Home » Eclipse Projects » Eclipse Platform » Filelocator not working in exe
Filelocator not working in exe [message #657838] Fri, 04 March 2011 05:02 Go to next message
i want to get the os location of a file in one my plugins
when i run the code in eclipse environment it works fine but when i export my product as exe it fails
here is my code snippet
Bundle bundle=Platform.getBundle("com.genesyslabs.sipserver.mist.generator");
		if(bundle!=null)
		System.out.println("\n bundle:"+bundle.getSymbolicName()+"\n");
		IPath pt=new Path("src/workflow/generator.oaw");
		URL url = FileLocator.find(bundle,pt, null);
		String wfFile = "";
		System.err.println("\n wFUrl"+"\n");
		String srcgen="/C:/";
		 try  	{
			 if(url!=null)
				 URL fileURL = FileLocator.toFileURL(url);
				 wfFile=fileURL.getFile().toString();
				 System.out.println("\nurl:"+url.getPath()+"\n");
				 System.out.println("\n wfFile:"+wfFile+"\n");
				else
					System.out.println("\n url:"+"could not  get the url"+"\n");
					wfFile="C:\\Documents and Settings\\rtiragat\\dummy workspace\\com.genesyslabs.sipserver.mist.generator\\src\\workflow\\generator.oaw";
					System.out.println("\n using the default hard coded workflow location \n");
in url variable is null i.e url is not pointing to any object when i execute it as an exe in win32
please give me a way how i can get the os location of the file
Ravi
Re: Filelocator not working in exe [message #657859 is a reply to message #657838] Fri, 04 March 2011 06:30 Go to previous messageGo to next message
The src folder will not be available when you export your bundle. You
should give the relative path within the jar.
- Prakash
Platform UI Team, IBM
www.eclipse-tips.com
Re: Filelocator not working in exe [message #657897 is a reply to message #657859] Fri, 04 March 2011 09:41 Go to previous messageGo to next message
Hi prakash
Thanks for replying
i didn't include the src folder in the binary build of the required plug in so i was not able to get the location
Ravi
Re: Filelocator not working in exe [message #657901 is a reply to message #657897] Fri, 04 March 2011 09:49 Go to previous message
On 03/04/2011 09:41 AM, Ravi Kiran wrote:
> Hi prakash
> Thanks for replying
That's not a good idea or generally accepted practice.
Files in your <project>/src directory are considered standard java
resources. You would access them using:
class.getResourceAsStream("/workflow/generator.oaw"); or simply
class.getResource(*)
That won't change while running in eclipse or once it is deployed.
bundle-type resources are accessed through Bundle.getEntry(*). i.e. if
you have <project>/icons that you include in your bundle from your
build.properties. They are a good candidate for
FileLocator.toFileURL(*), as they are not available through
class.getResourceAsStream(*). As they're available from the root of
your project, Bundle.getEntry(*) will work both inside eclipse and once
it is deployed.
You should look at your generator.oaw file and decide what kind of
support you need. If you can simply make it a java resource, go for it.
If not, then consider placing it similar to how icons are provided in
most eclipse plugins.
Later,
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Previous Topic:How to set the Editor size?
Next Topic:Helios Internal browser fails for JSF - FireFox OK
Current Time: Sat Jul 19 04:29:45 EDT 2025
Powered by FUDForum. Page generated in 0.03504 seconds
