Re: EMF Spreadsheet Model [message #657079 is a reply to message #656976] |
Tue, 01 March 2011 09:38   |
Antoine,
Comments below.
Antoine wrote:
> Hello everyone !
> I've made a simple spreadsheet model (that you can see at the end of
> this post) with EMF (Ecore and Ecore Diag).
No, I don't see them.
> I've generated the Model Code, Edit and Editor plugins by EMF but when
> I define a relatedHeader in a Cell with an already defined
> HeaderElement (method setRelatedHeader(HeaderElement e)), it seems to
> work but when I load the ressource in the editor, it fails and I have
> this error for each Cell where there is a relatedHeader:
> org.eclipse.emf.ecore.xmi.IllegalValueException: Value
> 'spreadsheet.impl.LineImpl@dbe4e5 (num: 2)' is not legal.
> (platform:/resource/Test/model/Example.spreadsheet, 37, 67)
> Caused by: java.lang.ClassCastException: spreadsheet.impl.LineImpl
> cannot be cast to spreadsheet.HeaderElement
Is it possible that you have more than one object with the same ID, i.e,
with ID "1" or "2"? Even if the objects are of different type, the ID
must be unique within the resource. Try invoking "Validate..." in the
editor before you save to check for this.
> If I open the file with a XML editor, this one looks fine :
> <?xml version="1.0" encoding="ASCII"?>
> <spreadsheet:Spreadsheet xmi:version="2.0"
> xmlns:xmi="http://www.omg.org/XMI" xmlns:spreadsheet="spreadsheet"
> name="ExampleICD">
> <containedSheets name="TestSheet1">
> <containedLines num="2">
> <containedCells content="Value1" x="1" y="2"relatedHeader="1"/>
> <containedCells content="12" x="2" y="2" relatedHeader="2"/>
> </containedLines>
> <containedLines num="3">
> <containedCells content="Value2" x="1" y="3" relatedHeader="1"/>
> <containedCells content="54" x="2" y="3" relatedHeader="2"/>
> </containedLines>
> <header content="Name" x="1" y="1" relatedHeader="1" id="1"/>
> <header content="Value" x="2" y="1" relatedHeader="2" id="2"/>
> </containedSheets>
> </spreadsheet:Spreadsheet>
> If I didn't create any relatedHeader in a Cell, the editor accepts to
> open it.
> So is it a modelisation error, or a bug from me or EMF ? Anybody knows ?
I suspect you're using num and id as IDs and that there are two things
with ID "2".
> Thank you
> Antoine
FUDForum. Page generated in 0.06079 seconds
