code completion for OLE/COM-objects? [message #657988] |
Fri, 04 March 2011 14:43  |
I'm looking for a way to get code completion for OLE/COM-objects.
example:
<?php
// start word
$word = new COM("word.application");
//show word
$word->Visible = 1;
//add empty document
$word->Documents->Add();
//insert some text
$word->Selection->TypeText("some text.");
//clear object
$word = null;
It would be nice to get code completion for (in this case/example) the word object model.
I'm familiar with developing VBA 'scripts' for different applications, and I'm also familiar with PHP.
When using the Excel scripting editor it's possible to get code completion by referencing the type libraries of the other application you want to access via OLE/COM.
Is there a way to do this in Eclipse?
Re: code completion for OLE/COM-objects? [message #658021 is a reply to message #657988] |
Sat, 05 March 2011 00:52  |
Definitely no.
You need definition files (like files under PHP Language Library) for code completion.
For example, (note that it is basic steps)
1. Create typeinfo file
Run this script and redirect output to file as wordobj.php.
<?php
$obj=new COM("word.application");
com_print_typeinfo($obj,"_Application");
com_print_typeinfo($obj,"Documents");
com_print_typeinfo($obj,"Selection");
// add all IDispatch you need
// but there are about 200 IDispatch...
2. Edit wordobj.php
Add "<?php" tag.
Fix syntax error. (Selection::GoTo to Selection::_GoTo)
Add type declaration for properties.
> /* DISPID=6 */
> /* VT_PTR [26] */
> var $Documents;
to
> /* DISPID=6 */
> /* VT_PTR [26] */
> * @var Documents $Documents
> var $Documents;
also
> /* DISPID=5 */
> /* VT_PTR [26] */
> var $Selection;
to
> /* DISPID=5 */
> /* VT_PTR [26] */
> * @var Selection $Section
> var $Selection;
(other properties as well...)
3. Test
Move wordobj.php into your php project.
Edit your script, insert type declaration for pdt as
>/* @var $word _Application */
>$word->
Test if code completion will work.
4. Create Library
Create folder for library somewhere and move typeinfo file.
Go to Preferences>PHP>PHP Libraries, Add new library, Add external folder.
5. Add Library to Project
Add the Library to PHP Include Path>Libraries.
(sorry for rough explanation)
FUDForum. Page generated in 0.27260 seconds
