Home » Modeling » GMF (Graphical Modeling Framework) » The code of method getNodeVisualID(View, EObject) is exceeding the 65535 bytes limit
The code of method getNodeVisualID(View, EObject) is exceeding the 65535 bytes limit [message #651290] Fri, 28 January 2011 13:06 Go to next message
HI,
while generating gmf codes i got the flowing error in the ApplicationVisualIDRegistry, i tried to modify the template
instead of:
switch (containerVisualID) {
case HtmlGM.diagram.edit.parts.PageEditPart.VISUAL_ID:
if (HtmlGM.HtmlGMPackage.eINSTANCE.getHtml().isSuperTypeOf(
domainElement.eClass())) {
return HtmlGM.diagram.edit.parts.ApplicationEditPart.VISUAL_ID;
i try to have something like:
return getViewChildrenForApplicationEditPart(domainElement);
and to have this method defined outside
private static int getViewChildrenForApplicationEditPart(EObject domainElement) {
return -1;
so i change the template :
«DEFINE genAllMethodNodeCase FOR gmfgen::GenDiagram»
«EXPAND caseMethod FOREACH getAllContainers()-»
«ENDDEFINE»
«DEFINE caseMethod FOR gmfgen::GenContainerBase-»
«EXPAND caseMethodNodeNode FOREACH getContainedSemanticNodes(self)-»
«ENDDEFINE»
«DEFINE caseMethodNodeNode FOR gmfgen::GenCommonBase»
private static int getViewChildrenFor«self.editPartClassName»«e»(org.eclips e.emf.ecore.EObject domainElement){
if («EXPAND checkSemanticElement»)return «EXPAND visualID»;
return -1;
«ENDDEFINE»
but it genarete several method with the same name giving the following error:
Duplicate method getViewChildrenApplicationEditPart(EObject) in type ApplicationVisualIDRegistry
any ideas how i could solve this problem
thanks
[Updated on: Fri, 28 January 2011 13:07] by Moderator
Re: The code of method getNodeVisualID(View, EObject) is exceeding the 65535 bytes limit [message #651601 is a reply to message #651290] Mon, 31 January 2011 15:12 Go to previous messageGo to next message
you are calling caseMethodNodeNode with a FOREACH.
That is why there are several times the same method.
regards,
Re: The code of method getNodeVisualID(View, EObject) is exceeding the 65535 bytes limit [message #651688 is a reply to message #651601] Tue, 01 February 2011 05:03 Go to previous messageGo to next message
Hi Aurelien,
i tried what you said, but i got this error
Problems while generating code
Exception (No Definition caseMethodNodeNode for Sequence(GenTopLevelNode) could be found!) while generating code
thanks again
Re: The code of method getNodeVisualID(View, EObject) is exceeding the 65535 bytes limit [message #657308 is a reply to message #651688] Wed, 02 March 2011 06:52 Go to previous messageGo to next message
Any ideas, how can i manage to solve this problem?
Re: The code of method getNodeVisualID(View, EObject) is exceeding the 65535 bytes limit [message #657792 is a reply to message #657308] Fri, 04 March 2011 00:01 Go to previous messageGo to next message
The problem is not that you are calling that NodeNode expand FOREACH, thats correct.
The problem is that your method name does not depend on the pair <parent, child> but only on <child>, so if you have PopularChildEditPart as a possible child for 2 different parents, you will get 2 identically named methods.
You may solve this by collecting all the children into the set, or (a bit ugly, but should work) just by generating 1 method for every pair:
«EXPAND caseMethodNodeNode(self) FOREACH getContainedSemanticNodes(self)-»
«ENDDEFINE»
«DEFINE caseMethodNodeNode(parent : gmfgen::GenCommonBase) FOR gmfgen::GenCommonBase»
private static int getViewChildrenForParent«parent.editPartClassName»OfType«self.editPartClassName»(org.eclips e.emf.ecore.EObject domainElement){
return -1;
«ENDDEFINE»
Re: The code of method getNodeVisualID(View, EObject) is exceeding the 65535 bytes limit [message #657835 is a reply to message #657792] Fri, 04 March 2011 04:48 Go to previous message
HI Michael,
Thanks you saved me a lout of trouble, because i split the method into several sub method to avoid this problem.
Thanks again
Previous Topic:Difference between Children Feature and Containment Feature?
Next Topic:A Creation Tool for every model/figure?
Current Time: Fri Jul 18 00:05:17 EDT 2025
Powered by FUDForum. Page generated in 0.12927 seconds
