Home » Archived » BIRT » How to show the image in birt report?(How to show the image in birt report?)
How to show the image in birt report? [message #657248] |
Wed, 02 March 2011 02:41  |
Currently, I use birt API to generate a report. I design this report with birt, has a image need to show in this report. And the image name is dynamic from database. I have completed the source code, and it can generate report successfully, but the image can't show in report. Following is my source code:
package com.ncs.report;
import java.util.HashMap;
import java.util.List;
import java.util.Map;
import java.util.logging.Level;
import junit.framework.Test;
import org.eclipse.birt.core.exception.BirtException;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.EngineConstants;
import org.eclipse.birt.report.engine.api.HTMLActionHandler;
import org.eclipse.birt.report.engine.api.HTMLEmitterConfig;
import org.eclipse.birt.report.engine.api.HTMLRenderContext;
import org.eclipse.birt.report.engine.api.HTMLRenderOption;
import org.eclipse.birt.report.engine.api.HTMLServerImageHandler;
import org.eclipse.birt.report.engine.api.IReportEngine;
import org.eclipse.birt.report.engine.api.IReportEngineFactory;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IRunAndRenderTask;
import org.eclipse.birt.report.engine.api.PDFRenderOption;
import org.eclipse.birt.report.model.api.ElementFactory;
import org.eclipse.birt.report.model.api.OdaDataSourceHandle;
import org.eclipse.birt.report.model.api.ReportDesignHandle;
import org.eclipse.birt.report.model.api.activity.SemanticException ;
import org.eclipse.birt.report.model.api.elements.structures.Embedd edImage;
import com.actuate.eservices.moe.erdf.RegistryServiceWrapper;
public class TestReport {
* @param args
public static void main(String[] args) throws BirtException{
try{
final EngineConfig config = new EngineConfig();
String reportName="RPTLSI05_report";
config.setEngineHome("D:\\abc\\Eclipse report\\ReportEngine");
config.setLogConfig("D:\\reportLog",Level.FINE);
config.setResourcePath("D:\\abc\\sams\\trunk\\az\\modules\\rpt\\brdf\\Libraries ");
Platform.startup(config);
IReportEngineFactory factory =(IReportEngineFactory)Platform.createFactoryObject(IReportE ngineFactory.EXTENSION_REPORT_ENGINE_FACTORY);
IReportEngine engine = factory.createReportEngine(config);
engine.changeLogLevel(Level.WARNING);
IReportRunnable design= engine.openReportDesign(" D:\\abc\\sams\\trunk\\az\\modules\\rpt\\brdf\\rptdesign\\ls\ \reports\\RPTLSI05_report.rptdesign ");
ReportDesignHandle report = (ReportDesignHandle) design.getDesignHandle();
buildReport(report);
IRunAndRenderTask task = engine.createRunAndRenderTask(design);
task.getAppContext().put(EngineConstants.APPCONTEXT_CLASSLOA DER_KEY, Test.class.getClassLoader());
//start
HTMLEmitterConfig emitterConfig = new HTMLEmitterConfig( );
emitterConfig.setActionHandler( new HTMLActionHandler( ) );
HTMLServerImageHandler imageHandler = new HTMLServerImageHandler( );
emitterConfig.setImageHandler( imageHandler );
config.getEmitterConfigs( ).put( "html", emitterConfig );
HTMLRenderContext renderContext = new HTMLRenderContext ();
// renderContext.setBaseURL("http://localhost/");
// renderContext.setBaseImageURL("http://localhost/myimages");
//renderContext.setImageDirectory("d:\\myimages");
renderContext.setSupportedImageFormats("JPG;PNG;BMP;SVG");
HashMap<String, HTMLRenderContext> contextMap = new HashMap<String, HTMLRenderContext>();
//contextMap.put( EngineConstants.APPCONTEXT_HTML_RENDER_CONTEXT, renderContext );
contextMap.put( EngineConstants.APPCONTEXT_PDF_RENDER_CONTEXT, renderContext );
task.setAppContext( contextMap );
//end
Map<String,Object> reportParameterMap = new HashMap<String,Object>();
reportParameterMap.put("Scheme", "2010ISD1ANL");
reportParameterMap.put("Interview Schedule Id", null);
task.setParameterValues(reportParameterMap);
task.validateParameters();
PDFRenderOption options = new PDFRenderOption();
options.setOutputFileName("D:\\p350\\Generated Report\\"+reportName+".pdf");
options.setOutputFormat("pdf");
task.setRenderOption(options);
task.run();
Platform.shutdown();
task.close();
engine.shutdown();;
System.exit(0);
}catch(Exception e){
e.printStackTrace();
System.exit(0);
protected static void buildReport(ReportDesignHandle designHandle) {
try {
ElementFactory designFactory = designHandle.getElementFactory();
buildDataSource(designFactory, designHandle);
} catch (SemanticException e) {
protected static void buildDataSource(ElementFactory designFactory,
ReportDesignHandle designHandle) throws SemanticException {
RegistryServiceWrapper regSrvcWrapper = new RegistryServiceWrapper("AZ");
String[] regParams = regSrvcWrapper.getRegistryParameters("az");
String dataSource = regParams[0];
String dbUsername = regParams[1];
String appCode = regParams[2];
String keyCode = regParams[3];
String level1Code = regParams[4];
System.out.println("dataSource===============> "+dataSource);
System.out.println("dbUsername===============> "+dbUsername);
System.out.println("appCode===============> "+appCode);
System.out.println("keyCode===============> "+keyCode);
System.out.println("level1Code===============> "+level1Code);
regSrvcWrapper.initialize(appCode,"az");
if (dbUsername == null)
dbUsername = regSrvcWrapper.getRegistryValue("USER", level1Code);
String dbPassword = regSrvcWrapper.getRegistryValue(keyCode, level1Code);
System.out.println("dbPassword===============> "+dbPassword);
clearDataSource(designHandle);
OdaDataSourceHandle dsHandle = designFactory.newOdaDataSource("Oracle Data Source", "org.eclipse.birt.report.data.oda.jdbc");
dsHandle.setProperty( "odaDriverClass","oracle.jdbc.driver.OracleDriver");
dsHandle.setProperty( "odaURL", dataSource);
System.out.println("odaURL===============> "+dataSource);
dsHandle.setProperty( "odaUser", dbUsername);
dsHandle.setProperty( "odaPassword", dbPassword);
designHandle.getDataSources().add(dsHandle);
protected static void clearDataSource(ReportDesignHandle designHandle) {
int count = designHandle.getDataSources().getCount();
try {
for (int i = 0; i < count; i++){
designHandle.getDataSources().drop(i);
Re: How to show the image in birt report? [message #657404 is a reply to message #657248] |
Wed, 02 March 2011 11:47   |
Bob,
Can you post the xml from the report design?
Jason
On 3/2/2011 2:41 AM, Bob wrote:
> Hi
> edImage;
> * @param args
> try{ final EngineConfig config = new EngineConfig();
> //start
> emitterConfig.setImageHandler( imageHandler ); config.getEmitterConfigs(
> ).put( "html", emitterConfig ); HTMLRenderContext renderContext = new
> // renderContext.setBaseURL("http://localhost/"); //
> renderContext ); contextMap.put(
> task.setAppContext( contextMap ); //end
> task.run();
> task.close();
> engine.shutdown();;
> System.exit(0);
> System.exit(0);
> protected static void buildReport(ReportDesignHandle designHandle) { try
> { ElementFactory designFactory = designHandle.getElementFactory();
> buildDataSource(designFactory, designHandle); } catch (SemanticException
> e) { e.printStackTrace(); }
> dsHandle.setProperty( "odaUser", dbUsername); dsHandle.setProperty(
> "odaPassword", dbPassword); designHandle.getDataSources().add(dsHandle);
> int count = designHandle.getDataSources().getCount(); try { for (int i =
> 0; i < count; i++){
> designHandle.getDataSources().drop(i); }
> } catch (SemanticException e) { e.printStackTrace(); } }
Re: How to show the image in birt report? [message #657488 is a reply to message #657404] |
Wed, 02 March 2011 19:47   |
Hi Jason,
Refer to following:
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.15" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 2.2.2.v20080718-1613 Build <2.2.2.v20080718-1613></property>
<property name="units">in</property>
<property name="comments">Copyright (c) 2007 <<Your Company Name here>></property>
<html-property name="description">This is a sample report template for portrait layout.</html-property>
<property name="theme">BRDF_themes.defaultTheme_Plain</property>
<text-property name="displayName">Sample xxx Portrait Report Report</text-property>
<property name="iconFile">/templates/simple_listing.gif</property>
<list-property name="libraries">
<structure>
<property name="fileName">BRDF_masterpages.rptlibrary</property>
<property name="namespace">BRDF_masterpages</property>
</structure>
<structure>
<property name="fileName">BRDF_themes.rptlibrary</property>
<property name="namespace">BRDF_themes</property>
</structure>
<structure>
<property name="fileName">BRDF_structure.rptlibrary</property>
<property name="namespace">BRDF_structure</property>
</structure>
<structure>
<property name="fileName">BRDF_datasources.rptlibrary</property>
<property name="namespace">BRDF_datasources</property>
</structure>
<structure>
<property name="fileName">/themes.rptlibrary</property>
<property name="namespace">themes</property>
</structure>
<structure>
<property name="fileName">BRDF_controls.rptlibrary</property>
<property name="namespace">BRDF_controls</property>
</structure>
</list-property>
<list-property name="includeScripts">
<property>JavaScripts/escapeSpecialCharacter.js</property>
</list-property>
<parameters>
<parameter-group name="System Parameters" id="884">
<parameters>
<scalar-parameter name="rp_appName" id="885">
<property name="hidden">true</property>
<text-property name="helpText">For registry service integration</text-property>
<property name="valueType">static</property>
<property name="dataType">string</property>
<property name="paramType">simple</property>
<property name="isRequired">false</property>
<property name="controlType">text-box</property>
<property name="defaultValue">az</property>
<property name="distinct">true</property>
<structure name="format">
<property name="category">Unformatted</property>
</structure>
</scalar-parameter>
<scalar-parameter name="rp_reportID" id="197">
<text-property name="helpText">Static report label - unique per report</text-property>
<property name="defaultValue">RPTLSI05</property>
</structure>
</scalar-parameter>
<scalar-parameter name="rp_reportTitle" id="198">
<text-property name="helpText">Report title - unique per report</text-property>
<property name="defaultValue">Interview Booklet a€" Pre-U</property>
</structure>
</scalar-parameter>
</parameters>
</parameter-group>
<scalar-parameter name="Scheme" id="902">
<method name="validate"><![CDATA[if(params["Scheme"].value=='----1'){
false;
}else{
true;
}]]></method>
<property name="valueType">dynamic</property>
<text-property name="promptText">Scheme</text-property>
<property name="controlType">list-box</property>
<property name="dataSetName">paramScheme</property>
<expression name="valueExpr">dataSetRow["SCHEME_ID"]</expression>
<expression name="labelExpr">dataSetRow["SCHEME_NAME"]</expression>
<property name="mustMatch">true</property>
<property name="fixedOrder">true</property>
<property name="defaultValue">----1</property>
</structure>
</scalar-parameter>
<scalar-parameter name="Interview Schedule Id" id="1291">
<property name="hidden">false</property>
<text-property name="promptText">Interview Schedule Id</text-property>
</structure>
</scalar-parameter>
</parameters>
<data-sources>
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Oracle Data Source" id="851"
extends="BRDF_datasources.Oracle Data Source">
<property name="odaDriverClass">com.actuate.jdbc.oracle.OracleDriver</property>
<property name="odaURL">jdbc:actuate:oracle://192.168.81.238:1521;ServiceName=azd</property>
<property name="odaUser">az03</property>
<encrypted-property name="odaPassword" encryptionID="jce">e783a2121bdf69ddcaab65efdde92e0b</encrypted-property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet" name="paramScheme" id="901">
<list-property name="columnHints">
<structure>
<property name="columnName">SCHEME_ID</property>
<property name="displayName">SCHEME_ID</property>
</structure>
<structure>
<property name="columnName">SCHEME_NAME</property>
<property name="displayName">SCHEME_NAME</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">SCHEME_ID</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">SCHEME_NAME</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Oracle Data Source</property>
<structure>
<property name="nativeName">SCHEME_ID</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">SCHEME_NAME</property>
</structure>
</list-property>
<property name="queryText">SELECT '----1' SCHEME_ID,'Please Select' SCHEME_NAME FROM DUAL
UNION ALL
SELECT *
FROM (
SELECT S.SCHEME_ID,S.SCHEME_NAME
FROM AZ_SCHEME S
WHERE S.RECRUITMENT_YR BETWEEN TO_NUMBER(TO_CHAR(SYSDATE,'YYYY'))-10 AND TO_NUMBER (TO_CHAR(SYSDATE,'YYYY'))+1
AND S.STATUS_CD = 'A'
AND S.SCHOLARSHIP_TYPE_CD = 'L'
ORDER BY S.SCHEME_NAME
</property>
<xml-property name="designerValues"><![CDATA[<?xml version="1.0" encoding="UTF-8"?>
<model:DesignValues xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design" xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>SCHEME_ID</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>20</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>SCHEME_ID</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>SCHEME_ID</design:label>
<design:formattingHints>
<design:displaySize>20</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>SCHEME_NAME</design:name>
<design:position>2</design:position>
<design:precision>50</design:precision>
<design:uiHints>
<design:displayName>SCHEME_NAME</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>SCHEME_NAME</design:label>
<design:displaySize>50</design:displaySize>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet" name="main" id="903">
<structure>
</structure>
<structure>
<property name="columnName">UPLOAD_PHOTO_FILENAME</property>
<property name="displayName">UPLOAD_PHOTO_FILENAME</property>
</structure>
<structure>
<property name="columnName">APPLICANT_ID</property>
<property name="displayName">APPLICANT_ID</property>
</structure>
<structure>
<property name="columnName">INTERVIEW_TIME</property>
<property name="displayName">INTERVIEW_TIME</property>
</structure>
<structure>
<property name="columnName">FULL_NAME</property>
<property name="displayName">FULL_NAME</property>
</structure>
<structure>
<property name="columnName">DOB</property>
<property name="displayName">DOB</property>
</structure>
<structure>
<property name="columnName">GENDER_CD</property>
<property name="displayName">GENDER_CD</property>
</structure>
<structure>
<property name="columnName">CITIZENSHIP</property>
<property name="displayName">CITIZENSHIP</property>
</structure>
<structure>
<property name="columnName">NRIC</property>
<property name="displayName">NRIC</property>
</structure>
<structure>
<property name="columnName">FIN</property>
<property name="displayName">FIN</property>
</structure>
<structure>
<property name="columnName">ADDRESS_LINE1</property>
<property name="displayName">ADDRESS_LINE1</property>
</structure>
<structure>
<property name="columnName">ADDRESS_LINE2</property>
<property name="displayName">ADDRESS_LINE2</property>
</structure>
<structure>
<property name="columnName">ADDRESS_LINE3</property>
<property name="displayName">ADDRESS_LINE3</property>
</structure>
<structure>
<property name="columnName">TEL_NO</property>
<property name="displayName">TEL_NO</property>
</structure>
<structure>
<property name="columnName">CCA_GRADE</property>
<property name="displayName">CCA_GRADE</property>
</structure>
<structure>
<property name="columnName">SELF_WRITE_UP</property>
<property name="displayName">SELF_WRITE_UP</property>
</structure>
<structure>
<property name="columnName">IP_YN</property>
<property name="displayName">IP_YN</property>
</structure>
<structure>
<property name="columnName">INTERVIEW_DT</property>
<property name="displayName">INTERVIEW_DT</property>
</structure>
</list-property>
<structure>
</structure>
<structure>
<property name="name">UPLOAD_PHOTO_FILENAME</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">APPLICANT_ID</property>
<property name="dataType">decimal</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">INTERVIEW_TIME</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">FULL_NAME</property>
</structure>
<structure>
<property name="position">6</property>
<property name="name">DOB</property>
<property name="dataType">date-time</property>
</structure>
<structure>
<property name="position">7</property>
<property name="name">GENDER_CD</property>
</structure>
<structure>
<property name="position">8</property>
<property name="name">CITIZENSHIP</property>
</structure>
<structure>
<property name="position">9</property>
<property name="name">NRIC</property>
</structure>
<structure>
<property name="position">10</property>
<property name="name">FIN</property>
</structure>
<structure>
<property name="position">11</property>
<property name="name">ADDRESS_LINE1</property>
</structure>
<structure>
<property name="position">12</property>
<property name="name">ADDRESS_LINE2</property>
</structure>
<structure>
<property name="position">13</property>
<property name="name">ADDRESS_LINE3</property>
</structure>
<structure>
<property name="position">14</property>
<property name="name">TEL_NO</property>
</structure>
<structure>
<property name="position">15</property>
<property name="name">CCA_GRADE</property>
</structure>
<structure>
<property name="position">16</property>
<property name="name">SELF_WRITE_UP</property>
</structure>
<structure>
<property name="position">17</property>
<property name="name">IP_YN</property>
</structure>
<structure>
<property name="position">18</property>
<property name="name">INTERVIEW_DT</property>
</structure>
</list-property>
</structure>
<method name="beforeOpen"><![CDATA[paramInterviewSchId = params["Interview Schedule Id"].value;
if(params["Interview Schedule Id"].value!=null && params["Interview Schedule Id"].value !=""){
this.queryText = this.queryText.replaceAll("##InterviewScheduleId##"," AND ISL.INTERVIEW_SCHED_ID = '"+escapeSpecialChar(paramInterviewSchId)+"'");
}else{
this.queryText = this.queryText.replaceAll("##InterviewScheduleId##","");
}]]></method>
<structure>
</structure>
<structure>
<property name="nativeName">UPLOAD_PHOTO_FILENAME</property>
</structure>
<structure>
<property name="nativeName">APPLICANT_ID</property>
<property name="nativeDataType">3</property>
</structure>
<structure>
<property name="nativeName">INTERVIEW_TIME</property>
</structure>
<structure>
<property name="nativeName">FULL_NAME</property>
</structure>
<structure>
<property name="nativeName">DOB</property>
<property name="nativeDataType">93</property>
</structure>
<structure>
<property name="nativeName">GENDER_CD</property>
</structure>
<structure>
<property name="nativeName">CITIZENSHIP</property>
</structure>
<structure>
<property name="nativeName">NRIC</property>
</structure>
<structure>
<property name="nativeName">FIN</property>
</structure>
<structure>
<property name="nativeName">ADDRESS_LINE1</property>
</structure>
<structure>
<property name="nativeName">ADDRESS_LINE2</property>
</structure>
<structure>
<property name="nativeName">ADDRESS_LINE3</property>
</structure>
<structure>
<property name="nativeName">TEL_NO</property>
</structure>
<structure>
<property name="nativeName">CCA_GRADE</property>
</structure>
<structure>
<property name="nativeName">SELF_WRITE_UP</property>
</structure>
<structure>
<property name="nativeName">IP_YN</property>
</structure>
<structure>
<property name="nativeName">INTERVIEW_DT</property>
</structure>
</list-property>
<property name="queryText">SELECT S.SCHEME_NAME,NVL2(APP.APPLICANT_ID,'D:\\'||APP.APPLICANT_ID||'.jpg',NULL) UPLOAD_PHOTO_FILENAME,
APP.APPLICANT_ID,LTRIM(TO_CHAR(TO_DATE(ISTAL.INTERVIEW_TIME,'HH24MI'),'HH12.MI AM'),'0') INTERVIEW_TIME,
APP.FULL_NAME,APP.DOB DOB,APP.GENDER_CD,
AZ_PKG_COM_4RPT.AZ_FN_GETCODEDESC('citizen',APP.CITIZENSHIP_CD) CITIZENSHIP,APP.NRIC,APP.FIN,
ADDR.ADDRESS_LINE1,ADDR.ADDRESS_LINE2,ADDR.ADDRESS_LINE3,APP.TEL_NO,
AZ_PKG_COM_4RPT.AZ_FN_GETCODEDESC('oLvlGrade',APP.OVERALL_CCA_GRADE) CCA_GRADE,APPS.SELF_WRITE_UP,APP.IP_YN,
ISL.INTERVIEW_DT INTERVIEW_DT
FROM AZ_APPLICANT APP,
AZ_APPLICANT_SCHEME APPS,
AZ_INTERVIEW_SCHED_LS ISL,
AZ_INTERVIEW_SCHED_TO_APPL_LS ISTAL,
AZ_SCHEME S,
AZ_APPLICANT_ADDR ADDR
WHERE S.SCHEME_ID = APPS.SCHEME_ID
AND APPS.APPLICANT_ID = APP.APPLICANT_ID
AND ISL.SCHEME_ID = S.SCHEME_ID
AND ISTAL.SCHEDULE_ID = ISL.SCHEDULE_ID
AND ISTAL.APPLICANT_SCHEME_ID = APPS.APPLICANT_SCHEME_ID
AND ADDR.APPLICANT_ID = APP.APPLICANT_ID
AND ADDR.ADDR_TYPE = 'H'
AND S.SCHEME_ID = '2010ISD1ANL'
--##InterviewScheduleId##
ORDER BY ISL.INTERVIEW_DT,TO_DATE(ISTAL.INTERVIEW_TIME,'HH24MI')</property>
</oda-data-set>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet" name="familyBkg" id="943">
<structure>
</structure>
<structure>
<property name="columnName">RELATIONSHIP</property>
<property name="displayName">RELATIONSHIP</property>
</structure>
<structure>
</structure>
<structure>
<property name="columnName">OCCUPATION</property>
<property name="displayName">OCCUPATION</property>
</structure>
</list-property>
<structure>
</structure>
<structure>
<property name="name">RELATIONSHIP</property>
</structure>
<structure>
</structure>
<structure>
<property name="name">OCCUPATION</property>
</structure>
</list-property>
</structure>
<list-property name="parameters">
<structure>
<property name="name">app_id</property>
<property name="nativeName"></property>
<expression name="defaultValue">1</expression>
<property name="allowNull">false</property>
<property name="isInput">true</property>
<property name="isOutput">false</property>
</structure>
<structure>
<property name="name">app_id1</property>
</structure>
</list-property>
<structure>
</structure>
<structure>
<property name="nativeName">RELATIONSHIP</property>
</structure>
<structure>
</structure>
<structure>
<property name="nativeName">OCCUPATION</property>
</structure>
</list-property>
<property name="queryText">SELECT FAM.FULL_NAME,AZ_PKG_COM_4RPT.AZ_FN_GETCODEDESC('paRelation',FAM.RELATIONSHIP_CD) RELATIONSHIP,
AZ_PKG_COM_4RPT.AZ_FN_GETCODEDESC('citizen',FAM.CITIZENSHIP_CD) CITIZENSHIP,
FAM.OCCUPATION
FROM AZ_APPLICANT_FAMILY FAM
WHERE FAM.APPLICANT_ID = ?
AND FAM.RELATIONSHIP_CD IN ('F','M','G')
UNION ALL
SELECT FAM.FULL_NAME,AZ_PKG_COM_4RPT.AZ_FN_GETCODEDESC('sbRelation',FAM.RELATIONSHIP_CD) RELATIONSHIP,
FAM.OCCUPATION
AND FAM.RELATIONSHIP_CD IN ('S','B')</property>
<design:DataSetParameters>
<design:parameterDefinitions>
<design:inOutMode>In</design:inOutMode>
<design:attributes>
<design:name></design:name>
<design:nativeDataTypeCode>3</design:nativeDataTypeCode>
<design:precision>38</design:precision>
<design:nullability>NotNullable</design:nullability>
</design:parameterDefinitions>
<design:attributes>
</design:DataSetParameters>
<design:attributes>
<design:name>FULL_NAME</design:name>
<design:precision>80</design:precision>
<design:uiHints>
<design:displayName>FULL_NAME</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>FULL_NAME</design:label>
<design:displaySize>80</design:displaySize>
<design:attributes>
<design:name>RELATIONSHIP</design:name>
<design:precision>4000</design:precision>
<design:uiHints>
<design:displayName>RELATIONSHIP</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>RELATIONSHIP</design:label>
<design:displaySize>4000</design:displaySize>
<design:attributes>
<design:name>CITIZENSHIP</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>CITIZENSHIP</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CITIZENSHIP</design:label>
<design:attributes>
<design:name>OCCUPATION</design:name>
<design:position>4</design:position>
<design:precision>300</design:precision>
<design:uiHints>
<design:displayName>OCCUPATION</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>OCCUPATION</design:label>
<design:displaySize>100</design:displaySize>
</oda-data-set>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet" name="academicInfoSec" id="1058">
<structure>
<property name="columnName">SEC_SCHOOL</property>
<property name="displayName">SEC_SCHOOL</property>
</structure>
</list-property>
<structure>
<property name="name">SEC_SCHOOL</property>
</structure>
</list-property>
</structure>
<structure>
</structure>
</list-property>
<structure>
<property name="nativeName">SEC_SCHOOL</property>
</structure>
</list-property>
CASE
WHEN APPL.IP_YN = 'Y' THEN AZ_PKG_COM_4RPT.az_fn_getCodeDesc('locSch',EDU.SCHOOL_CD)
ELSE EDU.SECONDARY_SCHOOL_NAME
END SEC_SCHOOL
FROM AZ_APPLICANT APPL LEFT JOIN AZ_APPLICANT_EDU_BKG EDU
ON EDU.APPLICANT_ID = APPL.APPLICANT_ID AND EDU.EDU_TYPE_CD = 'SEC'
WHERE APPL.APPLICANT_ID = ?</property>
<design:attributes>
<design:attributes>
<design:name>SEC_SCHOOL</design:name>
<design:uiHints>
<design:displayName>SEC_SCHOOL</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>SEC_SCHOOL</design:label>
</oda-data-set>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet" name="academicInfoJC" id="1059">
<structure>
<property name="columnName">JC_SCHOOL</property>
<property name="displayName">JC_SCHOOL</property>
</structure>
</list-property>
<structure>
<property name="name">JC_SCHOOL</property>
</structure>
</list-property>
</structure>
<structure>
</structure>
</list-property>
<structure>
<property name="nativeName">JC_SCHOOL</property>
</structure>
</list-property>
<property name="queryText">SELECT AZ_PKG_COM_4RPT.AZ_FN_GETCODEDESC('locSch',EDU.SCHOOL_CD) JC_SCHOOL
FROM AZ_APPLICANT_EDU_BKG EDU
WHERE EDU.APPLICANT_ID = ?
AND EDU.EDU_TYPE_CD = 'JC'</property>
<design:attributes>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
</oda-data-set>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet" name="subject" id="1090">
<structure>
<property name="columnName">SUBJECT</property>
<property name="displayName">SUBJECT</property>
</structure>
<structure>
<property name="columnName">GRADE</property>
<property name="displayName">GRADE</property>
</structure>
</list-property>
<structure>
<property name="name">SUBJECT</property>
</structure>
<structure>
<property name="name">GRADE</property>
</structure>
</list-property>
</structure>
<structure>
Re: How to show the image in birt report? [message #657818 is a reply to message #657811] |
Fri, 04 March 2011 03:48  |
Bob wrote on Fri, 04 March 2011 03:05 | Hi Magnet,
Sorry, I misunderstand you're Jason. Thanks a lots.
Bob
Hey bob
Thats perfectly fine.. I was just trying to put some humor .. at the same time wanted to know if there are any other solution used offline. I am happy that my first solution posted at the forum was useful & made you happy.... cheers!!
Magnet
Current Time: Sat Jul 26 19:58:30 EDT 2025
Powered by FUDForum. Page generated in 0.04967 seconds
