Home » Modeling » EMF » [query2] How may I do a query on attribute values using regexp?([query2] How may I do a query on attribute values using regexp?)
[query2] How may I do a query on attribute values using regexp? [message #656179] Thu, 24 February 2011 08:22 Go to next message
Hi all
I'm new on modeling with EMF .
I need to do a search on string attribute values using regexp and case sensitive flag.
I have discovered the Model Query2 framework but from its guide (http://wiki.eclipse.org/EMF/Query2/DevGuide) I cannot figure out how to use regular expressions.
It seems that the Model Query framework has a regexp support and from Query2 project page (http://www.eclipse.org/modeling/emf/?project=query2) I read:
Query2 supports multiple ways to specify queries.
1. User can use APIs for the basic EObject based Condition objects that are used to formulate queries for EMF models.
Unfortunately I haven't found a way to use Condition objects along with the index support.
Any suggestion about using Query2 for searching strings using regexp?
Thanx
Fabrizio
Re: [query2] How may I do a query on attribute values using regexp? [message #656317 is a reply to message #656179] Fri, 25 February 2011 00:43 Go to previous messageGo to next message
You can do a search on string attribute values using an SQL like syntax using wild characters in query editor like below.
AllPersonNoJoinsAndNoNests:
from Person withoutsubtypes as p
select p where p.name like 'kolb*'.
Also the characters within single quotes are case sensitive.
Also the same can be achieved in object based query format, using the operation like,
WhereString whereClause =  new WhereString("title",org.eclipse.emf.query2.Operation.LIKE, 'Linus Made*');
		LocalWhereEntry localWhereEntry = new LocalWhereEntry("m", whereClause);
Hope this helps for your issue.
Manasa
Re: [query2] How may I do a query on attribute values using regexp? [message #656320 is a reply to message #656179] Fri, 25 February 2011 00:55 Go to previous messageGo to next message
Manasa
Re: [query2] How may I do a query on attribute values using regexp? [message #656351 is a reply to message #656317] Fri, 25 February 2011 04:19 Go to previous messageGo to next message
Thank you for your kind reply.
It's a useful hint, but it raises new questions.
You have mentioned a "query editor": do you mean that the Query2 plugin comes with its own editor? If so how can I use it?
What wild-char are supported other then *?
I need to generate queries dynamically. If I opt for the object base query format I cannot use patterns delimited by single quotes, so how can I switch to and from a case sensitive query? Alternatively, the sql format allows parameters in queries?
Fabrizio
Re: [query2] How may I do a query on attribute values using regexp? [message #656365 is a reply to message #656351] Fri, 25 February 2011 05:10 Go to previous message
Fabrizio Casali wrote on Fri, 25 February 2011 04:19
Yes
You can create a .query file in your workspace, provided the following plugins are present in your development workspace.
org.eclipse.emf.query2.stringsyntax.ui
org.eclipse.emf.query2.stringsyntax.tools.ui
You could then import your the namespace URI of the epackage, as the first line, which will be followed by queries, like below
import "http://eclipse.org/modeling/emf/query/1.0.0"
You could then run the query using the context menu, and selecting the query---->Run Query.
Alternatively you could open Query View where all the queries will be listed, you can execute the queries from there.
Presently only * is supported.
Sorry, that was a mistake from my side, in the object based query format,
you will have to specify the pattern within double quotes.
Also, it is possible to use parameters in queries, and replace them accordingly in your implementation.
You could refer to the below link for details on it.
http://www.eclipse.org/forums/index.php?t=msg&th=198593& amp; amp;start=0&S=6611ff721c0273e3462494026d3f04e9
Manasa
[Updated on: Fri, 25 February 2011 05:13] by Moderator
Previous Topic:Turn of generatation of PDE artifacts?
Next Topic:[TENEO] Integratind EMF and GMF generated editors
Current Time: Fri Jul 25 23:59:47 EDT 2025
Powered by FUDForum. Page generated in 0.07061 seconds
