Home » Archived » BIRT » [BIRT 2.5.2] Crosstab - Dynamic columns width autofit issues([BIRT 2.5.2] -> Crosstab -> Dynamic Column width issue)
icon5.gif  [BIRT 2.5.2] Crosstab - Dynamic columns width autofit issues [message #657513] Thu, 03 March 2011 01:16 Go to next message
[BIRT 2.5.2] - While building the cross tab element (Tried with Excel Report fromat), What ever width I am assigninng to the dynamic column ..it always fits to the width of the Page (Master Page width). As a result of which if page width is defined lesser than the actual required ..individual column width gets shrinked & if moe then it expands. How can we contol the width as per the choice.
How ever I have noticed that this issue was more or less in the earlier version 2.2.2 too... But I had a work around of using grids with 2 columns & putting the cross tab in the first column.
Appreciate quick response :( as this is one of the critical requirement for me before I can upgrade from 2.2.2---> 2.5.2
[Updated on: Thu, 03 March 2011 04:09] by Moderator
Re: [BIRT 2.5.2] Crosstab - Dynamic columns width autofit issues [message #657694 is a reply to message #657513] Thu, 03 March 2011 10:48 Go to previous messageGo to next message
Are you setting the width on the cell or the data item? Is the report
in fixed or auto layout( check general properties for the report)?
Jason
On 3/3/2011 1:16 AM, Abhishek Kumar wrote:
> [BIRT 2.5.2] - While building the cross tab element (Tries with Excel
icon9.gif  Re: [BIRT 2.5.2] Crosstab - Dynamic columns width autofit issues [message #657802 is a reply to message #657694] Fri, 04 March 2011 02:18 Go to previous messageGo to next message
Thanks for your response. I had tried settign almost everything like cell level width, column level width & also the auto & fixed layout.
Finally raised a bug in the bugzilla (BUG 338781).
There it was clearly mentioned that there is no work around is available ... Sad Sad
This is fixed in 2.6.2 & I need to use the same ...
How ever at this point there is no way I can use the 2.6.2 in near future .. hence still looking for some work around.
btw why I am not getting any link to attach any ref files ??
using below you can simulate the issue
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.21" id="1">
<property name="comments">Copyright (c) 2007 &lt;&lt;Your Company Name here>></property>
<property name="createdBy">Eclipse BIRT Designer Version 2.5.2.v20100208 Build &lt;2.5.2.v20100210-0630></property>
<html-property name="description">Creates a blank report with no predefined content.</html-property>
<property name="units">in</property>
<text-property name="displayName">Blank Report</text-property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="layoutPreference">fixed layout</property>
<data-sources>
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source" id="6">
<property name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet " name="Data Set" id="7">
<list-property name="columnHints">
<structure>
<property name="columnName">CUSTOMERNUMBER</property>
<text-property name="displayName">CUSTOMERNUMBER</text-property>
</structure>
<structure>
<property name="columnName">CUSTOMERNAME</property>
<text-property name="displayName">CUSTOMERNAME</text-property>
</structure>
<structure>
<property name="columnName">CONTACTLASTNAME</property>
<text-property name="displayName">CONTACTLASTNAME</text-property>
</structure>
<structure>
<property name="columnName">CONTACTFIRSTNAME</property>
<text-property name="displayName">CONTACTFIRSTNAME</text-property>
</structure>
<structure>
<property name="columnName">PHONE</property>
<text-property name="displayName">PHONE</text-property>
</structure>
<structure>
<property name="columnName">ADDRESSLINE1</property>
<text-property name="displayName">ADDRESSLINE1</text-property>
</structure>
<structure>
<property name="columnName">ADDRESSLINE2</property>
<text-property name="displayName">ADDRESSLINE2</text-property>
</structure>
<structure>
<property name="columnName">CITY</property>
<text-property name="displayName">CITY</text-property>
</structure>
<structure>
<property name="columnName">STATE</property>
<text-property name="displayName">STATE</text-property>
</structure>
<structure>
<property name="columnName">POSTALCODE</property>
<text-property name="displayName">POSTALCODE</text-property>
</structure>
<structure>
<property name="columnName">COUNTRY</property>
<text-property name="displayName">COUNTRY</text-property>
</structure>
<structure>
<property name="columnName">SALESREPEMPLOYEENUMBER</property>
<text-property name="displayName">SALESREPEMPLOYEENUMBER</text-property>
</structure>
<structure>
<property name="columnName">CREDITLIMIT</property>
<text-property name="displayName">CREDITLIMIT</text-property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">CUSTOMERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">CUSTOMERNAME</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">CONTACTLASTNAME</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">CONTACTFIRSTNAME</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">PHONE</property>
</structure>
<structure>
<property name="position">6</property>
<property name="name">ADDRESSLINE1</property>
</structure>
<structure>
<property name="position">7</property>
<property name="name">ADDRESSLINE2</property>
</structure>
<structure>
<property name="position">8</property>
<property name="name">CITY</property>
</structure>
<structure>
<property name="position">9</property>
<property name="name">STATE</property>
</structure>
<structure>
<property name="position">10</property>
<property name="name">POSTALCODE</property>
</structure>
<structure>
<property name="position">11</property>
<property name="name">COUNTRY</property>
</structure>
<structure>
<property name="position">12</property>
<property name="name">SALESREPEMPLOYEENUMBER</property>
</structure>
<structure>
<property name="position">13</property>
<property name="name">CREDITLIMIT</property>
<property name="dataType">float</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">CUSTOMERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">CUSTOMERNAME</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">CONTACTLASTNAME</property>
</structure>
<structure>
<property name="nativeName">CONTACTFIRSTNAME</property>
</structure>
<structure>
<property name="nativeName">PHONE</property>
</structure>
<structure>
<property name="nativeName">ADDRESSLINE1</property>
</structure>
<structure>
<property name="nativeName">ADDRESSLINE2</property>
</structure>
<structure>
<property name="nativeName">CITY</property>
</structure>
<structure>
<property name="nativeName">STATE</property>
</structure>
<structure>
<property name="nativeName">POSTALCODE</property>
</structure>
<structure>
<property name="nativeName">COUNTRY</property>
</structure>
<structure>
<property name="nativeName">SALESREPEMPLOYEENUMBER</property>
</structure>
<structure>
<property name="nativeName">CREDITLIMIT</property>
<property name="nativeDataType">8</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select * from CLASSICMODELS.CUSTOMERS]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml version="1.0" encoding="UTF-8"?>
<model:DesignValues xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design" xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>CUSTOMERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>CUSTOMERNUMBER</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>CUSTOMERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>CUSTOMERNAME</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>50</design:precision>
<design:uiHints>
<design:displayName>CUSTOMERNAME</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CUSTOMERNAME</design:label>
<design:displaySize>50</design:displaySize>
<design:attributes>
<design:name>CONTACTLASTNAME</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>CONTACTLASTNAME</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CONTACTLASTNAME</design:label>
<design:attributes>
<design:name>CONTACTFIRSTNAME</design:name>
<design:position>4</design:position>
<design:uiHints>
<design:displayName>CONTACTFIRSTNAME</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CONTACTFIRSTNAME</design:label>
<design:attributes>
<design:name>PHONE</design:name>
<design:position>5</design:position>
<design:uiHints>
<design:displayName>PHONE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PHONE</design:label>
<design:attributes>
<design:name>ADDRESSLINE1</design:name>
<design:position>6</design:position>
<design:uiHints>
<design:displayName>ADDRESSLINE1</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ADDRESSLINE1</design:label>
<design:attributes>
<design:name>ADDRESSLINE2</design:name>
<design:position>7</design:position>
<design:uiHints>
<design:displayName>ADDRESSLINE2</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ADDRESSLINE2</design:label>
<design:attributes>
<design:name>CITY</design:name>
<design:position>8</design:position>
<design:uiHints>
<design:displayName>CITY</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CITY</design:label>
<design:attributes>
<design:name>STATE</design:name>
<design:position>9</design:position>
<design:uiHints>
<design:displayName>STATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>STATE</design:label>
<design:attributes>
<design:name>POSTALCODE</design:name>
<design:position>10</design:position>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>POSTALCODE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>POSTALCODE</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>COUNTRY</design:name>
<design:position>11</design:position>
<design:uiHints>
<design:displayName>COUNTRY</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>COUNTRY</design:label>
<design:attributes>
<design:name>SALESREPEMPLOYEENUMBER</design:name>
<design:position>12</design:position>
<design:uiHints>
<design:displayName>SALESREPEMPLOYEENUMBER</design:displayName >
</design:uiHints>
<design:usageHints>
<design:label>SALESREPEMPLOYEENUMBER</design:label>
<design:attributes>
<design:name>CREDITLIMIT</design:name>
<design:position>13</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>CREDITLIMIT</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CREDITLIMIT</design:label>
<design:displaySize>22</design:displaySize>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
</data-sets>
<cubes>
<tabular-cube name="Data Cube" id="8">
<property name="defaultMeasureGroup">Summary Field</property>
<property name="dimensions">
<tabular-dimension name="Group" id="9">
<property name="defaultHierarchy">NewTabularHierarchy</property>
<property name="hierarchies">
<tabular-hierarchy name="NewTabularHierarchy" id="10">
<property name="levels">
<tabular-level name="STATE" id="11">
</tabular-level>
</property>
</tabular-hierarchy>
</property>
</tabular-dimension>
<tabular-dimension name="Group1" id="14">
<property name="defaultHierarchy">NewTabularHierarchy1</property>
<tabular-hierarchy name="NewTabularHierarchy1" id="15">
<tabular-level name="CREDITLIMIT" id="16">
</tabular-level>
</property>
</property>
</property>
<property name="measureGroups">
<tabular-measure-group name="Summary Field" id="12">
<property name="measures">
<tabular-measure name="CUSTOMERNUMBER" id="13">
<expression name="measureExpression">dataSetRow["CUSTOMERNUMBER"]</expression >
</tabular-measure>
</property>
</tabular-measure-group>
</property>
<property name="dataSet">Data Set</property>
</tabular-cube>
</cubes>
<styles>
<style name="crosstab" id="4">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab-cell" id="5">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<property name="type">custom</property>
<property name="height">20in</property>
<property name="width">200in</property>
<property name="topMargin">1in</property>
<property name="leftMargin">1.25in</property>
<property name="bottomMargin">1in</property>
<property name="rightMargin">1.25in</property>
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<grid id="32">
<property name="width">100%</property>
<column id="33"/>
<column id="34"/>
<row id="35">
<cell id="36">
<extended-item extensionName="Crosstab" extensionVersion="2.5.0" id="17">
<extended-item extensionName="MeasureView" id="28">
<property name="measure">CUSTOMERNUMBER</property>
<property name="detail">
<extended-item extensionName="AggregationCell" id="39">
<property name="aggregationOnRow">Group1/CREDITLIMIT</property>
<property name="aggregationOnColumn">Group/STATE</property>
<property name="content">
<data name="CUSTOMERNUMBER" id="31">
<property name="resultSetColumn">CUSTOMERNUMBER</property>
</data>
</property>
<property name="width">1.5in</property>
</extended-item>
</property>
<property name="header">
<extended-item extensionName="CrosstabCell" id="30"/>
</property>
</extended-item>
</property>
<property name="rows">
<extended-item extensionName="CrosstabView" id="18">
<property name="views">
<extended-item extensionName="DimensionView" id="19">
<property name="dimension">Group1</property>
<extended-item extensionName="LevelView" name="NewLevel View" id="20">
<property name="level">Group1/CREDITLIMIT</property>
<property name="member">
<extended-item extensionName="CrosstabCell" id="21">
<data name="CREDITLIMIT" id="22">
<property name="resultSetColumn">CREDITLIMIT</property>
</data>
</property>
<property name="width">1in</property>
</extended-item>
</property>
</extended-item>
</property>
</extended-item>
</property>
</extended-item>
</property>
<property name="columns">
<extended-item extensionName="CrosstabView" id="23">
<extended-item extensionName="DimensionView" id="24">
<property name="dimension">Group</property>
<extended-item extensionName="LevelView" name="NewLevel View1" id="25">
<property name="level">Group/STATE</property>
<extended-item extensionName="CrosstabCell" id="26">
<data name="STATE" id="27">
<property name="resultSetColumn">STATE</property>
</data>
</property>
</extended-item>
</property>
</extended-item>
</property>
</extended-item>
</property>
</extended-item>
</property>
<property name="hideMeasureHeader">false</property>
<extended-item extensionName="CrosstabCell" id="38"/>
</property>
<property name="cube">Data Cube</property>
<list-property name="boundDataColumns">
<structure>
<expression name="expression">dimension["Group1"]["CREDITLIMIT"]</expression >
</structure>
<structure>
<expression name="expression">dimension["Group"]["STATE"]</expression >
</structure>
<structure>
<expression name="expression">measure["CUSTOMERNUMBER"]</expression >
</structure>
</list-property>
</extended-item>
</cell>
<cell id="37"/>
</row>
</grid>
</body>
</report>
Re: [BIRT 2.5.2] Crosstab - Dynamic columns width autofit issues [message #657941 is a reply to message #657802] Fri, 04 March 2011 11:38 Go to previous messageGo to next message
I wish I had a work around but I do no. You could try looking at the
tribix XLS emitter and see what it produces.
Jason
> btw why I am not getting any link to attach any ref files ?? using below
> id="1">
> <property name="comments">Copyright (c) 2007 <<Your Company Name
> here>></property>
> Build <2.5.2.v20100210-0630></property>
> <data-sources>
> <property
> </property>
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> encoding="UTF-8"?>
> <model:DesignValues
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> </oda-data-set>
> </data-sets>
> <cubes>
> </tabular-level>
> </property>
> </property>
> </tabular-level>
> </property>
> </property>
> </property>
> <expression
> </tabular-measure>
> </property>
> </property>
> </tabular-cube>
> </cubes>
> <styles>
> </style>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> </page-setup>
> <body>
> <grid id="32">
> <column id="33"/>
> <column id="34"/>
> <row id="35">
> <cell id="36">
> </data>
> </property>
> </extended-item>
> </property>
> </property>
> </extended-item>
> </property>
> </data>
> </property>
> </extended-item>
> </property>
> </extended-item>
> </property>
> </extended-item>
> </property>
> </extended-item>
> </property>
> </data>
> </property>
> </extended-item>
> </property>
> </extended-item>
> </property>
> </extended-item>
> </property>
> </extended-item>
> </property>
> </property>
> <structure>
> <expression
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </extended-item>
> </cell>
> <cell id="37"/>
> </row>
> </grid>
> </body>
> </report>
Re: [BIRT 2.5.2] Crosstab - Dynamic columns width autofit issues [message #989634 is a reply to message #657941] Fri, 07 December 2012 01:19 Go to previous messageGo to next message
No Message Body
Re: [BIRT 2.5.2] Crosstab - Dynamic columns width autofit issues [message #989637 is a reply to message #989634] Fri, 07 December 2012 01:47 Go to previous message
Hi Jason
We are using BIRT 3.7 run time engine. The excel reports have "#" in place of data. It requires manual expansion of column widths when we give to our customers. We have tried with auto and fixed layouts in the design template. It did not work for us. How to solve this progrmmatically?
Thank you,
Anita
Previous Topic:Spring Tool Suite and Birt Report Design
Next Topic:what is the meaning of "can shrink" for table element?
Current Time: Fri Jul 18 20:37:57 EDT 2025
Powered by FUDForum. Page generated in 0.04409 seconds
