Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Compare] Ecore diagram for EMF Compare metamodel?
[EMF Compare] Ecore diagram for EMF Compare metamodel? [message #657051] Tue, 01 March 2011 08:18 Go to next message
I would like to take a look at the EMF Compare metamodel in the Ecore diagram form, as to better understand all the references.
Where can I find the diagram or the original Ecore model? Is there possibly a way to create an Ecore diagram from the Ecore model in Eclipse?
Thanks!
Re: [EMF Compare] Ecore diagram for EMF Compare metamodel? [message #657113 is a reply to message #657051] Tue, 01 March 2011 11:02 Go to previous messageGo to next message
Leonard,
There might not be a diagram for it. The Ecore model for compare is
likely in the same bundle where the generated package is hosted. If you
import that bundle as source into your workspace, you could work
directly with it.
leonard.krpan@bmw-carit.de wrote:
> Eclipse?
> Thanks!
Re: [EMF Compare] Ecore diagram for EMF Compare metamodel? [message #657114 is a reply to message #657051] Tue, 01 March 2011 11:05 Go to previous message
Hi Lenoard,
You'll find the Ecore models in each plugin :
org.eclipse.emf.compare.diff/model/diff.ecore
For the diff model, quickly generated diagram here :
http://img684.imageshack.us/img684/972/diffpackageentities.j pg
org.eclipse.emf.compare.match/model/match.ecore
For the match model, diagram here :
http://img855.imageshack.us/img855/3167/matchpackageentities .jpg
Cédric
> Thanks!
Previous Topic:[Texo] documentation fields
Next Topic:[EMF Compare] Left and right vs. original and changed model
Current Time: Sat Jul 19 01:15:25 EDT 2025
Powered by FUDForum. Page generated in 0.03805 seconds
