Home » Modeling » M2T (model-to-text transformation) » [Acceleo 3] Protected Area
[Acceleo 3] Protected Area [message #655097] Fri, 18 February 2011 05:12 Go to next message
I am not sure I understand how protected areas should work.
The source code placed in a protected area is always lost during a re-generation (a .lost file is generated).
The protected code should not reappear in the generated files ?
In my project (UML --> C), I have a lot of protected areas...
It's quite long and boring to have to copy and paste the contents of the .lost files in my re-generated .c files...
Is there a solution to automate the process ?
Thanks for all,
Alexandre
Re: [Acceleo 3] Protected Area [message #655150 is a reply to message #655097] Fri, 18 February 2011 08:57 Go to previous messageGo to next message
Hi Alexandre,
So let me explain protected areas:
1- you generate some code, then you modify that generated code and you launch the generation once again -> your modification in the generated files are lost
2- you generate some code with a protected area (with an unique identifier -> [protected ('myIdentifier')] ... [/protected] in a given file), you modify your generated code inside of the protected area and outside of the protected area, you launch the generation once again -> the code modified in the generated file outside of the protected area is lost, the code modify inside of the protected area is still there.
Since with a code generation project, you will one day have to modify the generated code. Even when you think that you won't, you will because you will be lazy / late / anything else Very Happy
The protected area allow you to prepare some parts of the generated code for modifications. You can predict where those modifications should appear and where your generator will support those modifications.
If you create an UML to Java generator, you want to create a protected area between the last attribute and the constructor so that you can modify without risk the generated code to add a new attributes and you want to create a protected area after all your generated method to give the user the opportunity to add new methods.
For more information on protected area, you can find here a video that I've realized for the conference Topcased Days, during the "part 7" I show how protected areas work (start at 7min 25s in the video part7).
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Acceleo wiki: http://wiki.eclipse.org/Acceleo
Blogs: http://stephanebegaudeau.tumblr.com & http://sbegaudeau.tumblr.com
[Updated on: Fri, 18 February 2011 08:58] by Moderator
Re: [Acceleo 3] Protected Area [message #656248 is a reply to message #655150] Thu, 24 February 2011 12:07 Go to previous messageGo to next message
Ok thanks...
But, in wich situations a'.lost' file is generated ?
Because I'm quite sure that the identifiers I use for my protected areas are unique...
My scenario is the following :
Step 1- I have protected areas
Step 2- I generate some C source code
Step 3- I modify the C source code (inside the protected areas)
Step 4- I re-launch the generation
Then :
- a .lost file is generated where I can retrieve the source code that I have added in Step 3...
I will re-check the identifiers I use for my protected areas, but I'm quite sure they are unique...
Alex
Re: [Acceleo 3] Protected Area [message #656363 is a reply to message #655150] Fri, 25 February 2011 04:59 Go to previous messageGo to next message
It seems that there really exists a bug concerning protected area.
If not, can you explain me this following error :
1/ First I generate code using the following protected area :
- In the generated code, I had user code ("TOTO") in the corresponding protected area.
- I re-generate the code (no source code modification in my Acceleo modules).
- Result : a .lost file is generated. I retrieve "TOTO" in the .lost file but not directly in the generated code....
2/ Second : I modify my protected area :
/* [protected(' for ' + name + ' includes */')]
/* [/protected] for [name/] includes */
As you can see : I just move '*/' in the protected area name.
Then I follow exactly the same process :
- I generate code,
- I modify the protected area in the generated code,
Result : It works... No .lost file is generated. I retrieve my user-code in the appropriate protected area...
This point is really blocking. Is it a bug ? Did I miss something ?
Thanks...
Alex
Re: [Acceleo 3] Protected Area [message #656367 is a reply to message #655150] Fri, 25 February 2011 05:26 Go to previous messageGo to next message
(sorry, i made a mistake in my last message)
Hi Stephane,
/* [protected(' for ' + name + ' includes ')] */
- I generate code,
Thanks...
Alex
Re: [Acceleo 3] Protected Area [message #656410 is a reply to message #656367] Fri, 25 February 2011 08:34 Go to previous message
Hi Alexandre,
Acceleo does not allow anything to be located between the protected area identifier and the following line separator. Your first use case is wrong because of that, the second correct.
If you really need to put something there, you have to make it be part of the protected area identifier.
Laurent Goubet
Obeo
Previous Topic:xPand and TaggedValues
Next Topic:[Acceleo] Outsource Computation to Java
Current Time: Sat Jul 26 07:59:01 EDT 2025
Powered by FUDForum. Page generated in 0.04904 seconds
