Home » Modeling » OCL » Extend Ocl parser.
Extend Ocl parser. [message #655933] Wed, 23 February 2011 06:33 Go to next message
We are a group of students and we working on " Extend OCLParser for Another language (CCSL) ".
we have the project OCL ( Code source OClParser).
but what's the better way for extend OclParser ?
Solution(?) : extend directly the grammar (file .g) OCL and used ANTLR ?
The file .g , is it generated with ecore ?
Thanks for your time. Razz
rapport_intermédiaire(PDF FRENCH)
http://dl.free.fr/rPL620ga8
http://www.omgmarte.org/
Re: Extend Ocl parser. [message #655998 is a reply to message #655933] Wed, 23 February 2011 12:00 Go to previous messageGo to next message
You have two options:
The old LPG 2 parser
/org.eclipse.ocl/src/org/eclipse/ocl/parser/EssentialOCL.gi evolved to
be extensible for QVT. It is internally extended for Complete OCL. This
parser in its current form will be deprecated as from Eclipse OCL 3.2
but may be resurrected as a transformation from the new parser.
The new Xtext/ANTLR parser
/org.eclipse.ocl.examples.xtext.essentialocl/src/org/eclipse /ocl/examples/xtext/essentialocl/EssentialOCL.xtext
is extended internally by:
/org.eclipse.ocl.examples.xtext.completeocl/src/org/eclipse/ ocl/examples/xtext/completeocl/CompleteOCL.xtext
/org.eclipse.ocl.examples.xtext.oclinecore/src/org/eclipse/o cl/examples/xtext/oclinecore/OCLinEcore.xtext
/org.eclipse.ocl.examples.xtext.oclstdlib/src/org/eclipse/oc l/examples/xtext/oclstdlib/OCLstdlib.xtext
you should find this a much more promising avenue for extension; and
you get an editor almost for free.
Ed Willink
On 23/02/2011 11:34, Bontemps wrote:
> Thanks for your time. :p
Re: Extend Ocl parser. [message #656160 is a reply to message #655933] Thu, 24 February 2011 06:30 Go to previous messageGo to next message
hi Edward,
thank you for your reply.
We find no connection between Meta modele ecore and File .g (grammar)
What is the relation between meta modele ecore and file .g ?
Thank you in advance.
Razz
Re: Extend Ocl parser. [message #656270 is a reply to message #656160] Thu, 24 February 2011 14:53 Go to previous messageGo to next message
There are too many *.g files and *.ecore to try to guess which files in
which version of which plugin interest you.
Please express youir question more precisely.
Ed Willink
On 24/02/2011 11:30, Bontemps wrote:
> hi Edward,
> Thank you in advance. :p
Re: Extend Ocl parser. [message #656348 is a reply to message #656270] Fri, 25 February 2011 03:44 Go to previous messageGo to next message
the file ocl.g is generated by a Meta modele or hand written ?
Thank.
Re: Extend Ocl parser. [message #656361 is a reply to message #656348] Fri, 25 February 2011 04:49 Go to previous messageGo to next message
There is no ocl.g.
As I wrote before:
"There are too many *.g files and *.ecore to try to guess which files in
Please express youir question more precisely."
i.e. provide the full folder path and version/origin of "ocl.g".
It appears to me that you are probably not using Eclipse OCL.
Ed Willink
On 25/02/2011 08:44, Bontemps wrote:
> Thank.
Re: Extend Ocl parser. [message #658498 is a reply to message #656361] Tue, 08 March 2011 13:09 Go to previous messageGo to next message
Hello Ed,
I' continuing the work hardly started by my students...
I have now a working editor of my new grammar based on OCL and generated from Xtext.
As a first test we simply extended the completeOCL.ecore and its xtext grammar.
I still have a problem, and this problem appears even before the introduction of new metaclass in the ecore.
I'm not able to "import" any uml model and to have the completion. Before it was not my priority I didn't care but now, I'd like to finalize this part.
Have you got an OCL file compliant with the CompleteOCL syntax which import a uml or any other model file ?
Consider a simple model where a 'A' class contains some 'B' class instances by using the 'myB' association
I tried this :
import MyImport : 'Simple.uml'
context A
	inv test:
		self.myB.size() <> 0
What's wrong ?
Thanks in advance !
Julien
[Updated on: Tue, 08 March 2011 13:10] by Moderator
Re: Extend Ocl parser. [message #658506 is a reply to message #658498] Tue, 08 March 2011 13:47 Go to previous messageGo to next message
Hi Julien
The UML support is work in progress.
I had hoped that with the underlying Pivot model being UML-based, that
the UML support would be much easier than the Ecore support. There is
support for pure UML, but any practical UML involves a profile, which is
not yet supported.
I'm hoping to get this in Indigo, but it will be touch and go.
You may be able to workaround the limitations by exporting your UML to
Ecore for now.
/org.eclipse.ocl.examples.xtext.tests/src/org/eclipse/ocl/ex amples/test/xtext/models/RoyalAndLoyal.ocl
(and sibling files) will provide you with an Ecore (and other) examples.
There is no completeOCL.ecore. Did you mean CompleteOCLCST.ecore?
Ed Willink
On 08/03/2011 18:09, Julien DeAntoni wrote:
> Hello Ed,
> grammar.
> finalize this part.
> I tried this :
> context A
> inv test:
> What's wrong ? Thanks in advance !
> Regards,
> Julien
Re: Extend Ocl parser. [message #658512 is a reply to message #658506] Tue, 08 March 2011 14:23 Go to previous message
Hi Ed !
Sometimes I feel ambitious but I have no real needs to work on uml so I'm going to work on ecore models Rolling Eyes
It's perfect for all my tests. A little point for future readers of this post, I founded the royalandloyal.ocl in
/org.eclipse.ocl.examples.project.royalandloyal/oclsrc/RoyalAndLoyal/RoyalAndLoyal.ocl"
Exactly ! I planned to make a mix between this metamodel and mine in order to provide a formal temporal extension to OCL.
Thanks for your message.
Good luck with the UML integration.
Julien
Previous Topic:IMP
Next Topic:OCLInvalid Error
Current Time: Wed Jul 23 06:47:07 EDT 2025
Powered by FUDForum. Page generated in 0.08031 seconds
