Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EEF] NPE when selecting to add a relation
[EEF] NPE when selecting to add a relation [message #656855] Mon, 28 February 2011 14:16 Go to next message
I am getting an NPE when selecting to add a relation
The stack trace is:
java.lang.NullPointerException at
org.eclipse.emf.eef.runtime.ui.widgets.settings.AdvancedEEFE ditorContentProvider.getElements(AdvancedEEFEditorContentPro vider.java:65)
org.eclipse.jface.viewers.StructuredViewer.getRawChildren(St ructuredViewer.java:989)
org.eclipse.jface.viewers.ColumnViewer.getRawChildren(Column Viewer.java:703)
org.eclipse.jface.viewers.AbstractTreeViewer.getRawChildren( AbstractTreeViewer.java:1332)
org.eclipse.jface.viewers.TreeViewer.getRawChildren(TreeView er.java:391)
which point to this line of code:
EList<Resource> resources =
((EEFEditorSettings)object).getSource().eResource().getResou rceSet().getResources();
and it happens because the getResourceSet() portion is returning null.
If I create at least one entry matching the relation the error goes away
and I see the dialog allowing me to select from the Model Resource or
All Resource.
Alain
Re: [EEF] NPE when selecting to add a relation [message #657112 is a reply to message #656855] Tue, 01 March 2011 11:01 Go to previous messageGo to next message
Alain,
It's a little odd that you'd have a resource that isn't in a resource
set. How does that happen?
> The stack trace is:
> away and I see the dialog allowing me to select from the Model
> Resource or All Resource.
> Thanks
> Alain
Re: [EEF] NPE when selecting to add a relation [message #657183 is a reply to message #657112] Tue, 01 March 2011 15:54 Go to previous messageGo to next message
On 3/1/2011 11:01 AM, Ed Merks wrote:
> Alain,
Not sure but it does. :)
Alain
>> The stack trace is:
>> Thanks
>> Alain
Re: [EEF] NPE when selecting to add a relation [message #657201 is a reply to message #657183] Tue, 01 March 2011 17:35 Go to previous messageGo to next message
Alain,
I imagine they'll likely need a test case for this if you want to report
it as a bug. In the mean time, you could determine the URI of that
resource, who's creating a resource URI, and why it's not created as
part of a resource set. It's quite unusual to have "free floating"
resources...
>> Alain,
> Alain
>>> The stack trace is:
>>> Thanks
>>> Alain
Re: [EEF] NPE when selecting to add a relation [message #657224 is a reply to message #657201] Tue, 01 March 2011 20:37 Go to previous messageGo to next message
On 3/1/2011 5:35 PM, Ed Merks wrote:
Ed,
The example is a simple modification of the model1.ecore from CDO again,
just with the offending Map$Entry removed.
I just found a very interesting thing. In
we have:
public Object[] getElements(Object object) {
if (object instanceof EEFEditorSettings) {
resources.retainAll(this.choiceOfValues);
return resources.toArray();
return super.getElements(object);
what happens is that if I click the + button on a widget implemented
with AdvancedReferencesTable when there is no reference content that
exist, the getElements() method is called a first time and there is no
error, but resources is set to an empty list. Then when it calls
resources.retainAll with an empty choice a values, the retainAll ends up
calling remove, which calls inverseRemove which ends with:
return resource.basicSetResourceSet(null, notifications); resetting the
Resourceset value to null.
Then on the following calls, the resourceset is null and voila, an NPE.
HTH,
Alain
> Alain,
> resources...
>>> Alain,
>> Alain
>>>> The stack trace is:
>>>> Thanks
>>>> Alain
Re: [EEF] NPE when selecting to add a relation [message #657234 is a reply to message #657224] Tue, 01 March 2011 22:59 Go to previous messageGo to next message
Alain,
Comments below.
> Ed,
> again, just with the offending Map$Entry removed.
> we have:
Modifying the resource set itself as part of producing a view for it
seems totally bad! This code should make a copy of the list of resources...
> up calling remove, which calls inverseRemove which ends with:
> the Resourceset value to null.
> HTH,
> Alain
>> Alain,
>> resources...
>>>> Alain,
>>> Alain
>>>>> The stack trace is:
>>>>> null.
>>>>> Thanks
>>>>> Alain
Re: [EEF] NPE when selecting to add a relation [message #658194 is a reply to message #657234] Mon, 07 March 2011 06:21 Go to previous message
It's an important bug. I fix it in the next EEF 0.9 RC.
Goulwen Le Fur - goulwen.lefur@obeo.fr
Le 02/03/2011 04:59, Ed Merks a écrit :
> Alain,
> Comments below.
>> Ed,
>> we have:
>> HTH,
>> Alain
>>> Alain,
>>> resources...
>>>>> Alain,
>>>> Alain
>>>>>> The stack trace is:
>>>>>> null.
>>>>>> Thanks
>>>>>> Alain
Previous Topic:Export code generator to Runnable-JAR file
Next Topic:[EEF] FeatureMap entry binary name
Current Time: Thu Jul 24 21:37:42 EDT 2025
Powered by FUDForum. Page generated in 0.10440 seconds
