Home » Archived » M2M (model-to-model transformation) » [AML] How to manage inherited properties?
[AML] How to manage inherited properties? [message #656802] Mon, 28 February 2011 11:49 Go to next message
Hi all,
I'm trying AML, which is in my opinion a really powerful tool, and I'm facing a problem with inherited properties. Here are my metamodels
- Former metamodel:
http://yuml.me/6abb9760
- Evolved metamodel:
http://yuml.me/69bf53c3
The difference between the two models is the fact that the relation between a Net and its components is direct in the former metamodel whereas it is inherited in the second metamodel. When I try to generate an ATL transformation thanks to AML, the net property isn't copy from the source model...
So I'd like to know if there is a special strategy to use or not? I mean I use the migration strategy I found in the Model Adaptation example (http://www.eclipse.org/m2m/atl/usecases/ModelAdaptation/) and I obtain this transformation:
-- @atlcompiler atl2006
module m12m2;
create OUT : rightpetrinetv3 from IN : leftpetrinetv2;
rule Net_Net {
 from
  s : leftpetrinetv2!Net
   s.oclIsTypeOf(leftpetrinetv2!Net)
 to
  t : rightpetrinetv3!Net (
   name <- s.name
rule Place_Place {
 from
  s : leftpetrinetv2!Place
   s.oclIsTypeOf(leftpetrinetv2!Place)
 to
  t : rightpetrinetv3!Place (
   out <- s.out,
   in <- s.in,
   name <- s.name
rule Transition_Transition {
 from
  s : leftpetrinetv2!Transition
   s.oclIsTypeOf(leftpetrinetv2!Transition)
 to
  t : rightpetrinetv3!Transition (
   in <- s.in,
   out <- s.out,
   name <- s.name
rule PTArc_PTArc {
 from
  s : leftpetrinetv2!PTArc
   s.oclIsTypeOf(leftpetrinetv2!PTArc)
 to
  t : rightpetrinetv3!PTArc (
   src <- s.src,
   dst <- s.dst
rule TPArc_TPArc {
 from
  s : leftpetrinetv2!TPArc
   s.oclIsTypeOf(leftpetrinetv2!TPArc)
 to
  t : rightpetrinetv3!TPArc (
   dst <- s.dst,
   src <- s.src
The correct transformation should be something like:
rule Place_Place {
 from
 to
   out <- s.out,
   in <- s.in,
   name <- s.name,
   net <- s.net
Aurélien
[EDIT] image modifications in order to improve understandability
[Updated on: Wed, 02 March 2011 09:38] by Moderator
Re: [AML] How to manage inherited properties? [message #657310 is a reply to message #656802] Wed, 02 March 2011 06:54 Go to previous messageGo to next message
You question is a little confusing. Perhaps you should describe exactly what you feel is not being transformed in the evolved model. Do you mean the Net EClass has no reference to EClass NetElement? If so your rule Net_Net doesn't seem to instruct any such mapping.
Ronan
Re: [AML] How to manage inherited properties? [message #657358 is a reply to message #656802] Wed, 02 March 2011 09:46 Go to previous messageGo to next message
Well, what I'm trying to explain is the fact that the net:Net attribute from Place, Transition, PTArc and TPArc are not set by the generated transformation. This attribute is inherited from NetElement Class.
The generated rule Place_Place:
rule Place_Place {
 from
 to
   out <- s.out,
   in <- s.in,
   name <- s.name
The correct rule:
rule Place_Place {
 from
 to
   out <- s.out,
   in <- s.in,
   name <- s.name,
   net <- s.net
Re: [AML] How to manage inherited properties? [message #657851 is a reply to message #657358] Fri, 04 March 2011 05:45 Go to previous messageGo to next message
--------------030700070309040803020208
Hi Aurelien,
I think the matching strategy offered by the Adaptation use case is
appropiate to the pair of metamodels you present in the previous post.
However, you need to flat the superclasses properties prior to the
matching strategy execution. To do that you can use the attached
transformation. You should execute such a transformation twice (the
initial metamodel and the evolving version). The matching strategy will
take as input the flatten metamodels.
Kelly.
name="FlattenEcoreFeatures.atl"
filename="FlattenEcoreFeatures.atl"
LS0gQGF0bGNvbXBpbGVyIGF0bDIwMDYNCm1vZHVsZSBGbGF0dGVuS00zRmVh dHVyZXM7DQpj
cmVhdGUgT1VUIDogTWV0YW1ldGFtb2RlbCBmcm9tIElOIDogTWV0YW1ldGFt b2RlbDsNCg0K
dXNlcyBNZXRhbWV0YW1vZGVsOw0KdXNlcyBTdWl0YWJsZU1ldGFtZXRhbW9k ZWw7DQoNCi0t
cnVsZSBNZXRhbW9kZWwgew0KLS0JZnJvbQ0KLS0JCXMgOiBNZXRhbWV0YW1v ZGVsIUVNZXRh
bW9kZWwNCi0tCXRvDQotLQkJdCA6IE1ldGFtZXRhbW9kZWwhRU1ldGFtb2Rl bCAoDQotLQkJ
CWNvbnRlbnRzIDwtIHMuY29udGVudHMNCi0tCQkpDQotLX0NCg0KcnVsZSBQ YWNrYWdlIHsN
Cglmcm9tDQoJCXMgOiBNZXRhbWV0YW1vZGVsIUVQYWNrYWdlDQoJdG8NCgkJ dCA6IE1ldGFt
ZXRhbW9kZWwhRVBhY2thZ2UgKA0KCQkJbmFtZSA8LSBzLm5hbWUsDQoJCQll Q2xhc3NpZmll
cnMgPC0gcy5lQ2xhc3NpZmllcnMNCgkJKQ0KfQ0KDQotLXJ1bGUgRURhdGFU eXBlIHsNCi0t
CWZyb20NCi0tCQlzIDogTWV0YW1ldGFtb2RlbCFFRGF0YVR5cGUNCi0tCXRv DQotLQkJdCA6
IE1ldGFtZXRhbW9kZWwhRURhdGFUeXBlICgNCi0tCQkJbmFtZSA8LSBzLm5h bWUNCi0tCQkp
DQotLX0NCg0KcnVsZSBFbnVtZXJhdGlvbiB7DQoJZnJvbQ0KCQlzIDogTWV0 YW1ldGFtb2Rl
bCFFRW51bQ0KCXRvDQoJCXQgOiBNZXRhbWV0YW1vZGVsIUVFbnVtICgNCgkJ CW5hbWUgPC0g
cy5uYW1lLA0KCQkJZUxpdGVyYWxzIDwtIHMuZUxpdGVyYWxzDQoJCSkNCn0N Cg0KcnVsZSBF
bnVtTGl0ZXJhbCB7DQoJZnJvbQ0KCQlzIDogTWV0YW1ldGFtb2RlbCFFRW51 bUxpdGVyYWwN
Cgl0bw0KCQl0IDogTWV0YW1ldGFtb2RlbCFFRW51bUxpdGVyYWwgKA0KCQkJ bmFtZSA8LSBz
Lm5hbWUNCgkJKQ0KfQ0KDQpydWxlIENsYXNzIHsNCglmcm9tDQoJCXMgOiBN ZXRhbWV0YW1v
ZGVsIUVDbGFzcw0KCXRvDQoJCXQgOiBNZXRhbWV0YW1vZGVsIUVDbGFzcyAo DQoJCQkiYWJz
dHJhY3QiIDwtIHMuImFic3RyYWN0IiwNCgkJCW5hbWUgPC0gcy5uYW1lLA0K CQkJZVN1cGVy
VHlwZXMgPC0gcy5lU3VwZXJUeXBlcywNCgkJCWVTdHJ1Y3R1cmFsRmVhdHVy ZXMgPC0gdGhp
c01vZHVsZS5hbGxTdHJ1Y3R1cmFsRmVhdHVyZXMocyktPmNvbGxlY3QoZSB8 DQoJCQkJVHVw
bGUge3NmID0gZSwgY2wgPSBzfSkNCgkJKQ0KfQ0KDQphYnN0cmFjdCBydWxl IFN0cnVjdHVy
YWxGZWF0dXJlIHsNCglmcm9tDQoJCXNmIDogTWV0YW1ldGFtb2RlbCFFU3Ry dWN0dXJhbEZl
YXR1cmUsDQoJCWNsIDogTWV0YW1ldGFtb2RlbCFFQ2xhc3MgKA0KCQkJdGhp c01vZHVsZS5h
bGxTdHJ1Y3R1cmFsRmVhdHVyZXMoY2wpLT5pbmNsdWRlcyhzZikJDQoJCSkN Cgl0bw0KCQl0
IDogTWV0YW1ldGFtb2RlbCFFU3RydWN0dXJhbEZlYXR1cmUgKA0KCQkJbmFt ZSA8LSBzZi5u
YW1lLA0KCQkJbG93ZXJCb3VuZCA8LSBzZi5sb3dlckJvdW5kLA0KCQkJdXBw ZXJCb3VuZCA8
LSBzZi51cHBlckJvdW5kLA0KCQkJZVR5cGUgPC0gc2YuZVR5cGUNCgkJKQ0K fQ0KDQpydWxl
IEF0dHJpYnV0ZSBleHRlbmRzIFN0cnVjdHVyYWxGZWF0dXJlIHsNCglmcm9t DQoJCXNmIDog
TWV0YW1ldGFtb2RlbCFFQXR0cmlidXRlLA0KCQljbCA6IE1ldGFtZXRhbW9k ZWwhRUNsYXNz
IA0KCXRvDQoJCXQgOiBNZXRhbWV0YW1vZGVsIUVBdHRyaWJ1dGUgKA0KCQkJ InVuaXF1ZSIg
PC0gc2YuInVuaXF1ZSINCgkJKQ0KfQ0KDQpydWxlIFJlZmVyZW5jZSBleHRl bmRzIFN0cnVj
dHVyYWxGZWF0dXJlIHsgDQoJZnJvbQ0KCQlzZiA6IE1ldGFtZXRhbW9kZWwh RVJlZmVyZW5j
ZSwNCgkJY2wgOiBNZXRhbWV0YW1vZGVsIUVDbGFzcw0KCXRvDQoJCXQgOiBN ZXRhbWV0YW1v
ZGVsIUVSZWZlcmVuY2UgKA0KCQkJLS1jb250YWluZXIgPC0gc2YuY29udGFp bmVyDQoJCSkN
Cn0NCg==
--------------030700070309040803020208--
Re: [AML] How to manage inherited properties? [message #659998 is a reply to message #657851] Wed, 16 March 2011 10:19 Go to previous message
Thanks Kelly for your message, and thanks all for the work you do on AML Project.
Previous Topic:[QVTO] CST, Pretty Printer
Next Topic:[QVTo] Sending objects to transformation
Current Time: Sun Aug 31 07:19:09 EDT 2025
Powered by FUDForum. Page generated in 0.04150 seconds
