Home » Eclipse Projects » Rich Client Platform (RCP) » setSelectionProvider to an editor without Viewers(How to set SElectionProvider to an editor whsoe components are not in a viewer?)
setSelectionProvider to an editor without Viewers [message #657222] Tue, 01 March 2011 19:47 Go to next message
I am trying to set(Selection provider) to my Editor through the
Handler class. But I am constantly failing.
I have a view class where I list down the various SWT widgets,
I drag and drop the widget from the view to my editor,
However, I am done with this part. But the problem occurs when I try
to relate the Properties View to the widgets in the editor which was
dropped.
As mentioned, please find below, the execute(..) method of the handler, which
is responsible in dropping the widget to my editor.
public Object execute(ExecutionEvent event) throws ExecutionException
final Composite composite =
MyDragnDropUtil.getDesignEditorComposite();
final Composite dspComp = (Composite) composite.getChildren()[0];//
[1];
final Button logger = new Button(dspComp, SWT.BORDER);
logger.setText("Button");
DroppedWidgetItem dwi = new DroppedWidgetItem(logger, "Button");
ndclist_static.add(dwi);
System.out.println("size:"+ndclist_static.getChildren().size());
return null;
I am unable to view the Properties View when I select the dropped
widget, since I am unable to set my SelectionProvider to the dropped
Widget composite.
I am aware of setting the Selection Provider through the Viewer.
However, I do not intend to use Viewer in the editor. As you can see
in the code above, I am using a composite.
Could you please suggest a workaround towards this issue? Or am I doing something wrong?
Re: setSelectionProvider to an editor without Viewers [message #657349 is a reply to message #657222] Wed, 02 March 2011 09:13 Go to previous messageGo to next message
you must provide a selection provider in your editor. Do you?
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: setSelectionProvider to an editor without Viewers [message #657491 is a reply to message #657349] Wed, 02 March 2011 20:02 Go to previous messageGo to next message
Hi Paul,
For a better understanding of my problem please find the code snippets below...
I create the Composite of my MultipageEditor dynamically using a handler..
The composite creation of the editor prior to Handler execution is as follows in my Editor Class:
private void createComposite(Composite composite) {
Composite comp = new Composite(composite, SWT.NONE);
comp.setLayout(new GridLayout());
comp.setLayoutData(new GridData(GridData.FILL, GridData.FILL, true, false));
In the above code, I am keeping a Initial composite space ready for the dynamic widget creation.
And once the handler is invoked(execute method), I drop my widgets to this composite as in the code below(in the Handler Class) :
private NexdigmDroppedComponentList ndclist_static=new NexdigmDroppedComponentList();
final Composite composite =MyDragnDropUtil.getDesignEditorComposite();
//Passing the Button as an DroppedWidgetItem (extends IAdaptable)as an IAdaptable element
// Adding the IAdaptable widgets to the IAdaptable list to link to the Property View
return null;
I am however unable to set Selection Provider for this issue since the Button Widget is not a Viewer.
I am now trying to set SelectionProvider to this Composite so as to display the related Properties in the Property View when I setFocus on the Widgets dropped in the editor composite.
I hope I am clear with my explaination..
Dila
Re: setSelectionProvider to an editor without Viewers [message #657615 is a reply to message #657491] Thu, 03 March 2011 08:39 Go to previous messageGo to next message
You must implement a selection provider
(org.eclipse.jface.viewers.ISelectionProvider) in your editor code
somewhere, and then register it with your editor site. You must tell it
when you create a new DroppedWidgetItem or when your editor selects a
new DroppedWidgetItem, and fire the appropriate events.
PW
Paul Webster
icon9.gif  Re: setSelectionProvider to an editor without Viewers [message #657779 is a reply to message #657615] Thu, 03 March 2011 20:29 Go to previous messageGo to next message
Dear Paul,
Could you please provide me with some examples for your explanation. Kind of confused with the overall flow.
http://www.eclipse.org/forums/images/message_icons/icon5.gif
Dila
[Updated on: Thu, 03 March 2011 20:31] by Moderator
Re: setSelectionProvider to an editor without Viewers [message #657873 is a reply to message #657779] Fri, 04 March 2011 07:17 Go to previous messageGo to next message
On 03/03/2011 08:29 PM, Dila wrote:
> Dear Paul,
> flow...http://www.eclipse.org/forums/images/message_icons/ic on9.gif
See http://www.eclipse.org/articles/Article-WorkbenchSelections/ article.html
You can also add your target platform to the Java Search, open
ISelectionProvider, and use F4 (Type Hierarchy) to find examples of
implementation/use in the SDK. See
http://wiki.eclipse.org/FAQ_How_do_I_find_a_particular_class _from_an_Eclipse_plug-in%3F
PW
Paul Webster
Re: setSelectionProvider to an editor without Viewers [message #658562 is a reply to message #657873] Tue, 08 March 2011 20:08 Go to previous message
Thanks Paul!
I have moved on to another module. I still haven't found a workaround for this issue.
I shall update if I get the solution.
If anyone could give me a workaround towards this issue.. would be grateful.
Dila
Previous Topic:RCP Book Tools
Next Topic:org.eclipse.ui.handlers: Why is handler class optional?
Current Time: Mon Nov 10 07:32:27 EST 2025
Powered by FUDForum. Page generated in 0.27653 seconds
