Home » Archived » BIRT » Stored procedure is not available in the New Data Set dialog(How do I make my stored procedure available in the New Data Set dialog?)
Stored procedure is not available in the New Data Set dialog [message #656472] Fri, 25 February 2011 15:05 Go to next message
I am new to using BIRT... I apologize if my question is too simple.
I am following the ClassicModels tutorial that came with the BIRT download. I am using the birt-report-framework-2_5_2 version and MySql 5.5.9 for Windows.
I finished the tutorial but I now want to call a stored procedure within a newly created Data Set.
Below is the code to my stored procedure in my .sql file:
create procedure ClassicModels.getAllCustInfo()
BEGIN
select state, city, customerName, phone
from customers
order by state, city, customerName;
END
Within the MySql command line prompt, I created this stored procedure and called it without any problems as such:
call getAllCustInfo();
When I go back to the the BIRT New Data Set dialog, this stored procedure is not listed under the 'stored procedure' item in the tree for my database schema that it belongs to. Thus, I cannot call this stored procedure.
Am I missing a step?
Thanks so much in advance,
--Anna
Re: Stored procedure is not available in the New Data Set dialog [message #656475 is a reply to message #656472] Fri, 25 February 2011 15:12 Go to previous messageGo to next message
Anna,
In the new dataset editor are you choosing SQL Stored Procedure Query as
the data set type?
After setting the type you should be able to enter:
{call getAllCustInfo()}
as the query.
Jason
On 2/25/2011 3:05 PM, anna.w.teittinen@gmail.com wrote:
> Hello,
> 5.5.9 for Windows.
> BEGIN
> select state, city, customerName, phone from customers
> END
> stored procedure.
> --Anna
Re: Stored procedure is not available in the New Data Set dialog [message #656478 is a reply to message #656475] Fri, 25 February 2011 15:27 Go to previous messageGo to next message
Hello Jason,
Yes, I did that but I got the following error after I click the "Finish Button" on the New Data Set dialog:
A BIRT exception occurred.
Plug-in Provider:Eclipse.org
Plug-in Name:BIRT Data Engine
Plug-in ID:org.eclipse.birt.data
Version:2.5.2.v20100209
Error Code:data.engine.fail.prepareExecution
Error Message:Failed to prepare the query execution for the data set: mySP
Failed to prepare the following query for the data set type (org.eclipse.birt.report.data.oda.jdbc.SPSelectDataSet).
[{call ClassicModels.getAllCustInfo()} ]
Error preparing SQL statement.
SQL error #1: 'CLASSICMODELS.GETALLCUSTINFO' is not recognized as a function or procedure.
The last line in the error message indicates that GETALLCUSTINFO is not a stored procedure. It should be since I tested it fine on the MySql command line.
--Anna
Re: Stored procedure is not available in the New Data Set dialog [message #656479 is a reply to message #656472] Fri, 25 February 2011 15:30 Go to previous messageGo to next message
I don't know about MySQL, but in Oracle if you want to use a stored procedure to fetch a data set, you have to define the procedure to return a CURSOR type to the JDBC interface. It's neither intuitive nor simple. I suspect you'll need to find someone who has done this with BIRT and MySQL specifically to get an answer to your question.
Which leaves aside the main question, that being, why do you need to do that from the context of a stored procedure? BIRT can certainly execute what you're showing as a straight SQL query passed to the database back end.
Richard
Re: Stored procedure is not available in the New Data Set dialog [message #656483 is a reply to message #656479] Fri, 25 February 2011 15:42 Go to previous messageGo to next message
Hello Richard,
I need to use stored procedures so that the intended end user does not need to have SQL smarts to create a report.
I am using MySql now just to follow the tutorial using the ClassicModels database that came with BIRT.
I will actually be using Oracle with BIRT for my work project after I get an understanding of how to call the stored procedure I created.
Just curious, how would I change the simple stored procedure below to return an CURSOR type as you suggested?
BEGIN
from customers
END
Thanks alot again,
--Anna
Re: Stored procedure is not available in the New Data Set dialog [message #656491 is a reply to message #656472] Fri, 25 February 2011 16:51 Go to previous messageGo to next message
In Oracle (and it depends on which version of Oracle), I have to define the stored procedure similar to the following:
CREATE OR REPLACE procedure getcounterparties( p_cursor in out SYS_REFCURSOR)
as
begin
open p_cursor for select name, id from counterparty;
end;
I don't know how MySQL and the JDBC interface deal with stored procedure calls.
Re: Stored procedure is not available in the New Data Set dialog [message #656500 is a reply to message #656491] Fri, 25 February 2011 17:48 Go to previous messageGo to next message
I just did this in MySQL:
-- Routine DDL
DELIMITER $$
CREATE DEFINER=`root`@`localhost` PROCEDURE `test`()
BEGIN
Select * from orderdetails;
END
In the dataset editor I then entered:
{call test()}
And it worked fine.
I know I have seen issues in earlier version of the jdbc driver for MySQL.
I am using:
mysql-connector-java-5.0.4-bin.jar
Jason
> SYS_REFCURSOR)
> as
> begin
> end;
> calls.
Re: Stored procedure is not available in the New Data Set dialog [message #656501 is a reply to message #656500] Fri, 25 February 2011 18:08 Go to previous messageGo to next message
Hello Jason,
Thank you for your solution.
I tried what you did and it works from the MySql command line but still not from within the BIRT gui.
I was wondering if you see your 'test' stored procedure listed in the 'Available Items' listbox in the New Data Set dialog.
If you do see it, then I think that is why it works from the BIRT gui.
I don't see my stored procedure listed in that listbox.
Thanks again,
--Anna
Re: Stored procedure is not available in the New Data Set dialog [message #656832 is a reply to message #656501] Mon, 28 February 2011 12:56 Go to previous messageGo to next message
Anna
I do see it in the list. What version of the driver are you using?
Jason
On 2/25/2011 6:08 PM, Anna T. wrote:
> Hello Jason,
> Thanks again,
> --Anna
Re: Stored procedure is not available in the New Data Set dialog [message #656844 is a reply to message #656832] Mon, 28 February 2011 13:46 Go to previous messageGo to next message
Hello Jason,
The JDBC driver for MySQL I am using is:
mysql-connector-java-5.1.15-bin
I am using MySQL Server 5.5.
Do you think I need to run my 'create procedure' command on a tool that comes with MySQL Server 5.5 rather than on the MySql command line?
Thanks so much again for your help and insights.
--Anna
Re: Stored procedure is not available in the New Data Set dialog [message #656865 is a reply to message #656844] Mon, 28 February 2011 14:23 Go to previous message
Anna,
I am not sure what is going on here. I use MySql 5.1 and the driver:
mysql-connector-java-5.0.4-bin.jar and it works fine.
Jason
On 2/28/2011 1:46 PM, Anna T. wrote:
> Hello Jason,
> --Anna
Previous Topic:No events on Data Source
Next Topic:Breakpoints never hit in Javascript methods
Current Time: Sat Jul 26 07:58:09 EDT 2025
Powered by FUDForum. Page generated in 0.12419 seconds
