But I get the following exception:
> org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Feature
> 'model2element' not found.
> (file:/D:/test/runtime-EclipseApplication/test/modelfile.xml , 3, 24)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.handleErrors(XMLL oadImpl.java:83)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:191)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1494)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1282)
> at mytool.ui.popup.actions.NewAction.load(NewAction.java:75)
> I assume that I somehow must register the prefix of the second
> factory, but I don't know how :(
> What is wrong?
You can't have more than one package with the same namespace. You need
to generate one package from the two schemas.
> Thank you for help!
Re: EMF load resource with different namespaces (prefixes) [message #658120 is a reply to message #658118] |
Sun, 06 March 2011 13:03   |
--------------020701040302030007080001
Stephan,
Comments below.
> Ed Merks wrote on Thu, 03 March 2011 10:52
> How can I achieve this?
> I read that xml schema can only have one namespace per schema file, so
> I need two schema files.
Oh, sorry I misread them as having the same target namespace. I see now
one has a target namespace and the other doesn't.
> When I use the New EMF Generator Model wizard and choose XML Schema in
> the Model Importers page, always two ecore files and two packages are
> generated... Is there any trick that only one package will be generated?
You say you want to read
<attribute>
</attribute>
but that's not a valid instance. I think you meant this, right?
<attribute xmlns:model2="http://www.ns.com/model2">
</attribute>
> Thank you!
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Stephan,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:il0g5c$efq$1@news.eclipse.org" type="cite">Ed
<br>
<blockquote type="cite">You can't have more than one package with the
<br>
<br>
</blockquote>
<br>
<br>
How can I achieve this? <br>
I need two schema files. </blockquote>
now one has a target namespace and the other doesn't.<br>
<blockquote cite="mid:il0g5c$efq$1@news.eclipse.org" type="cite">When I
use the New EMF Generator Model wizard and choose XML Schema in the
generated?
<br>
</blockquote>
You say you want to read <br>
<br>
<br>
<attribute>
<br>
<br>
<model2:name>testString</model2:name&am p;gt;
<br>
<br>
</attribute>
<br>
<br>
but that's not a valid instance. I think you meant this, right?<br>
<blockquote><?xml version="1.0" encoding="UTF-8"
standalone="no"?>
<br>
<attribute xmlns:model2=<a class="moz-txt-link-rfc2396E"
href="http://www.ns.com/model2">"http://www.ns.com/model2</a>">
<br>
<br>
<br>
<br>
</attribute>
<br>
</blockquote>
<blockquote cite="mid:il0g5c$efq$1@news.eclipse.org" type="cite"><br>
Thank you!
<br>
</blockquote>
</body>
</html>
--------------020701040302030007080001--
Re: EMF load resource with different namespaces (prefixes) [message #662021 is a reply to message #662001] |
Mon, 28 March 2011 18:30  |
Stephan,
Write a schema to which this XML conforms and generate the Ecore model
corresponding to that. My blog shows how to make use of substitution
groups if you need them. I assume you're not just asking me to write
the schema for you...
> Hello Ed,
> I start with the following xml:
> <?xml version="1.0" encoding="UTF-8" standalone="yes"?>
> <model1element xmlns:model2="urn:/a/b/c-section">
> </model1element>
> This is delivered by the customer and cannot be modified. My goal is
> to deserialize it with EMF into Java objects to be able to use it for
> further M2M and M2T transformations.
> In the xsd and ecore creation I am free as long as I can load the
> given xml.
> So how must the xsd look like that I can generate valid ecore and that
> the deserialization into Java objects works without problems?
> Thank you
> Stephan
FUDForum. Page generated in 0.27229 seconds
