Home » Modeling » M2T (model-to-text transformation) » [Acceleo 3] ServiceWrapper Problem during generation
[Acceleo 3] ServiceWrapper Problem during generation [message #653196] Tue, 08 February 2011 15:15 Go to next message
i use acceleo 3.0.1. There is a strange behavoir during the generation process.
Considering the following scenario:
I created a java service wrapper with a method that fills a list. The list as an attribute of the service wrapper class. In the constructor i create an instance of these list.
Example:
private Set<Element> systemStates = null;
public ListServices() {
if(this.systemStates == null) {
this.systemStates = new LinkedHashSet<Element>();
So now i create a method that put state elements in this list. In my template i call the method for state elements. But if i call these template in two times in my generation process only one instance from my serviceclass exists and the list is filled with all values from the first call. I would expect that for every call of my template a new instance of the servicewrapper class will be created.
Best regards
Maik
[Updated on: Tue, 08 February 2011 15:34] by Moderator
Re: [Acceleo] [message #653280 is a reply to message #653196] Wed, 09 February 2011 03:03 Go to previous messageGo to next message
--------------010204080600030400070602
Hi Maik,
The service classes are only instantiated when we need to (thus not for
static method calls or when we are passed an instance of the class to
call the method on), and only once if we ever do.
If you do want the "systemStates" Set to be cleared, you'll have to do
it before calling methods on this service wrapper.
Laurent Goubet
Obeo
On 08/02/2011 21:16, Maik wrote:
> process.
> Example:
> Best regards
> Maik
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------010204080600030400070602--
Re: [Acceleo] [message #653559 is a reply to message #653280] Thu, 10 February 2011 04:26 Go to previous messageGo to next message
Hi Laurent,
thanks for your answer. Could you give me the class name from accleo who handle this service wrapper generation? I would look into the source code.
Is this java file
org.eclipse.acceleo.common/src/org/eclipse/acceleo/common/Ac celeoServicesRegistry.java??
Best regards
Maik
[Updated on: Thu, 10 February 2011 05:26] by Moderator
Re: [Acceleo] [message #653609 is a reply to message #653559] Thu, 10 February 2011 06:56 Go to previous messageGo to next message
--------------020100050909070709020106
Hi Maik,
The services in Acceleo 3 are stateful : their variables won't be reset
between two invocations. This behavior is a design choice we made, thus
we won't change it even if someone were to provide us with a patch.
If you truly wish to do with a forked version of Acceleo, you can take a
look at the implementations of
AcceleoServicesRegisty#getServiceInstance (in charge of instantiating
services in standalone)
and
AcceleoWorkspaceUtil#getServiceInstance (in charge of instantiating
services when within Eclipse)
Laurent Goubet
Obeo
On 10/02/2011 10:26, Maik wrote:
> Hi Laurent,
> Best regards
> Maik
--------------020100050909070709020106--
Re: [Acceleo] [message #656995 is a reply to message #653609] Tue, 01 March 2011 05:11 Go to previous messageGo to next message
Hi Laurent,
thanks for your answers. I'am a big fan of the whole acceleo project. Maybe we can find a solution for both of us and the community.
Would it be possible from your side to implement a property (true|false or new kind of generation in doGenerate() methode) where the user can decide in the generation class, if a service will be use as singleton or not?
Best regards
Maik
[Updated on: Tue, 01 March 2011 05:17] by Moderator
Re: [Acceleo] [message #657006 is a reply to message #656995] Tue, 01 March 2011 05:42 Go to previous messageGo to next message
--------------060909050806000201060203
Hi Maik,
This might sound more like a workaround but... can't you reinitialize
your variable when you call your service a second time? It sounds like
you're trying to use the service sometimes as a singleton (otherwise,
why initialize your list only once?) and sometimes as a regular Object
(thus your need to reinitialize it).
Laurent Goubet
Obeo
On 01/03/2011 11:11, Maik wrote:
> Hi Laurent,
> Maybe we can find a solution for both of us and the community. Would it
> be possible from your side to implement a property (true|false) where
> the user can decied in the generation class, if a service will be use as
> singleton or not?
> Best regards
> Maik
--------------060909050806000201060203--
Re: [Acceleo] [message #657286 is a reply to message #657006] Wed, 02 March 2011 05:45 Go to previous messageGo to next message
Hi Laurent,
at the moment i clear the list in the template, via a method resetList(). The method is implemented as a service too.
We have here to following scenarion:
The templates runs through every state. If a state has a defined stereotype (defined by us) then a method (as service) will be called who checks the outgoings from the current state and the next states from the outgoing and so on until the next state with this defined stereotype. All states between these both state with defined stereotype will be stored in a list.
The method call is recursiv. We need to delete (reset) the list for every call of the template because there is only one instance. Sad
public SystemStateServices() {
The method has the follwoing signature
public Set<Element> getSystemStatesUntilViewState(Transition t)
and the reset method
public void resetList(Set<Element> list){
list.clear();
and the template who use the service
[template public systemClassTemplate(state : uml::State)]
[let liste : Set(Element) = transition.getSystemStatesUntilViewState()]
[for (element : Element | liste)]
[if (element.oclIsTypeOf(State))]
[helperClassSystemStates(element.oclAsType(State))/]
[/if]
[/for]
reset the list
[/comment]
[resetList(liste)/]
[/let]
The problem ist that we need to reset the list in a template. Sad It should be fine if we can decide with a property during the generation -> use services as singleton or not. Wink
Best regards
Maik
[Updated on: Wed, 02 March 2011 05:56] by Moderator
Re: [Acceleo] [message #657545 is a reply to message #657286] Thu, 03 March 2011 03:58 Go to previous messageGo to next message
--------------000601060600010405030701
Maik,
Why do you have the "systemStates" collection as a field is what I do
not get. It does not seem to me as the implementation you want for this
service.
public class SystemStateService {
public Set<Element> getSystemStatesUntilViewState(Transition t) {
Set<Element> systemStates = new LinkedHashSet<Element>();
// Do stuff
return systemStates;
seem more like the solution you seek. Why did you make that set a class
member? Why do you instantiate it as a singleton?
Laurent Goubet
Obeo
On 02/03/2011 11:45, Maik wrote:
> Hi Laurent,
> resetList(). The method is implemented as a service too. But i think is
> only a workaround to delete the list in a template.
> stored in a list.
> every call of the template because there is only one instance. :(
> list.clear();
> [/if]
> [/for]
> reset the list
> [/comment]
> [resetList(liste)/]
> [/let]
> The problem ist that we need to reset the list in a template. :(
> Best regards
> Maik
--------------000601060600010405030701--
Re: [Acceleo] [message #657661 is a reply to message #657545] Thu, 03 March 2011 10:38 Go to previous messageGo to next message
Hi Laurent,
i can't create the list in the method because there is a recursivly call.
public class ServiceHelper {
public ServiceHelper () {
if (!(t.getTarget() instanceof FinalState)) {
if (t.getTarget() instanceof State) {
if (!hasViewStateStereotype((State) t.getTarget())) {
systemStates.add((State) t.getTarget());
return getSystemStatesUntilViewState(((Transition) t
.getTarget().getOutgoings().get(0)));
Best regards
Maik
Re: [Acceleo] [message #657822 is a reply to message #657661] Fri, 04 March 2011 03:40 Go to previous message
--------------010700080004070403050702
This could be changed to :
return
systemStates.addAll(getSystemStatesUntilViewState(((Transiti on) t
.getTarget().getOutgoings().get(0))));
I usually favor short-lived objects to long-lived ones, especially when
it impacts readability (Who changes my set? From where? In which cases?
Why reset it?).
I do aggree that this might seem to you as a workaround for the fact
Acceleo does not reinstantiates its services... but what you see as a
bug (my "set" field is not emptied") was asked for as a feature in the
previous Acceleo, and we do think this is the best handling for services.
Laurent Goubet
Obeo
On 03/03/2011 16:38, Maik wrote:
> Hi Laurent,
> Best regards Maik
--------------010700080004070403050702--
Previous Topic:[Acceleo] eliminate white lines generated by template
Next Topic:[Acceleo 3] Update site problem
Current Time: Thu Nov 06 15:40:49 EST 2025
Powered by FUDForum. Page generated in 0.63547 seconds
