Home » Archived » BIRT » HowTo - Scripting - Dinamically get Images...
icon5.gif  HowTo - Scripting - Dinamically get Images... [message #655837] Tue, 22 February 2011 14:07 Go to next message
I'm having difficulty using scripts to dynamically set the URI of an image in a report.
What I need to do is this:
When running a preview of the report, find the Path of the project folder, and inside that folder, look for a file that ends with jpeg. I'm trying to insert javascript in the URI field of the image. I know how to search in a directory for the file that ends with jpeg. My problem is to take the path of the project folder, or the name of the project.
Any help?
Thanks.
Re: HowTo - Scripting - Dinamically get Images... [message #655864 is a reply to message #655837] Tue, 22 February 2011 16:51 Go to previous messageGo to next message
How are you going to deploy the report?
Have you seen this post?
http://birtworld.blogspot.com/2010/09/birt-image-report-item .html
Jason
> image in a report.
> Any help?
> Thanks.
icon5.gif  Re: HowTo - Scripting - Dinamically get Images... [message #656058 is a reply to message #655837] Wed, 23 February 2011 17:37 Go to previous messageGo to next message
Hi.
I Had already looked at the link but could not find a guide to what i need to do.
The Report will be distributed through a template that I'm setting. The user must create a report from the template I'm developing.
In my situation I do not know the path of the image because I do not know the name of the project created by the user, and also do not know his workspace. Just know that there must be a jpeg file in the user's project folder.
I need a way to find the path of the project through a javascript entered in the URI field of the Image in the reportTemplate.
Thank you for listening.
Bruno.
Re: HowTo - Scripting - Dinamically get Images... [message #656228 is a reply to message #656058] Thu, 24 February 2011 10:44 Go to previous messageGo to next message
Bruno,
Most BIRT projects setup a resource folder to contain things like
images, libraries, external js files etc.
If you used this approach you could enter:
var myurl = reportContext.getResource("green.png");
As the expression. If that is not an option try something like:
var mybundle =
Packages.org.eclipse.core.runtime.Platform.getBundle("my.rcp.application ");
var furl = FileLocator.find(mybundle, new Path("/"), null);
var myimage = FileLocator.toFileURL(furl).getPath() +"myimage.png";
Jason
On 2/23/2011 5:38 PM, Bruno Mattos wrote:
> Hi.
> need to do.
> project folder.
> Bruno.
icon5.gif  Re: HowTo - Scripting - Dinamically get Images... [message #656263 is a reply to message #655837] Thu, 24 February 2011 14:33 Go to previous messageGo to next message
I tried as suggested but could not solve the problem.
When running javascript, I get NullPointerException on the line "var furl = FileLocator.find (mybundle, new Path ("/"), null)".
I noticed that the variable mybundle is set to NULL.
I'm new in the Eclipse environment and do not know exactly which symbolicname should pass to the method Platform.getBundle.
I looked the Platform class in Eclipse API and did not find guidance on this.
Any suggestions?
Thank you very much for the help.
Bruno.
Re: HowTo - Scripting - Dinamically get Images... [message #656275 is a reply to message #656263] Thu, 24 February 2011 15:16 Go to previous messageGo to next message
Bruno
Try:
//extra code to show how to iterate projects
importPackage(Packages.org.eclipse.core.resources);
projects = ResourcesPlugin.getWorkspace( ).getRoot( ).getProjects( );
projectString = "";
for ( i = 0; i < projects.length; i++ )
proj = projects[i];
projectString += proj.getName( ) + File.pathSeparator;
var wkspcroot = ResourcesPlugin.getWorkspace().getRoot();
var myProject = wkspcroot.getProject("BIRT Reports");
var specFolder = myProject.getFolder("demo").getLocation();
Jason
> this.
> Any suggestions?
> Bruno.
icon14.gif  Re: HowTo - Scripting - Dinamically get Images... [message #656449 is a reply to message #655837] Fri, 25 February 2011 12:39 Go to previous messageGo to next message
I managed to solve my problem.
Using the solution suggested earlier - var myURL reportContext.getResource = ("green.png") - can get on the path to the project where my report is located, I just need to know the name of a file that is in the project.
For example, I can do:
var myurl reportContext.getResource = ("whatever.whatever");
(assuming there's a file named whatever.whatever in the project folder)
And then I just need to remove the end of the string, so i get the address to the the project folder.
I can also point to the report itself, since I know the report's name.
Any tips on how to get the report's name directly from a javascript that is running in a Image's field?
Thank you for your help.
Re: HowTo - Scripting - Dinamically get Images... [message #656460 is a reply to message #656449] Fri, 25 February 2011 13:24 Go to previous message
Use one of these methods:
reportContext.getRenderOption().getOptions().get("report");
or
reportContext.getReportRunnable().getReportName();
Jason
Previous Topic:Problems with viewing report as PDF and also in Preview
Next Topic:Font not in list
Current Time: Sat Jul 26 16:59:18 EDT 2025
Powered by FUDForum. Page generated in 0.06455 seconds
