Home » Archived » M2M (model-to-model transformation) » [QVTO] Cannot modify resource set without a write transaction
[QVTO] Cannot modify resource set without a write transaction [message #657332] Wed, 02 March 2011 08:33 Go to next message
Hi all!
I'm running a qvto transformation programmatically following the example transformation in http://wiki.eclipse.org/QVTOML/Examples/InvokeInJava.
It worked fine until I changed the transformation to accepts an inout model and a in model (previously it was like the example an, in model and a out model)
When I execute it, it complains with the following error:
source=org.eclipse.m2m.qvt.oml.execution code=120 Unexpected runtime exception caught during execution data=[java.lang.IllegalStateException: Cannot modify resource set without a write transaction]
I tried to execute it inside a Command via the CommandStack.execute() but the error is still the same.
Is there a solution?
Re: [QVTO] Cannot modify resource set without a write transaction [message #657592 is a reply to message #657332] Thu, 03 March 2011 06:55 Go to previous messageGo to next message
Since the in-place transformation (with an INOUT parameter) works well when I execute it directly from the Run menu, I tried to execute directly the code which is called via the QvtLaunchConfigurationDelegateBase class.
After some debugging I found that I need to declare my transformation in an extension point since when at some point the DeployedQvtModule.getModule() method is called (precisely at unitResolver.resolveDeployedUnitOnly(moduleID)) it raises an exception since my transformation is not found.
Unfortunately even if my transformation is stored in the BundleModuleRegistry the following conditions does not hold in anyway
public CFile resolveImport(String importedUnitName) {
		if(importedUnitName == null || importedUnitName.length() == 0) {
			return null;
		IPath fullPath = new Path(importedUnitName.replace('.', '/') + MDAConstants.QVTO_FILE_EXTENSION_WITH_DOT);
		for (BundleModuleRegistry nextRegistry : bundleModules) {
			if (importedUnitName.indexOf(nextRegistry.getBundleSymbolicName()) == 1) {
				fullPath = new Path(importedUnitName.substring(nextRegistry.getBundleSymbolicName().length()+2));
			else if (importedUnitName.startsWith("/")) { //$NON-NLS-1$
				fullPath = new Path(importedUnitName.substring(1).replace('.', '/') + MDAConstants.QVTO_FILE_EXTENSION_WITH_DOT);
			if (nextRegistry.fileExists(fullPath)) {
				return new BundleFile(fullPath, nextRegistry);
		return resolveResourcePluginPath(importedUnitName);
My importedUnitName is in the form
/bundleentry://1172.fwk5285449/transformations/my_transforma tion.qvto. I would match if was in the form /my_transformation.qvto, but it never can't be, no matter if I try to define the transformation with a different URI since it is instantiated correcly only if I pass a Platform URI in the following line of code:
QvtModule m = org.eclipse.m2m.internal.qvt.oml.runtime.project.TransformationUtil.getQvtModule(transformationPlURI);
I there a salution? Perhasp it there a cleaner way to call an in-place QVT-o transformation in java?
Re: [QVTO] Cannot modify resource set without a write transaction [message #657625 is a reply to message #657592] Thu, 03 March 2011 09:05 Go to previous messageGo to next message
With a dirty trick I managed to solve this problem, however after some computations the transformation complains again with the usual exception: Cannot modify resource set without a write transaction
I really don't know what I'm doing wrong Sad
Re: [QVTO] Cannot modify resource set without a write transaction [message #657826 is a reply to message #657625] Fri, 04 March 2011 04:06 Go to previous messageGo to next message
Originally posted by: koen.yskout.cs.kuleuven.be
Alex,
It looks like the model/resource on which you are trying to execute the
transformation is transactional (e.g., part of a transactional editing
domain). Are you feeding the transformation with a model from some
opened editor (GMF?) ?
This might explain while it works well with an in/out model: the
original (transactional) model is never modified.
I guess you need to obtain the (transactional) editing domain and create
a command that executes your transformation (see for example
http://wiki.eclipse.org/Graphical_Modeling_Framework/Tips#Cr eate_New_Elements_Using_RecordingCommand_and_CanonicalEditPo licies),
although you said in your initial post that you have tried this already...
If you do something else in the command than executing the
transformation (like changing the name of the model root or so), does
that work?
I'm sorry not to be of any more help,
Koen
> I really don't know what I'm doing wrong :(
Re: [QVTO] Cannot modify resource set without a write transaction [message #657973 is a reply to message #657826] Fri, 04 March 2011 13:45 Go to previous message
Thanks Koen!
I manage to solve the problem thanks to your suggestion.
I've created a new ResourceSet different from the one of editor and now the transformation works with the code from the example invocation!
Previous Topic:[ATL] Latest ATL Metamodel in KM3 Format
Next Topic:[QVTo] Is it possible to use blackbox libraries when running standalone?
Current Time: Mon Jul 28 11:27:13 EDT 2025
Powered by FUDForum. Page generated in 0.36373 seconds
