Home » Modeling » Papyrus » Newbie: Add attribute to a class in UML class diargram
Newbie: Add attribute to a class in UML class diargram [message #657755] Thu, 03 March 2011 16:07 Go to next message
Good day, colleagues!
I've just install Papyrus and create first UML class diagram. Then I created class from the pallete. But now I don't see a way to create attributes for the class. I have Properties tab at the bottom of the window, it has 4 tabs: UML, Profile, Appearence, Advanded. I don't see any tool for attribute creation at any of these tabs.
Can you help me? How can I create class attributes in Papyrus?
Eclipse - Helios SR2, Papytus - 0.7.2
Re: Newbie: Add attribute to a class in UML class diargram [message #657806 is a reply to message #657755] Fri, 04 March 2011 02:48 Go to previous messageGo to next message
After adding a class from the palette, you can select on the palette the node "property" and move it into your AttributeCompartment's class.
You can also open the Model Explorer, right click on your class, and select "New Child / Create a new Property".
nicolas
Re: Newbie: Add attribute to a class in UML class diargram [message #659592 is a reply to message #657806] Mon, 14 March 2011 13:41 Go to previous messageGo to next message
Hi Nicolas,
The point that Sergey is driving at is when you create an XML schema, you have a mix of elements and attributes.
The point is if you are using EA or RSA, the UML allows you to distinguish between elements and attributes.
How does Papyrus distinguish between an property for an element and a property for an attribute?
The only way I was able to do this was to create a UML to XML Schema profile when using Topcased.
Here is to illustrate my example of XSD with elements and attributes:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<xs:schema xmlns="http://www.edna-site.org" xmlns:xs="http://www.w3.org/2001/XMLSchema" targetNamespace="http://www.edna-site.org">
<xs:include schemaLocation="UMLPrimitiveTypes.library.xsd"/>
<xs:element name="Class0" type="xs:string"/>
<xs:complexType name="Class0">
<xs:sequence>
<xs:element maxOccurs="1" minOccurs="0" name="oid"
type="xs:Integer" />
<xs:element maxOccurs="1" minOccurs="0" name="name"
type="xs:String" />
<xs:element ref="Class0"></xs:element>
</xs:sequence>
<xs:attribute name="oid" type="xs:int"></xs:attribute>
</xs:complexType>
</xs:schema>
Cheers, JP
[Updated on: Mon, 14 March 2011 13:43] by Moderator
Re: Newbie: Add attribute to a class in UML class diargram [message #1326847 is a reply to message #659592] Thu, 01 May 2014 19:46 Go to previous messageGo to next message
Embarrassed Mad
very anti natural to do that and still couldn't find the option....
The feature at the bottom of the properties window only shows owned attributes....
Can't imagine how hard would be adding properties....
Re: Newbie: Add attribute to a class in UML class diargram [message #1333652 is a reply to message #1326847] Mon, 05 May 2014 02:53 Go to previous message
Hi Leo,
Attributes and Properties in UML are actually exactly the same thing. The semantic element is a "Property", which can have many roles. When a Property is owned by a Structured Classifier, it plays the role of an Attribute.
So... "Owned attributes" actually displays the Properties of the Class.
Thus, you have three options for creating attributes/properties for a Class:
- Most natural one: In a Class diagram, select "Property" from the Palette, and create it on your Class (Drag & Drop, or Click & Click)
- From the properties view: Select a Class, go to the UML tab, then click on the green "+" near "Owned attribute", and select "Property"
- From the model explorer: Right click on a Class, New Child > Property
Camille
Previous Topic:Delete option is disabled
Next Topic:Moving with mouse inside diagram view
Current Time: Wed Jul 23 17:39:25 EDT 2025
Powered by FUDForum. Page generated in 0.46137 seconds
