Home » Archived » M2M (model-to-model transformation) » [ATL] content assist with library use
[ATL] content assist with library use [message #655910] Wed, 23 February 2011 04:35 Go to next message
Hello
Anybody know how getting a content assit with a library ? I've heard in
a training about ATL that it should be possible.
I've tried this :
-- @nsURI UML=http://www.eclipse.org/uml2/3.0.0/UML
-- @path
stateMachine=/stateMachine.project/transformation/stateMachi ne.atl
module stateMachine2Class;
create OUT : UML from IN : UML;
uses stateMachine;
The transformation works, but the content assist is not working when
using helpers defined in the library.
Re: [ATL] content assist with library use [message #655929 is a reply to message #655910] Wed, 23 February 2011 05:30 Go to previous messageGo to next message
Sorry, I forgot courtesy..
Same message than ID7102
Anybody know how getting a content assit with a library ? I've heard in a
I've tried this :
-- @path stateMachine=/stateMachine.project/transformation/stateMachi ne.atl
uses stateMachine;
The transformation works, but the content assist is not working when using
Thank you in advance
Kind regards
Cédric Gava
Kind regards
Cédric Gava
Re: [ATL] content assist with library use [message #656715 is a reply to message #655910] Mon, 28 February 2011 03:54 Go to previous messageGo to next message
--------------050404020705090209060103
In case of libraries, you have to use th "--@lib" tag instead of
"--@path", e.g. :
-- @lib stateMachine=/stateMachine.project/transformation/stateMachi ne.atl
It should work this way.
William
Le 23/02/2011 10:35, cedric gava a
Re: [ATL] content assist with library use [message #656960 is a reply to message #656715] Tue, 01 March 2011 02:57 Go to previous message
Thank you very much William
Best regards
Cédric
> Hello,
> In case of libraries, you have to use th "--@lib" tag instead of "--@path",
> e.g. :
> Best regards,
> William
Previous Topic:[ATL] resoveTemp and eopposite
Next Topic:M2M with interfaces
Current Time: Sun Aug 31 02:13:42 EDT 2025
Powered by FUDForum. Page generated in 0.03990 seconds
