Home » Modeling » Epsilon » [EVL] Validation on EMF editor
[EVL] Validation on EMF editor [message #656523] Sat, 26 February 2011 05:19 Go to next message
Hi there,
Is it possible to use EVL for validating not only the GMF diagram but also the (EMF) model itself?
In the GMF mindmap tutorial for example, I would like to validate the xxx.mindmap file (in addition to the xxx.minmap_diagram). Is this possible with EVL?
Christian
Re: [EVL] Validation on EMF editor [message #657056 is a reply to message #656523] Tue, 01 March 2011 08:39 Go to previous messageGo to next message
Hi Christian,
To do this, you need to open the .mindmap file, right-click on the root model element and select "Validate".
Dimitris
Re: [EVL] Validation on EMF editor [message #659203 is a reply to message #656523] Fri, 11 March 2011 09:26 Go to previous messageGo to next message
Oh, now that's kinda embarassing Smile
I expected it to be under Edit -> Validate (like in GMF)..
I want to run the validation whenever i save the model file, like i did for the diagram via XXXDocumentProvider. Can you help me out on this matter, or should I post this question in the EMF forums?
Christian
Re: [EVL] Validation on EMF editor [message #659205 is a reply to message #659203] Fri, 11 March 2011 09:47 Go to previous messageGo to next message
Hi Christian,
I'm not really sure how to do this (haven't needed to so far) so I guess asking in the EMF newsgroup sounds like a good idea.
Dimitris
Re: [EVL] Validation on EMF editor [message #659207 is a reply to message #656523] Fri, 11 March 2011 09:51 Go to previous message
Thanks for the quick response.
I just stumbled upon this post which adresses my issue.
Previous Topic:On ConstraintsBinding for Model validation with EVL
Next Topic:ETL problem
Current Time: Wed Jul 23 15:34:55 EDT 2025
Powered by FUDForum. Page generated in 0.25738 seconds
