Home » Newcomers » Newcomers » New Android Project option missing in File -> New...
New Android Project option missing in File -> New... [message #655960] Wed, 23 February 2011 09:44 Go to next message
I'm using Eclipse for Android development and after installing the Android plug-in, I found that the option to create a new Android project is missing from the File Menu's - New pop up menu. The option to create an Android project is only found when I select File -> New -> Other and then find Android project.
How can I make the New Android Project option visible under the File - New menu?
Thanks!
Re: New Android Project option missing in File -> New... [message #655970 is a reply to message #655960] Wed, 23 February 2011 10:01 Go to previous messageGo to next message
> New menu?
The Android plugins (ADT) are not a product of Eclipse; they run on the
Eclipse platform but are developed and supported by Google. This forum
isn't for supporting third-party tools like ADT; I suggest you ask on
the Android support/developer forums.
Eric
Re: New Android Project option missing in File -> New... [message #655984 is a reply to message #655960] Wed, 23 February 2011 10:57 Go to previous messageGo to next message
> New menu?
> Thanks!
There is a way to promote "buried" options up out of Other... to
front-line status and, I assume, so could be done with Android Project.
I've seen the solution to this described in the last year in this forum,
however, it wasn't important enough to me to learn it, so I can't
describe it here.
I observe that New behaves differently (i.e.: has different front-line
options) depending on the perspective, the view and how you reach it.
For example in the JEE perspective, frustratingly, I find Dynamic Web
Project missing when I right-click down in the Project Explorer and
choose New, but present when I pull down File -> New.
Re: New Android Project option missing in File -> New... [message #657743 is a reply to message #655960] Thu, 03 March 2011 14:25 Go to previous messageGo to next message
Because I find the reply you received here to be so very offensively unhelpful, I'd like to share the following link that should help to resolve your issue.
http://developer.android.com/sdk/eclipse-adt.html#installing
Best of luck in your Android dev efforts...
Bill
Re: New Android Project option missing in File -> New... [message #846492 is a reply to message #655960] Mon, 16 April 2012 01:30 Go to previous messageGo to next message
in case anyone still needs the answer, it's here:
stackoverflow.com/questions/4649562/eclipse-with-android-sdk-missing-menu-items
basically, switch to the java perspective, bring up its context menu, then reset.
Re: New Android Project option missing in File -> New... [message #1705220 is a reply to message #655960] Wed, 12 August 2015 18:32 Go to previous message
Tried everything suggested but no luck until I installed Android Development tools for Eclipse
https://marketplace.eclipse.org/content/android-development-tools-eclipse
Now under file-new it will list new android project
Previous Topic:mongodb-java connection
Next Topic:Tomcat failed to start
Current Time: Mon Jul 21 12:16:30 EDT 2025
Powered by FUDForum. Page generated in 0.10393 seconds
