Home » Modeling » M2T (model-to-text transformation) » [Acceleo] eliminate white lines generated by template([Acceleo] eliminate white lines generated by template)
[Acceleo] eliminate white lines generated by template [message #657379] Wed, 02 March 2011 10:58 Go to next message
There is some form of eliminate the white lines generated when one template returns the string ''?
I tried with "trim()" but It does not work.
in advance, thanks for your help
Re: [Acceleo] eliminate white lines generated by template [message #657568 is a reply to message #657379] Thu, 03 March 2011 04:02 Go to previous message
--------------010502050705090203060008
A template, if it returns the empty String, won't generate anything in
the output file. What you have here is (I assume) something like this :
[file (...)]
some text
[templateCallThatDoesNotGenerateAnything()/]
and some other text
[/file]
And you expect the output to be
some text
and some other text
whereas you get
some text
and some other text
This is normal, and expected. The line where you have a template call
ends with a carriage return, this carriage return _will_ be generated.
There is no way to prevent this from happening.
Laurent Goubet
Obeo
On 02/03/2011 16:58, olafo987 wrote:
> Hi
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------010502050705090203060008--
Previous Topic:[ Acceleo 3] java service get a empty Jpa metamodel
Next Topic:[Acceleo 3] ServiceWrapper Problem during generation
Current Time: Thu Sep 25 04:04:02 EDT 2025
Powered by FUDForum. Page generated in 0.52064 seconds
