Home » Modeling » EMF » [CDO] since API breakage occurred since version 3.0.0.v20100618-1451
[CDO] since API breakage occurred since version 3.0.0.v20100618-1451 [message #658043] |
Sat, 05 March 2011 07:47  |
I have follow the guide on http://wiki.eclipse.org/CDO_Source_Installation, after done, I got the following errors(I have tried clean all projects):
Description Resource Path Location Type
The major version should be incremented in version 0.2.0.qualifier, since API breakage occurred since version 0.2.0.v20100618-1452 MANIFEST.MF /org.eclipse.emf.cdo.dawn.examples.acore/META-INF line 5 Version Numbering Problem
The major version should be incremented in version 3.0.0.qualifier, since API breakage occurred since version 3.0.0.v20100618-1451 MANIFEST.MF /org.eclipse.emf.cdo.defs/META-INF line 5 Version Numbering Problem
The major version should be incremented in version 3.0.0.qualifier, since API breakage occurred since version 3.0.0.v20100618-1452 MANIFEST.MF /org.eclipse.emf.cdo.edit/META-INF line 4 Version Numbering Problem
The major version should be incremented in version 3.0.0.qualifier, since API breakage occurred since version 3.0.0.v20100618-1452 MANIFEST.MF /org.eclipse.emf.cdo.examples.company/META-INF line 4 Version Numbering Problem
The major version should be incremented in version 3.0.0.qualifier, since API breakage occurred since version 3.0.0.v20100618-1452 MANIFEST.MF /org.eclipse.emf.cdo.examples/META-INF line 4 Version Numbering Problem
The major version should be incremented in version 3.0.0.qualifier, since API breakage occurred since version 3.0.0.v20100618-1453 MANIFEST.MF /org.eclipse.emf.cdo.team/META-INF line 4 Version Numbering Problem
The major version should be incremented in version 3.0.0.qualifier, since API breakage occurred since version 3.0.0.v20100618-1453 MANIFEST.MF /org.eclipse.emf.cdo.ui/META-INF line 5 Version Numbering Problem
The major version should be incremented in version 3.0.0.qualifier, since API breakage occurred since version 3.0.1.v20100706-1131 MANIFEST.MF /org.eclipse.emf.cdo.server/META-INF line 4 Version Numbering Problem
The major version should be incremented in version 3.0.1.qualifier, since API breakage occurred since version 3.0.0.v20100618-1453 MANIFEST.MF /org.gastro.inventory/META-INF line 5 Version Numbering Problem
The major version should be incremented in version 3.0.1.qualifier, since API breakage occurred since version 3.0.1.v20100809-1025 MANIFEST.MF /org.eclipse.emf.cdo.net4j/META-INF line 5 Version Numbering Problem
The major version should be incremented in version 3.0.1.qualifier, since API breakage occurred since version 3.0.1.v20100911-0901 MANIFEST.MF /org.eclipse.emf.cdo/META-INF line 5 Version Numbering Problem
The major version should be incremented in version 3.0.2.qualifier, since API breakage occurred since version 3.0.0.v20100618-1453 MANIFEST.MF /org.gastro.business/META-INF line 5 Version Numbering Problem
The method org.eclipse.emf.cdo.session.CDOSession.getView(int) has been removed CDOSession.java /org.eclipse.emf.cdo/src/org/eclipse/emf/cdo/session line 55 Compatibility Problem
The re-exported type org.eclipse.emf.internal.cdo.CDOObjectReferenceImpl has been removed from org.eclipse.emf.cdo.dawn.examples.acore_0.2.0 MANIFEST.MF /org.eclipse.emf.cdo.dawn.examples.acore/META-INF line 1 Compatibility Problem
The re-exported type org.eclipse.emf.internal.cdo.CDOObjectReferenceImpl has been removed from org.eclipse.emf.cdo.defs_3.0.0 MANIFEST.MF /org.eclipse.emf.cdo.defs/META-INF line 1 Compatibility Problem
The re-exported type org.eclipse.emf.internal.cdo.CDOObjectReferenceImpl has been removed from org.eclipse.emf.cdo.edit_3.0.0 MANIFEST.MF /org.eclipse.emf.cdo.edit/META-INF line 1 Compatibility Problem
The re-exported type org.eclipse.emf.internal.cdo.CDOObjectReferenceImpl has been removed from org.eclipse.emf.cdo.examples_3.0.0 MANIFEST.MF /org.eclipse.emf.cdo.examples/META-INF line 1 Compatibility Problem
The re-exported type org.eclipse.emf.internal.cdo.CDOObjectReferenceImpl has been removed from org.eclipse.emf.cdo.examples.company_3.0.0 MANIFEST.MF /org.eclipse.emf.cdo.examples.company/META-INF line 1 Compatibility Problem
The re-exported type org.eclipse.emf.internal.cdo.CDOObjectReferenceImpl has been removed from org.eclipse.emf.cdo.net4j_3.0.1 MANIFEST.MF /org.eclipse.emf.cdo.net4j/META-INF line 1 Compatibility Problem
The re-exported type org.eclipse.emf.internal.cdo.CDOObjectReferenceImpl has been removed from org.eclipse.emf.cdo.server_3.0.1 MANIFEST.MF /org.eclipse.emf.cdo.server/META-INF line 1 Compatibility Problem
The re-exported type org.eclipse.emf.internal.cdo.CDOObjectReferenceImpl has been removed from org.eclipse.emf.cdo.team_3.0.0 MANIFEST.MF /org.eclipse.emf.cdo.team/META-INF line 1 Compatibility Problem
The re-exported type org.eclipse.emf.internal.cdo.CDOObjectReferenceImpl has been removed from org.eclipse.emf.cdo.ui_3.0.0 MANIFEST.MF /org.eclipse.emf.cdo.ui/META-INF line 1 Compatibility Problem
The re-exported type org.eclipse.emf.internal.cdo.CDOObjectReferenceImpl has been removed from org.gastro.business_3.0.0 MANIFEST.MF /org.gastro.business/META-INF line 1 Compatibility Problem
The re-exported type org.eclipse.emf.internal.cdo.CDOObjectReferenceImpl has been removed from org.gastro.inventory_3.0.0 MANIFEST.MF /org.gastro.inventory/META-INF line 1 Compatibility Problem
The type org.eclipse.emf.internal.cdo.CDOObjectReferenceImpl has been removed from org.eclipse.emf.cdo_3.0.1 MANIFEST.MF /org.eclipse.emf.cdo/META-INF line 1 Compatibility Problem
Re: [CDO] since API breakage occurred since version 3.0.0.v20100618-1451 [message #658050 is a reply to message #658043] |
Sat, 05 March 2011 11:11   |
Yau,
The class in question,
org.eclipse.emf.internal.cdo.CDOObjectReferenceImpl, is named internal,
so I don't imagine it should be considered API. Note that you can
change your preferences to make these warnings or to ignore them.
> Numbering Problem
> Numbering Problem
> Numbering Problem
> Numbering Problem
> Numbering Problem
> Numbering Problem
> Numbering Problem
Re: [CDO] since API breakage occurred since version 3.0.0.v20100618-1451 [message #658059 is a reply to message #658043] |
Sat, 05 March 2011 12:45  |
Sorry, I have no clue what's going on there. As Ed pointed out, CDOObjectReferenceImpl is an internal class and is not ecported from its plugin. API Tools should really not complain about it.
Cheers
/Eike
http://www.esc-net.de
Am 05.03.2011 13:47, schrieb Yau:
Current Time: Sun Jul 27 02:08:43 EDT 2025
Powered by FUDForum. Page generated in 0.04666 seconds
